Old 07-23-2011   #501
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Project Lex
Maybe running a bit rich.
Car is looking good B
looks like black smoke then turns blue so running rich and burning oil?
Originally Posted by 311evo
Old 07-23-2011   #502
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Lex
Wait where is the turbo blanket?
Amsoil Dealer
Old 08-08-2011   #503
Re: Project Lex
Thanks Blaine Auto Detailing. Did a complete detail in/out, great discount thanks to Mo. They did a decent job, but in the end there still is no magic cure for bad/chipped paint.
Will start on fuel system mods this week.
Same pic, just a couple different camera settings
Old 08-08-2011   #504
93gtpeater
Drives: cbr 1000rr repsol
Re: Project Lex
Car looks real good. whens it hitting the dyno for some numbers and a tune?
Old 08-08-2011   #505
Re: Project Lex
Who knows. Next spring maybe at this rate.
Old 08-08-2011   #506
Re: Project Lex
Why no little inside round lights in the front bumper?
Old 08-08-2011   #507
blackawdtsi
Drives: 2G DSM
Re: Project Lex
I'm guessing to keep the radiator cool and intake temps down.
Old 08-08-2011   #508
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Project Lex
Car looks pretty damn clean. Would you recommend them to others for the detail? I was going to get the evo a full detail when I get it back and have thought about using them before, I have heard mixed reviews though from some saying they didn't really do anything worth the money that they charge but not from anyone I really trust.
Yours looks clean for sure though but I don't really have a comparison since I haven't looked at yours enough before.
Regardless, nice update!
Old 08-09-2011   #509
Re: Project Lex
Spring my ass, lets get this thing going, just needs fuel mods and then dyno time!!
Car felt gorgeous last night, I think I'm gonna get all my rides done.
Old 08-15-2011   #510
Re: Project Lex
While disassembling to do the injectors and AFPR, I quick did a compression test.
1 - 210
2 - 210
3 - 210
4 - 200
5 - 175
6 - 200
Cyl 5 might be part of the reason we saw so much smoke in that video I posted... But still seems good enough to let er buck for a little while
Started on the fuel system. Got the injector clip pigtails soldered in in-place of the stock clips. Then installed the injectors. Decided to install my AEM AFPR since I was right there. I had a spare -6 to M12 x 1.5 fitting laying around. Found the hole where the stock FPR was mounted accepts an M12 tap pretty much perfectly as-is without drilling the hole any larger. So I tapped it and installed the fitting. The AEM AFPR inlet ports are made to screw into a -6AN fitting. So I mounted it right to the fitting on the fuel rail. Nice and simple/clean, I really liked it! Just didn't like the way it pointed. So I tried to turn the fitting a little bit more. Oops, snapped the fitting I was able to extract it so no real harm. I ordered some replacement fittings from Summit that arrived today. So I finished up the install today. I'm pretty happy with how simple of a setup it is.
Next I need to get the car running on the new injectors, and set the base FP with the new AFPR. Then install the dual 255hp pumps, get it half-way dialed in, then take it to Shane at DB Performance to get it tuned on the dyno at around 15psi levels for now.
Anyhow, on to some pics of the injector/AFPR install:
Tinning the pigtails:
All pigtails soldered/heat shrunk in place:
Tapping fuel rail for M12 x 1.5 fitting (if I were to do this again, I would have done 3/8npt)
Fuel rail tapped
Fitting installed. You can see the blue fitting is the M6x1.5 for the Fuel Feed. The silver one is the spare one I had laying around and is being used for the return end
Injectors and fuel rail installed. Again, big thanks to Shane at DB Performance for helping me pick these injectors out, and getting the correct ones on the first try for this car, and the great price!
New set of BCPR7ES plugs
AFPR wasn't in the exact angle I wanted so I tried turning it a little more, Ooops
Easy out to save the day
Purchased a new bunch of fittings from Summit (didn't take pics of it all though). Ended up using the same blue Earls fitting for the return as I had on the feed (I like the oring it comes with).
AEM AFPR installed with Turbosmart gauge. I love the stealth black look Big thanks again to MAPerformance for the great price on the AFPR setup
Hard to see, but I simply used a 3/8" male-male barbed fitting to extend the stock rubber return hose to reach the new AFPR
All done
Old 08-15-2011   #511
Re: Project Lex
FUcking Awesome!!!!!
Those are some nice ass wire strippers d0g!
It's so close.
Old 08-15-2011   #512
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: Project Lex
I have a soft spot for these cars, so win in my book. Needs lots more tire in the back and it would be perfect for me. They swap ls1's in these pretty easily..
Old 08-16-2011   #513
Re: Project Lex
http://www.youtube.com/watch?v=VntljfdpQ7w&hd=1
Old 08-16-2011   #514
Re: Project Lex
Your CEL is on, better get that checked out at Autozone.
Old 08-16-2011   #515
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: Project Lex
Looking good man! How close are you to bringing it to shane?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 08-16-2011   #516
Re: Project Lex
Bad ass! When's the maiden voyage?
Are you going straight to E85 or are you getting it tuned on pump gas first?
Old 08-17-2011   #517
Re: Project Lex
Haven't decided on switching to e85 yet or not.
Got a little bit motivated in the wee hours of the night. Since I'm only running low boost for now, decided to install just a single 255hp in an attempt to "hurry up" and get this thing back on the road and tuned before winter. Will install the 2nd one in parallel this winter.
Old 08-17-2011   #518
Re: Project Lex
Good work B! Its coming along!
Old 08-17-2011   #519
Re: Project Lex
Nice updates, hope to see this thing sometime when I'm back.
Old 08-17-2011   #520
Re: Project Lex
