Old 02-08-2007   #1
Toms Project...
Ok so heres the synapsis (not sure on the word usage) of what im planning for my car, what the Goals for the build are, and what parts i have and will be ordering.
Table of Contents:
Chapter 1...... Planning is everything
Chapter 2...... Goals for the build
Chapter 3...... Status On Current parts and parts to be added
Chapter 4...... Estimated time when Eclipse will be ready
Appendix A.... Pictures
Chapter 1
Planning is Everything
When i was a wee lad... just kidding. The plan for the car is simple, a) Get it running, b) Keep it running and c) Make it as fast as possible in the budget i have.
This time around i am going to make sure i have completly happy with the setup before i start driving, meaning that everything that needs to be taken care of will be.
Before the synchro went out in second, the car had no speedo because in taking out and putting in the tranny 5 times in 2 months the 4th time it was taken out the speed sensor got caught on the motor mount and snapped.
The other issue i was having is that i didnt feel like the knock sensor was working properly due to the amount of knock i was reading on dsmlink. but also when i took everything apart i accidentally pulled the wire out of the knock sensor.... oops.
Chapter 2
Goals for the build
Goals are the same as when i first got this car. This car will be used as a daily driver/Race car for Drag Racing. I would like to see over 500 FWHP (not hamster power). I would like to be able to throw the slicks in the trunk and drive to the track, put down some good times and then pack it up and drive back home.
The main thing with this build is i am not going to leave anything to chance. I am going to make sure that all of the parts are in good shape, that everthing will work as intended and that i get the most out of each part i put on. From Brakes to a Wideband, as long as it takes this will be done correct.
Chapter 3
Status of Current Modifications and Parts to be added.
Engine:
RRE 6Bolt block
RRE Stage 2 Head
2G Pistons 8.5:1
HKS Valve Springs
Ferrea Valves
NGK BPR7 Spark Plugs
Forced Induction:
PTE T3/T4 50 Trim Turbo
Tial 38mm External Wastegate
Ported Exhaust Manifold
Front Mount Intercooler
Magnus Intake Manifold
Custom Piping 2.5 in made by me.
Greddy Type S BOV
RRE Upper IC Piping
Fuel Management:
DSMLink
Magnus Fuel Rail
Fuelab 525 FPR
3/S Fuel Pump + rewire
680cc Injectors
SS braided Lines From Mesa Hose
Wideband o2 Sensor (Coming soon)
Drivetrain:
Fidenza Flywheel
ACT 2100 Clutch
Transmission Race Built by Dogbox Racing with Phantom LSD
Southbend Clutch (Possibility)
Baer or AEM Big Brakes (coming soon)
Other Points of Interest:
2.5" Turbo Back Exhaust
Magnecore Race wires
Tokico Shocks and struts
Battery Relocation to the trunk.
New Knock sensor (Coming Soon)
New Speed Sensor (Coming Soon)
New Throttle body (coming soon)
Possibilities include:
GM 3Bar map sensor
Bigger Injectors
2g Front fenders, bumper and headlights
Chapter 4
Estimated time when this project will be complete.
When is a DSM ever truely complete. This project however i am giving a good guesstimate of 1 month. But I am not going to restrict myself with a time frame. I would rather take the time to do it right then do a half assed job which will just cause me to use more time under the hood.
In past projects i have been in a rush to get things done for some race or track or dyno day. So with that said we shall see how long this actually takes. I have a lot of decisions to make still with this build but we will take it one step at a time.
Appendix A:
Pictures
ID:	4967   Click image for larger version
ID:	4968   Click image for larger version
