Old 04-28-2010   #521
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Swifty's never-ending project thread!
Whats wrong with the permatorque's? I have yet to hear of one failing yet. (Except on Rau's car.)
Yeah, and Rau's car could break God.
Originally Posted by Trogdor
Old 04-28-2010   #522
when I got the mls for alys car it was around 120 with the discount now. so I am done with them and just will get the perma's from craig since I get his price on it.
Old 04-28-2010   #523
MAP doesn't have the MLS in stock, and even so, it's $130. It looks like I'll be going with the permatorque.
Old 04-28-2010   #524
cmspaz
Walls need hugs too
cmspaz's Avatar
Call Craig, do work.
Old 04-28-2010   #525
Get me a cost. Otherwise, I'll just do it through MAP.
Old 04-28-2010   #526
cmspaz
Walls need hugs too
cmspaz's Avatar
I'm not at work all day today, that's why I said to call Craig. Or call the store, 763-566-1274.
Old 04-28-2010   #527
Yeah, and Rau's car could break Chuck Norris.
Fixed.
Mitsu MLS with no spray gets my vote. Evo's stock head gasket is MLS and none of us recently have used copper spray and they've held just fine.
Old 04-28-2010   #528
santa
Boost Spike
santa's Avatar
Do you ever read what people write or just part of it? lol I never said anything about permatorque's being bad.
Old 04-28-2010   #529
anyone copperspray permatorques? I hear it's in a sealed package that is already tacky?
Old 04-28-2010   #530
Whoops, I read that wrong. Thought you said fel-pro's suck.
Yep, I would never spray a PermaTorque
Old 04-28-2010   #531
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
I wouldn't spray a headgasket period. Just make sure both surfaces are as clean as possible. If the gasket is gonna seal, it will seal.
-1990 Mitsubishi Cyborg 4WD-
Old 04-28-2010   #532
ylimert01
ylimert01's Avatar
Drives: Nissian
If it ain't broke..why fix it?
preventive maintenance?
F Subarus!!!
-Emily
Old 04-28-2010   #533
I am always a fan of that, and since it will be torn apart shortly, I just might do that water pipe o-ring.
Old 04-28-2010   #534
You can't compare the Evo MLS to the DSM one, nor the head rigidity between a DSM head and an Evo head.
I would run the Permatorque, and don't copper spray it. Copper spray is not going to do shit for holding in it 2500psi of cylinder pressure.
Old 04-28-2010   #535
For the last goddamn time. I did not reuse my fucking gasket. I got a cometic HP, but drilled out 3 of the 4 rivets, coppersprayed all 4 parts, let sit overnight, then re-assembled, put back on the car, then slapped the head on, only to need to lift it off a bit to get the washers on..THAT's where I went wrong. If I get nothing but people finger pointing, then I won't ever update this thread again, and you all can go read some other shit. No skin off my ass. Shit happens sometimes, oh well! It will be fixed when I can fix it. Big fucking deal.
Its ok swifty. I do recall the conversation but it was more of a pondering as to whether to reuse or not to. which he came to the conclusion that he would not be reusing. I am reusing mine, and i will post up the compression tester results and we can compare. But i have always reused my metal head gaskets, never taken out the rivets though that seems pretty extreme. Maybe next time ring the block and head and not have to worry about expensive head gaskets.
Speaking of which have you done a compression test?
Old 04-28-2010   #536
I am reusing mine
This thread is full of fail. I don't see the point to trying to be a cheapass and save a few bucks when it risks having the rip the head off again, buy a new gasket anyway, plus all the additional stress, headache, and downtime.
Old 04-28-2010   #537
blackrosenova400
blackrosenova400's Avatar
Plus headstuds, or any studs for that matter dont like to be stretched 50 times...
20g Mafia
Old 04-28-2010   #538
I just palmed face so hard I am now bleeding and partially blind. You have got to be joking. Please tell me you are.
Compression test isn't going to prove jack shit unless you absolutely fucked up the head installation or the gasket is severely messed up. When the cylinder fires it puts more pressure on the head gasket than just cranking the engine over will ever do.
Old 04-28-2010   #539
This site can now be named Failstyle.
Old 04-28-2010   #540
Hey guys! Good news! I just saved $130...but my car doesn't run...what a good deal!
WTB: used head gasket
