Old 02-06-2013   #381
Re: Mark's 1G Winter Projects
for bending pipe I leave the die surface ruff with no lubrication, and I polish the shoe surface and apply plenty of grease on the shoe and pipe while bending. I have a Pro Tools bender that we made into a 12volt hydraulic/electric.
We figured it took about 250lbs on a 3 1/2 foot bar to bend a 1 5/8" chrome moly tube.
Any thoughts for front to back braces similar to factory?
Old 02-06-2013   #382
Now you just need Vassil's new k-member to drop a little more weight off the front.
Old 02-07-2013   #383
Mark Leasure
Mark Leasure's Avatar
Thanks for all the feedback. I’m going to rock it how it is. It’s a lot stronger than it looks. The motor is supported by 3 other mounts too, and the motor can be considered a part of the system. I can jack the car up by the front bar and there is minimal deflection, without the bolt installed on the roll stop. No worries here! The car is off to paint tomorrow.
www.maperformance.com
Old 02-08-2013   #384
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
sweet, cant wait to see pics. wheres it getting painted?
2006 WW IX RS 396/404 - SOLD
Old 02-08-2013   #385
Mark Leasure
Thanks for the advice. I'm going to polish the shoe surface and experiment. Do you know what the radius is for your die? My benders die radius is very small at 5” and I’m sure it adds to the problem. I see the JD2’s have a 6.5”. I don't have plans to make it hydraulic, unless I start getting sick of ratcheting.
Old 02-08-2013   #386
Mark Leasure
So after its painted your putting it back together with the dog box? Or you going to work the 5 spd some more.
I'm going to run the dogbox. The other trans has a stripped 4th gear.
Old 02-08-2013   #387
4seasons69
4seasons69's Avatar
what were you running for a trans last summer??
Old 02-08-2013   #388
Pretty sure it was a shep stage 4 right mark?
Old 02-08-2013   #389
Mark Leasure
It was a Jacks trans evo 3 gear cluster (1-4 double syncro). Self built with a TRE center diff spool and VCE clamp.
Old 02-08-2013   #390
^Did that have the rip grip insert? If so, do you still have it?
Old 02-09-2013   #391
Mark Leasure
Update:
Bumper and areo parts are painted, looks awesome. They are not attached yet but fit perfect.
I took out the front subframe so the painter could get everything on the fire wall. And to clean up, rebuild and paint the subframe. The car will be ready to be picked up next week!
Old 02-09-2013   #392
Omg sex. How are those side covers attached? Any pics from the back?
Old 02-09-2013   #393
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Sub frame is out. Time to call Vassil. Looking good. Is the tube sticking out the front for a tow hook?
11.35 @ 120mph
Old 02-09-2013   #394
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Why? Because racecar! Yeah that's a tow hook.
Old 02-10-2013   #395
4seasons69
4seasons69's Avatar
Very cool!
The bumper looks great!
Old 02-12-2013   #396
Mark Leasure
A couple of update pics, It's painted. I need to get it home now to get some parts on it!
I rebuilt the cross member too. Degreasing & power washing it took forever! The energy suspension bushings show up tomorrow to finish it off. Then I need to get it back on the car so I can pick it up.
Old 02-12-2013   #397
You could replace that heavy complex looking crossmember with a piece of steel tube with some brackets! This car doesn't need to turn anyway, right?
Old 02-12-2013   #398
Cross member looks clean! Did you get it powdercoated?
Old 02-12-2013   #399
Call Vassil and save yourself more work!
Looks fantastic.
Old 02-12-2013   #400
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Paint looks great!! Love that blue
