12-05-2007
#1
Re: Harmonic Tensioner Pulley BROKE OFF!
Back when I was young I was doing e-brake slides with my mom's car and everytime I did it it would trip the traction control and ABS lights since the front wheels would be moving, the rear wheels were locked, and there was nothing the computer could do about it.
Originally Posted by Murlo26
#2
E-brake drifts will make those lights come on every time.
12-05-2007
#3
Yup, as far as I know those bolts were never touched.....it is due for a timing belt job in another 14k miles or so, but other than that my car was 100% unmodded when I bought it. Then I corrupted it
12-08-2007
#4
Damn it, the bolts are seized in there....off comings the timing cover and belt....and another few days for another part
12-08-2007
#5
shitty
12-08-2007
#6
Chris, my cousin works at that Sinclair, I saw your car sleeping there last night.
12-08-2007
#7
Any thoughts on his mechanical abilities?
#8
They have a L1 ase cert mechanic there that should beable to do a timing belt correctly.
My cousin is just the gas station attendant/pump bitch. Fills air, fills oil, stuff like that (he is 18).
12-08-2007
#9
AWD4G64
That sucks man! You might as well pull the engine and toss in a freshly built 2.3l!
12-12-2007
#10
Got the car back last night. Dave at Golden Valley Sinclair worked on my car, I talked to him for quite a bit through the week and for about an hour last night when I picked up the car. I feel very confident in his abilities as a mechanic--it's not a Ferrari or anything (though it may be as fast as one?)! He pulled off the timing cover, pushed in the tensioner with the proper tool, and then yanked the pulley off and replaced it with a brand new one. Reset the timing and the reassembled. Not a full timing belt job but half way there at least. In the end I probably could have done it myself, but if anyone knows what happened at work the day before this happened, you would not want to deal with it either!
Here's some pics of the pulley, if you look closely you will see how the sheared off bolts got tweaked and goobered up the outside edge of a lot of the holes. The guide pin is gone as well, obviously left violently.
more pics here: http://www.scheides.com/gallery/evotimingpulley
I'll be doing a compression check and tossing it on the dyno here soon, I'm sure everything is dandy, the car runs like a top!
12-12-2007
#11
Now i too have Janine's phone number! BWAHAHAHHAHHAHHAA
#12
Wow, that pulley hung on for quite a while after the balancer bailed. That is quite a bit of damage to the bolt holes. Hopefully the main bearings are ok with all that imbalance that was going on. If not, stroker time!
12-12-2007
#13
Yup, I think everything is fine. I'll do an oil change and compression test for grins, but the car runs awesome. And JET yes you are right!
12-12-2007
#14
The Newbie
Glad everything is back in order!
2006 Mitsubishi Eclipse GT
12-28-2007
#15
Changed the oil the other night and my oil filter has a few good dings in it:
I sent some oil off to blackstone just to see what they say about it, but I am sort of considering myself lucky for now, the car drives just dandy....put about 800 miles on it since getting it back together and no problems yet.
12-28-2007
#16
And I'm the pussy who wants to put another undertray on.
Originally Posted by Tachyon
12-28-2007
#17
Dont these come from the factory with an undertray? I would think even a shitty plastic one would deflect some of this stuff.
12-28-2007
#18
Smells like cat poop
damn! you need to stop snow drifting
those are some pretty severe hits it took. good thing it didnt split open.
12-28-2007
#19
They do, but a lot of people remove them since they are a real PITA.
#20
I WANT an undertray, the stock one would not have blocked this. It does not reach back past the front of the block; the oil filter is completely exposed. I'm looking at this undertray that buschur is selling now, it goes back past the block and all the way to the wheel wells.
