Old 07-31-2010   #381
Re: 91 Galant VR4
I look forward to it..hopefully no 4am nights setting up that 2-step..lol. I can already hear the wife..and neighbors...
Old 07-31-2010   #382
Re: 91 Galant VR4
I will get the car back up in the air and check everything over and switch to the good tires. Setup the shift light and the 2 step.
Rock falls Aug 7/8 is the next test day, I will try to make it out there. Then the next day is Aug 28/29.
The car weighs in at 2450 as swift said, I weigh 185, so it should be around 2600-2650 running down the track. The turbo setup and water to air setup weigh a lot.
LMAO, weighs a lot. Good luck man, let us know when you go out there I wouldn't mind seeing this action first hand.
Old 07-31-2010   #383
Re: 91 Galant VR4
The turbo is 45lbs, the exhaust manifold and WG's are another 40lbs, the W/A intercooler core, heat exchanger, lines, pump, and 4 gallons of water another 100lbs. That is about 185lbs total, but is weight that needs to be there, other wise I make no OMG hp, o wait I do not make OMG hp, zing.
Old 07-31-2010   #384
Re: 91 Galant VR4
shut it john. It's still more then 97% of people out there, and on this board. and it seems to work well together. It's been fun watching/helping were I can, seeing this go from stands/white bay, to the tubed moon taxi grocery getter it is now. Mount up those 2 rear seats, and make it an amusement park ride...
John's Moon Taxi service..coming to an on-ramp near you..
Old 07-31-2010   #385
Re: 91 Galant VR4
Back OT, I found a few 1/4 mile calculators and they say 8.8@153mph with 2600lbs and 740whp. So to address Brown mans question, I wanted 600whp, check, now I want to get as close to 8.8@153mph as I can then add more power.
Old 07-31-2010   #386
Re: 91 Galant VR4
You got a link to those 1/4 mile calculators?
BTW, B.I.R. has wed night drags on the 4th and 25th and a Bracket racing weekend on the 21-22nd also.
Old 07-31-2010   #387
Re: 91 Galant VR4
Mike, BIR on wednesday nights require you to run street tires and a full exhaust.
Old 07-31-2010   #388
Re: 91 Galant VR4
I thought you needed to have exhaust that exits behind the driver to run on Wed night drags, My BFG tires are street tires but also they do NO track prep so I would slide all over. I have lined up a trailer for the 7th at Rock falls.
http://www.hotrodpitstop.com/tools.html
Old 07-31-2010   #389
Re: 91 Galant VR4
John, I have nothing going on that day if you'd like a helping hand or some moral support.
Old 07-31-2010   #390
Re: 91 Galant VR4
According to that I should be 9.2 @ 145. haha
Good luck at the track, should be cool to see what it can run.
Old 08-01-2010   #391
Re: 91 Galant VR4
So based on the numbers, C3L1CA your car was 16% slower on the ET and 3.5% slower on the MPH. Based on that I should be in the 10.2@147mph range. What tires and 60ft did you have at the track? The fastest GVR4 is a 9.5xx@something slowish like 145.
Old 08-01-2010   #392
Re: 91 Galant VR4
Oooo! You better raise that HP number up then. Pretty weak at 635, if I say so myself. lol. I want to see in car video of JDM John shifting faster than lightning.
Old 08-01-2010   #393
Re: 91 Galant VR4
There is the boost graph, I forgot to post it up.
Old 08-01-2010   #394
Re: 91 Galant VR4
Nice! That should be close to mid 700's on MAP's dyno.
Old 08-02-2010   #395
Re: 91 Galant VR4
I'm pumped for track day, so far so good?
Get any street time on it?
Old 08-02-2010   #396
Re: 91 Galant VR4
I have about 122 miles on this new setup, plus 5 gallons of E-85 for tuning. I have only gotten on it 2 times, both in 2nd gear. The car pulls straight and I can down shift into 2nd at high way speed.
Old 08-02-2010   #397
Re: 91 Galant VR4
I also can't drive as well as I should and this was on fuzion street tires spinning through all of first. The 60' time on the 10.7 run was 1.839 which is pretty crappy. I think that thing has a 9 in it, you just gotta drive the crap outa it!
Good luck dude, i'm sure you'll have a ton of people waiting to hear what this beast does down the track!
Old 08-02-2010   #398
Re: 91 Galant VR4
We will see, I hope the drive train stays in one piece for a pass or 2.
Old 08-02-2010   #399
Re: 91 Galant VR4
Mph is close, but the ETs from the calulators are more for a RWD auto.
Old 08-02-2010   #400
Re: 91 Galant VR4
http://www.dsmtimes.org/times.php?He...pe=GVR4&Page=1
Theres a few more in the 9's but I would be ok with the #5 spot first time out and on e-85.
