Old 07-05-2009   #41
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: The new setup for spring!
Got this video of my car after MAP.. Nothing special of a video but its something.
http://www.youtube.com/watch?v=0iYi6zleeDc
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-05-2009   #43
GsXtUrBo98
GsXtUrBo98's Avatar
lol its fine....
98 GSX (built)
03 BBY EVO dd
Old 07-05-2009   #45
GsXtUrBo98
GsXtUrBo98's Avatar
It only does that when I just get done driving it and its hot... Its not tuned yet and takes a little bit more... otherwise it starts right away..
98 GSX (built)
03 BBY EVO dd
Old 07-05-2009   #46
Looking good now get it tuned and post up the numbers!
Old 07-05-2009   #47
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Yeah that's normal for a DSM to start like that during a hot start, my GSX did the exact same thing and it's very embarrassing when there's a hot chick around and you're trying to act balla in your 2G.
Looks good dude, get it tuned!
2010 Evo X GSR
1997 Subaru GC8 STi
Old 07-05-2009   #48
GsXtUrBo98
GsXtUrBo98's Avatar
LOL thanks and yes It will be tuned on wed at 12 if I can get off my ass and get the last things hooked up and done! I'm taking a break from trying to hook up my 2 step on my car just because I'm not little and getting under that dash is the biggest B@T$# in the WORLD!!
Still need to put the radiator in and get the e85 and such...
I'm going tomorrow to have primo weld a 02 bung on my exhaust for my wideband, then I have to install that and my 2 step at the moment..
I changed the oil today and the engine finally has Mobil 1 10w 30 synthetic
98 GSX (built)
03 BBY EVO dd
Old 07-06-2009   #49
Chengy
Drives: EVO IX SE
Don't you work with Vandde?
Chengy is offline   Reply With Quote
Old 07-06-2009   #50
You need to do wiring under the dash for a 2-step on a 2G? Seems odd, as on a 1G it's a function inside Link that requires no wiring.
Glad you got her started!!
Old 07-06-2009   #51
GsXtUrBo98
GsXtUrBo98's Avatar
Yes I'm his boss
Ya you have to hook the wire from the clutch to the ecu Its more of a tap into the clutch wire... And thanks but I just ran into a problem today... My a/c fan that I have been using to cool my car when it isnt running is toast because of the heat... "wires melted"
98 GSX (built)
03 BBY EVO dd
Old 07-06-2009   #52
Chengy
Drives: EVO IX SE
Yes I'm his boss
Lol, I'm his buddy with the white 2g GSX. Glad to see you finally upgrade. ^.^
Old 07-06-2009   #53
GsXtUrBo98
GsXtUrBo98's Avatar
LOL thanks I hear your car is coming along aswell!
98 GSX (built)
03 BBY EVO dd
Old 07-07-2009   #54
Chengy
Drives: EVO IX SE
Yeah well, kinda lol... Needs some work but it'll do. Still gathering the new set up so yeah... I wanna see you run Vandde after Wednesday. Hope it all goes well with the tuning man!
Old 07-07-2009   #55
GsXtUrBo98
GsXtUrBo98's Avatar
Thanks but I think Im a little SOL because I installed the radiator and hooked up the slim fans so that I could run them both for cooling istead of one and one of them is kinda crapping out on me and only blowing like 40% so its still getting hot today......
98 GSX (built)
03 BBY EVO dd
Old 07-07-2009   #56
mike55112
mike55112's Avatar
Drives: 04 evo
It seems like your having way to much of an over heating problem. Maybe your water pump is leaking or just not working properly. You shouldnt be having that much of a problem after installing a aluminum radiator
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 07-07-2009   #57
Good luck that's all
Old 07-11-2009   #58
GsXtUrBo98
GsXtUrBo98's Avatar
I'm still overheating!!
I put spacers on the hood
Removed the thermastat " MAP recomended it "
Bought a mishimoto radiator and cap
running mostly water and some coolent
have 2 mishimoto 12 inch slim fans running at all times
REMOVED A/C
Put a heat sheild on my manifold and turbo
I had a 180 thermastat in there before I removed it, All of this has been happening since I got it back from map and I dont know what else i could do.... I think it could be my water pump because I will let the car run for 20 min at idle with a funnel and a radiator cap with a hole cut into it to suck in when needed and nothing, but when I turn the car off it bubbles and sucks some in.... the I do it again but at the end it doesnt suck any in... next step I put the cap on and move my car like 25ft then look again and my hose's are callapsed!! what could this be?
98 GSX (built)
03 BBY EVO dd
Old 07-13-2009   #59
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
Collapsed hoses and hole in radiator cap are it. You gotta have pressure in the system for it work properly. I'd prolly switch to like a 50/50 mix instead of mostly water.
Old 07-13-2009   #60
GsXtUrBo98
GsXtUrBo98's Avatar
Thats what I had..
98 GSX (built)
03 BBY EVO dd
