Old 09-15-2010   #521
Re: 91 Galant VR4
Thanks, the tranny shifts great. I will figure out a launch before it sees the track again, then I will try some no lift to shift stuff.
Old 09-15-2010   #522
santa
Boost Spike
santa's Avatar
Re: 91 Galant VR4
Looks great John! is it a little laggy in 1st off the line?
Old 09-15-2010   #523
Re: 91 Galant VR4
Not really, the first run of the day it spun in 1st. Then the 2nd run I need to launch about 1500rpm higher then I did, they just finish track prep so there was a lot more traction.
Old 09-16-2010   #524
Re: 91 Galant VR4
Goodluck on your future passes.
Old 09-18-2010   #525
Re: 91 Galant VR4
The issue was not the EMS dumping the tune, but the one issue I set on before leaving the track. The 1/4 coil is toast, its the electrical connections and the base of the coil started to arc out to the mounting bolt. So I now have 2 replacement coils and the car should be at Cedar Falls the 26th for some more track duty. I will be working on the launch for the first few runs, then its off to break the record.
Old 09-19-2010   #526
428gt
Re: 91 Galant VR4
See ya there!
428gt is offline   Reply With Quote
Old 09-19-2010   #527
Re: 91 Galant VR4
^word.
What's the record btw?
Old 09-19-2010   #528
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: 91 Galant VR4
9.510 @ 148
Old 09-19-2010   #529
Re: 91 Galant VR4
^HUH?
Old 09-19-2010   #530
MustGoFaster
Re: 91 Galant VR4
^HUH?
The fastest 1/4 mile time for a GVR4 is a 9.510@148.87MPH set by Adam Wilson.
Just answered your question in the post above mine.
Old 09-20-2010   #531
Re: 91 Galant VR4
Nice, I'm looking forward to see that record getting broken this weekend.
Old 09-27-2010   #532
DSMPARTSGURU
Keeper of the lost toys!
Drives: 1977 pinto,1994 farm truck, 04 4-door mustang
Send a message via MSN to DSMPARTSGURU
Re: 91 Galant VR4
thanks john... for letting us park in your pit and help out when it was needed...
hope next time out goes better...
wookie
CHRIS
Wayzata Nissan
DSMPARTSGURU is offline   Reply With Quote
Old 09-28-2010   #533
Re: 91 Galant VR4
I ran at Cedar Falls this weekend, It all came down to track prep, I knew what RPM I need to launch at to get the 60' and 1/2 shift where they need to be to get the 9 second pass. But the track had no prep, so it just spun with a little wheel hop. Then I tried lowering the launch RPM and tire pressure, I ended up with a 1.73 60', but it did not shift into 2nd, so it was a bad run.
My last pass of the day I upped the boost a hair, cooled the W/A down, lowered the tire pressure again and ran another low 10. 10.11@149mph, I was 2mph slower in the 1/8 vs my Rock falls run, so the traction in 1st/into 2nd was not there.
I looked over the logs and I could see the lack of traction, but I was happy to see my shifts averaged a .250 seconds, and I nailed the shift points with in 100rpm of 9500rpm on each run, my last run it got up to 9500rpm in 4th, so I may need to up the rev limiter a hair.
The day was cut short again, the radiator started to leak, so I cut it off to fight another day.
Old 09-28-2010   #534
Re: 91 Galant VR4
sweet jeebus, still some badass mph on that sucker!!
Old 09-28-2010   #535
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: 91 Galant VR4
holy crap 140 trap speed that is insane. are you done for the year?
ლ(ಠ益ಠლ)
Old 09-28-2010   #536
Re: 91 Galant VR4
Originally Posted by awd-drifter View Post
..140 trap speed ...
149mph, on E85, also the highest trap in the Galant VR4 that I know of. I plan to be at Rock falls on October 9th for the last time this year.
Old 09-28-2010   #537
awd-drifter
'2of9'
Re: 91 Galant VR4
haha. i missed the typO! apparently it is. I've looking around the internet/youtube and it seems that you have the fastest trap for a gvr4
ლ(ಠ益ಠლ)
Old 09-28-2010   #538
Re: 91 Galant VR4
Good luck in October!!
John, have you looked at trying to setup the AEM traction control? With the trac prep issues, perhaps limiting the power in 1st and 2nd to the limit of the traction will help you fix the short time.
Let me know if you want help.
Old 09-28-2010   #539
Re: 91 Galant VR4
That will be next year, right now it has a ball/spring MBC.
Pending temps with the good track prep on the test and tune days at Rock I should be able to get the 60' down to the 1.6 it needs to be. The hand break helped a lot with getting the launch, I will also setup the 2 step and the no lift to shift, I looked over the logs and the engine likes to free rev when I shift, I see where I shift at 9500 but the motor keeps going. In the logs the motor got to 9950rpm between some of the shifts.
I thought they were going to do track prep at the house of hook, if I knew they were going to do no prep I would have waited and gone to rock falls for a test and tune. Next year on QTP tires I might have better luck with less track prep.
Old 09-28-2010   #540
Re: 91 Galant VR4
Any idea what would cause that?
