Closed Thread
Old 03-06-2007   #401
Re: Finally getting stuff done on our cars
X-ray of welds plz thx.
Super Bleeder!! is offline
Old 03-06-2007   #402
rst95eclipse
Originally Posted by rst95eclipse View Post
Put the downpipe on! Snap, snap, post.
Tight fit, but pulled it off. How far will the radiator be pushed to the front? "That's the biggest front mount I've ever seen!"
rst95eclipse is offline
Old 03-06-2007   #403
Gotta love the Weld-els!!!!
Halon is offline
Old 03-06-2007   #404
Originally Posted by CVD View Post
I dont think I've ever seen a welded piece where you didnt ask this. Do you have a weld fetish or something?
Yep.
Sure, any specific area you want?
Any weld process close-up you want?
Intercooler piping would be excellent. Tubular manifolds are not of interest to me. Tig or mig, what ever you all use when building intercooler piping.
Jakey is offline
Old 03-06-2007   #405
Yep.
Sure. We usually TIG IC piping as it is 99% of the time stainless, unless the customer is on a severe budget, then we will MIG mild steel.
Do you want to see raw welds on something? Endtank welds?
Just curious as to what you are looking for. I can have the guys go throw a bead down on some pipes to join them together, or what not.
niterydr is offline
Old 03-06-2007   #406
Some pics of the intercooler welding on my car after a few months of beating it up.
niterydr is offline
Old 03-06-2007   #407
Man that looks like total crap, I'd tear that apart and re-do it. Let me know if you need me to show you how to actually weld.
....JBWeld that is.
scheides is offline
Old 03-06-2007   #408
....JBWeld that is.
JB welding is an aquired skill! I might have to hit you up for some lessons, as I haven't done it in years I might need a refresher course .
niterydr is offline
Old 03-06-2007   #409
Welding that IC was fun, inside/outside welded endtanks and in/out pipes. Then I used almost all the TIGs power to weld the endtank to the IC core, and about 4 24"x 1/8" alum. rod for one front weld. Chris came in the shop 2-3hours after I welded the IC and he said "hey you just get done welding that", It was a little hot. I will do some weld samples tonight and we will get pics up, it will be nice for the show floor anyways. So SS ic piping, Mild steel/chrome moly cage tube welds, Aluminum welding, and schedual 40 304 SS for the race tubular headers.
Pushit2.0 is offline
Old 03-06-2007   #410
Yea, it's all about not touching *anything* except what you are welding together, and then as soon as your finger leaves the welding surface doubling back and wiping it with a paper towel. Pretty tough to get it right, really. If you want to do some practice JB Welding I do *not* suggest masturbation!!!
scheides is offline
Old 03-07-2007   #411
Yea, right. Try it! The goal is to get off, before the JB hardens!
-A. Swift
Swifty1638 is offline
Old 03-07-2007   #412
-A. Swift
That is enough!
/topic of JB weld on this thread.
niterydr is offline
Old 03-07-2007   #413
That is enough!
I just laughed so hard I think I woke my roommate up.
Matt D. is offline
Old 03-08-2007   #415
The digital camera does not want to take a good close up pick for the welds, sorry jakey. I did get some more work done tonight, pics should be up sometime tomorrow. IC pipe is done, down pipe just needs a vband, water to air is mounted now I just need to fab up the custom endtank on the intake manifold side, exhaust manifold is done minus waste gate, then the Intake manifold with a q45 TB is my next project.
Old 03-08-2007   #416
PSI2HI
Divided housing, or no?
PSI2HI is offline
Old 03-08-2007   #417
Yes.
How have you been?
niterydr is offline
Old 03-08-2007   #418
PSI2HI
Yes.
How have you been?
Running twin gates or single?
Not to bad, pluggin away waiting for winter to be done.
PSI2HI is offline
Old 03-08-2007   #419
I am going to try 1 Tial 38mm with a 1bar spring for pump then add another spring for 1.6bar then a MBC and turn it up untill the head blows off the block, switching fuel at about 35psi. The Tial will be just off the #2 and #3 collector just befor the turbo. If that is not enough then I will add a 2nd waste gate. Right now the manifold is divided with a divided flange and the primary runners are within 1" of equal length.
Old 03-08-2007   #420
PSI2HI
I think your cutting yourself short on wastegate on both boost control and being able to release enough backpressure. What AR turbine?
PSI2HI is offline
Closed Thread
