04-29-2010
#561
Re: Swifty's never-ending project thread!
flips McGee, I love it!
Originally Posted by Murlo26
Originally Posted by turbotalon1g
04-29-2010
#562
Boost Spike
So, how did the old gasket look? Could you see the point of where it was leaking?
04-29-2010
#563
lol
#564
Drives: E36
x2?
04-29-2010
#565
It seemingly looked from the timing side when it was on the car, but once it was off, and coolant all over, the copperspray just kinda went everywhere I guess. I just cleaned all surfaces off, and threw the new one in. Also made things much easier to pull the studs out this time, so i don't worry about the washers all falling off.
#566
Walls need hugs too
To bump this for Swifty's banned ass, he went through all that and it ended up being the water pump. Was still a good idea to get that gasket out of there anyway, but that wasn't the issue.
Originally Posted by Trogdor
05-02-2010
#567
We told him to check that first... haha
05-02-2010
#568
wow, why wouldn't you check the easiest/cheapest thing first.
05-02-2010
#569
At-Least-It's-White-Again
Why would someone want to do that?
'04 Honda Ricer: stock
05-02-2010
#570
Ahhh, I dont believe he has it fixed. He resealed the water pump and its still leaking.
I still believe his headgasket isnt sealing. I wanted to check his head and block with my straight edge before he put his new head gasket on but it was too late, he had it all together.
20g Mafia
05-02-2010
#571
Now he thinks its his weep hole of the pump.
20g Mafia
05-02-2010
#572
weep hole? is that like a pewp hole? lol
Originally Posted by scheides
05-02-2010
#573
Walls need hugs too
Water pumps have a little hole that'll drip coolant. It's normally a very small amount, no more than a drop each time you run the car. Don't ask me why, I just know it's there.
05-02-2010
#574
Drives: 2004 Corvette M6 F45
The only reason coolant would come out that hole it is the bearings in the pump are shot. Get a new pump and tune the dumb thing.
Is that all thats left to be done?
05-02-2010
#575
I'll be tearing it apart YET AGAIN tomorrow after work and replacing it with a pump Chad (black rosenova) is giving me that has less then 4,000 miles on it, along with another dumb paper gasket, and a THIN coat of rtv to get it to hold to the pump while i put it in place. I double checked the freeze plug on the side of the head..no leaks. Nor the teflon paste coated allen plugs behind the cam gears on that side too. No other leaks on the car, besides some stupid shit on this side. It took a damn day to get the hg done, then the water pump gasket done, and it was just fine, no leaks when I ran it in my garage, while others looked over it with me. Only started this issue when I was driving to and from cars n coffee yesterday morning. Timing belt and that side is covered in coolant..retarded.
#576
wants to kick mark
Drives: Battery with wheels
This is no longer true on new water pumps, they are designed to release pressure to save the seals.
05-02-2010
#577
Let me know if you need a hand man. I want to see this thing out n about, and could lend a hand if you need.
05-02-2010
#578
Thanks bud. I won't make ya drive down from blaine though. I just need to sort it out. Once I know the issue, fixing isn't hard.
#579
Replaced the waterpump, and saw the oil seals for the camshafts were also bad, so I replaced those from ones Kerry gave me (thanks a ton bud!). Seems to have fixed the issues..true test will be driving it to the gas station to fill it back up with new fuel. I also tentatively set up a dyno date with Shane..May 20th, 2pm. Hopefully all goes well!
#580
Awesome dude!
