Old 02-22-2011   #41
Re: Build your Dream DSM...
Originally Posted by 95tsi View Post
Lacroix's intake mani
I can help ya with that one
Originally Posted by DSM_421 View Post
Sell it, save up a few more hundred, get your self a better turbo. SCM61s spool like shit and make shit power on pump and probably E85 too.
Kerry made ~480 @ DB with that turbo, jus sayin'
Old 02-22-2011   #42
Ferrari F355
Red Targa Top
Tan Leather Interior
Old 02-22-2011   #43
Scheides hit the nail on the head with that list. I'd go with an FMIC instead of an SMIC due to the extra heat you'd see from the 16G on a 2.4L, but I can appreciate the sleeper logic.
If he is running E85 he wouldn't have to worry about that.
This was a careful decision. One, the car would probably run e85, mitigating the need for the FMIC, but still need the flow of a nice SMIC. Two, 1G's don't have the radiator openings over the FMIC that evos do, and this will keep the radiator nice and airflow-happy.
I'd consider a thin ETS FMIC like Halon did though, just because FMICs look cool
Old 02-23-2011   #44
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
DSM only? No GVR4s eh? lol
Here's what I'd love to have done to my Galant VR-4 (found this old list!)
Engine:
- 2G Head
- Ferrea Complete Valve Seal Kit
- Supertech Intake/Exhaust Valve Guides
- HKS 272 Intake/Exhaust Camshafts
- Cyclone Intake Manifold
- Mitsubishi MLS Head Gasket
- L19 Head Studs
- DSM Link V3
- Evo 8 Mas
- FP Race Manifold
- FP 18G6SL2 Turbo
- 1000cc injectors
- Walbro 255 fuel pump
Transmission:
- Shep Stage 2 (would love some sort of LSD equipped front and rear differential)
- 4 Bolt Rear
- AWS Removed
- ACT 2600
- ACT Flywheel
Interior (electronics, seats):
- Lancer Evolution 8 Front/Rear Seats
- Battery Relocation to trunk
Exterior:
- 3 Layer Repaint to original Belize Green
- JDM Galant VR4 Front Bumper
- JDM Galant VR4 Rear Bumper
- JDM Vented GVR4 Hood
- EDM Headlights
- Acura TSX Halogen bulb Retrofit
SUSPENSION:
- Polyurethane Bushings Bushings ALL AROUND
- 5 Lug Conversion
- 3000GT VR-4 4-Piston Calipers
- Slotted Rotors
- Stainless Steel Brake Lines
- Rustoleum oil based flat black undercoating
- Lancer Evolution Bilstein Suspension
- Swift Lowering Spring
- Rota Grids 17x7
- 235/40/17 Bridgestone Potenza RE01s
ლ(ಠ益ಠლ)
Old 02-23-2011   #45
Since money is not an obstacle here...
My dream DSM I guess:
1999 GSX in White
Engine:
2.4L 4g64
Wiseco 1400HD 10.5:1 pistons (E98 bish, I'll have a fuel tanker follpw me where ever I go )
Pauter rods
2g head
MAP Stage 5 porting, etc
3g lifters
Kiggly Beehives
Kiggly HLA pressure regulator
Ferrea +1 oversized valves
FP 4R cams
AEM adjustable cam gears
clear cam gear cover
A1 headstuds
Fel-Pro permatorque
no balance shafts
1990 OFH w/ Setrab oil cooler
Drivetrain:
Quartermaster twin disk
stock flywheel
Shep Stage 4 w/ 4 spider
Shep t-case
DSS 950HP aluminum driveshaft
DSS axles all around
B&M short throw w/ solid shifter bushings
solid mount/bushings on trans, diff, carrier bearing, etc
Power:
BW EFR 8374 turbo w/ T3 .83 A/R
Shearer T3 small runner manifold
3.5" v-band exhaust
ETS 4" FMIC w/ 2.5" piping
1g n/t throttle body w/ high pressure seals
Pushit 2.0 SMIM
FIC 1680's
DW/Aeromotive/Jay's 340lph pump w/ boost-a-pump
Golan -6 fuel filter
150 shot of nawwwzzzz
Evo 8 ECU with Tephra's goodies and Shane tune
Koyo radiator
FAL dual fan/shroud setup
Appearance/whatever:
Archer's custom OEM looking widebody 2g
Evo IX SE Recaro's
Suspension/wheels/brakes:
95tsi's suspension setup
black 17x9 RPF1's w/ 275/45-17 Star Specs (or slicks for drag racing)
Evo brakes w/ Ferodo DS2500 pads
probably missing a bunch, haven't had enough coffee this morning
Old 02-23-2011   #46
Tachyon
Tachyon's Avatar
Drives: Icarus
Here’s my build, it’s a completely different approach than most, but I really love low end acceleration and transitional Gforce more than dyno numbers!
Chassis:
1991 black and silver
Stripped, seam welded and then most interior returned for a stockish look
2600lbs
Engine
2.4 with lightened crank
12:1 compression pistons
Aluminum rods
Stock camshafts
Kiggly springs
Eaton TVS R1350 Supercharger air to water intercooled
Custom long tube header 4-1 with 28” primaries 2” diameter into reverse megaphone
Side exit exhaust, with limited baffling
Single Bosch 044
Fel-Pro permatorque
A-1 studs
Dry sump oil system with 12 qt capacity
MS3+ ECU
Drivetrain
Fidanza flywheel
ACT 2900 4 puck
Carbon fiber driveshaft
Evo 3 transmission with dog cut gears
Cusco Tarmac center differential
Quaife ATB front differential
HD 12 plate Max lock Evo 8 rear differential with upgraded casing
Shep Bulletproof transfer case
Suspension
Custom double wishbone A-arm setup
Custom spherical bearings for all suspension joints
Proflex Coilovers with remote reservoirs
Avid solid mounts
Brakes
Prodrive 8 piston aluminum calipers
13.2” front rotors
Full stainless lines
Hydraulic hand brake
Dot 4 fluid
Hawk DCT-70 pads
Tires and wheels
Volk TE-37’s 17”
P275/40R17 Hoosier slicks tread, pattern C
Fuel
VP Import (120+)
I also reflect Goodhart's sentiments about the coffee...
-Sebastian Vettel
Old 02-23-2011   #47
Ferrari F355
Red Targa Top
THIS, or maybe the 993TT from Bad Boys.
Dream dsm... lol I guess as I get older, I have bigger and better dreams.
Old 02-23-2011   #48
polishmafia
Smells like cat poop
polishmafia's Avatar
A black 2001 Galant GTZ with a carbon fiber FiD manifold and 120mm carbon fiber TB... with the trim that comes with an ash tray.
Old 02-23-2011   #49
I guess since we're adding that money is no object, than it definitely wouldn't be a DSM. It would be a matte black Lamborghini Reventon cab.
Old 02-23-2011   #50
I thought we were building DSMs?
If not my realistic dream car that i will have is a lsx FD, I've wanted a 911 since I was a kid.
Pagani zonda seems pretty pimp or ferrari xxx
Old 02-23-2011   #51
DSM_421
Old 02-23-2011   #52
My dream DSM:
Engine:
Swap in a geo metro 3 cyl engine
Electric Super Charger
Super Chip.
Super Max Flow Turbo Muffler
Body:
Super Max Drifto hyper uber front bumper
Ultra vibrato double dippin side skirts
Blitzkrieg tripple stacked massivenessfully rear bumper
3 legged workbench style wing.
The deepest dish wheels ever created
Pinkish purple tint all around with duct tape edging of the windows
paint the while car lime green with a pink pinstripe.
DONE. yeah baby that be pimpin.
Old 02-23-2011   #53
Wasn't me, my build would be in a dsm.
ok so maybe single turbo instead of TT. wait even better screw-type blower hahah
Old 02-23-2011   #54
My dream DSM:
Engine:
Super Chip.
Body:
Don't forget the orange rtv.
Old 02-23-2011   #55
Yeah, forgot, All interior coated with copper RTV.
Old 02-23-2011   #56
Or spun bearing mod.
Old 02-23-2011   #57
awd-drifter
'2of9'
does it glow in the dark?
ლ(ಠ益ಠლ)
Old 02-23-2011   #58
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
sure hope so, add some black lights and then we talking!!
Originally Posted by 311evo
Old 02-24-2011   #59
I already built my dream DSM
But.... I would have added.
Perfect paint job, in the stock color.
Wilwood/TCE front big brakes
17" Volk TE-37s colored black
Twin Walbros (or better)
Stock black leather interior
Candian seatbelts
And then drive the biatch.
