Old 02-19-2008   #1
streetTERROR
streetTERROR's Avatar
4G63 custom timing gear covers
Some people have been asking about the timing cover I have on my car from photos or whatever. I just custom made them at my buddy's shop, I have blue-prints made up from the stock origonal one and just tweaked it a little. Right now I only have one made from SS and polished it up a little, and another one from steel and had it powder coated a fine wrinkled black. The SS one fits, but could use new mounting tabs welded on, its not a perfect fit, but its on..... and it doesn't have the little bump out off the back end to fit over the plastic/metal front engine cover. ( I just took a wizzer and shaved it off the back of the block to get it to fit. The black one fits real nice and has that extra welded tab for the back bolt and fits with no modification. I've seen polished ones off ebay selling for $100 when they even have them, and I know they make clear plastic ones now for $100 also, molded straight from stock ones. Well I'm asking for $50 each, your choice if interested. I can't really make them out of aluminum right now, they are limitted on times they use the aluminum spool gun. Plus they don't use aluminum all that much so it's harder to get ahold of and weld or tig up for me. If you really wanted an aluminum one really badly I probably could get one for you for like probably $100 just because it would most likely have to be tigged (to the best of my ability if you wanted pretty welds)(I'm not a welder, but can do it) or I could grind the welds smooth if I were to use the spool gun, and most likely you would like it polished, so... that takes a little bit of time to do.
But $50 each of the ones I have now...
Nick Phelps
1993 Talon TSI AWD
streetTERROR is offline   Reply With Quote
