Old 07-09-2015   #401
Annoying as hell to be honest! I'm very glad it's off.
I never got retuned for the ported intake manifold since after the first test-drive I knew it would be coming off. Without proper retuning the ported intake manifolds show zero gains, so no, I did not feel any difference. I plan to eventually give the WeaponX ported intake manifold a shot since those are not supposed to have any adverse side effects, but he was taking too long and I wanted to have the car 100% for the cruise in two weeks.
My WeaponX Stage 1 ported intake manifold finally came in yesterday! It took so long because he was having trouble getting cores back from other customers, so he eventually just ordered a brand new one to get ported and have sent to me (which I will gladly accept, especially considering he didn't charge me a core charge). This one is quite a bit more expensive than the FasterProms whistler ($350 vs $150), but from initial impressions it is warranted (assuming it doesn't whistle as he claims). I was tempted to swap it on quick-like last night, but decided against it to just leave well enough alone for my 3k mile roadtrip that kicks off next week. I'll likely get it swapped on in early August to make sure it's retuned and ready for the annual Shreveport cruise later that month. I haven't taken any pictures yet, but the port work is definitely more in-depth, smoother, and more uniform. After now having both WeaponX's ported intake manifold and throttle body in my possession, I'd put their quality and attention to detail to be on the same level as MAP's work (I'm still bummed MAP wasn't interested in porting the intake manifold). I'll see if I can get some pictures tonight and post them tomorrow for visual comparison vs. the FasterProms.
Old 07-09-2015   #402
Hot giggity!!! Can't wait to see your impressions of this.
Get a f'ing big cam in this thing already!
Old 07-09-2015   #403
Hell no Operation stock tune and emissions compatibility is still in full effect!
The ported IM should put me somewhere around 450whp (DynoJet) if my estimation is correct.
Old 07-09-2015   #404
That's pretty stout for mods that don't affect driveability.
Old 07-09-2015   #405
I would concur, and that is exactly my plan. Zero drawbacks or reliability concerns.
Old 07-09-2015   #406
What I wouldn't do for a rigid aluminum oil pan with a built in sealing ring ala LS versus the flimsy tin pan and RTV solution for DSM's. I spend all last night chasing down small oil leaks, meanwhile my 100K+ mile Tahoe has yet to ever shred a drop of any fluid. LS for the win!
Old 07-09-2015   #407
LT FTW
I just hope they prove to be as durable as the LS!
Old 07-09-2015   #408
So you didn't order that supercharger yet?
Old 07-09-2015   #409
Ordered...then canceled
I had to remind myself it didn't fit in my plan.
Old 07-09-2015   #410
You have the Cruze for the plan! SC time!
Old 07-09-2015   #411
HAHA! This was back in December or so, and honestly has barely even crossed my mind since. I think the modding bug was starting to itch a bit but has since cleared up with a few more simple bolt-ons.
Old 07-09-2015   #412
Yea plenty of power being NA, I dont blame you!
Old 07-09-2015   #413
I'm sure it'll eventually get a Procharger kit though
Old 07-09-2015   #414
Do they make a cam that is mild enough that won't screw up drivability? Something similar in nature to like a DSM 264. Little bump in power, but no real noticeable drivability downfall?
Old 07-09-2015   #415
Probably, but I'm not really interested in tearing into the engine since that opens a whole new can of worms for potential oil leaks, tuning issues, etc.
*edit*
Here is pretty much what you were referring to: https://texas-speed.com/p-4547-texas...lications.aspx
By doing a cam, I would lose the Active Fuel Management (cylinder deactivation) functionality. Not a big deal to some, but I like it for roadtrips.
Old 07-10-2015   #416
WeaponX Stage 1 LT1 ported intake manifold pics:
The biggest difference in this port job is the lack of any internal sharp edges or lips, which are likely what caused the whistling with the previous manifold.
Old 07-10-2015   #417
Stock manifold for comparison:
INLET
RUNNER
FasterProms for comparison:
Old 07-10-2015   #418
Nice! I was starting to wonder if this was still a car site or just politics
Old 07-13-2015   #419
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Uhh exactly
2006 WW IX RS 396/404 - SOLD
Old 07-13-2015   #420
Originally Posted by evotuner View Post
Uhh exactly
Agreed, and you're welcome.
Next minor mod that I plan to order and stockpile for a boring weekend: C7 Z06 Z07 swaybar bushings. It turns out that all C7's with magnetic ride control (Z51 w/MRC option, Z06, & Z06 w/Z07 package) all share identical swaybars, with the Z07 getting stiffer bushings than the rest. The set of 4 should be right around $20-25 I think so I plan to get them ordered sooner or later since it should tigthen up the suspension by a little bit with minimal effect on ride quality. They're still made of rubber so there shouldn't be any additional noise.
