Old 01-26-2004   #41
FAL Twinline for the Eclipse. Has it's own shroud assembly. Only stick out 2 5/8 inches from radiator. I have 'em, love 'em.
Old 01-26-2004   #42
Spal and Trimline fans are also nice.
Old 01-26-2004   #43
I am sure the knock problem has something to do with carbon build up or that the car wasn't warmed up enough. I had excessive carbon buildup on my pistons and whenever I punched the gas I would build a high knock count untill I let off. If I hit it again right away the knock would be gone. I tried carb cleaner through the pcv valve and it didn't help much (although I could see carbon bieng burned off through the exhaust). I pulled the plugs and sprayed 2 cans of MCCC in and let it soak overnight. Car was fine afterwards. They were not small counts of knock I was experiencing though. Would usually get to 43 counts.
Old 01-26-2004   #44
car was warmed up and actually running on the high side. 213 coolant temps.
