Old 06-23-2011   #41
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: TalonFiero - E85 powered Lancer Evolution IX MR
Originally Posted by PlanoEvo View Post
Jim what compression ratio are you running?
126-141-141-136 Apparently I don't assemble engines all that well.
9.0:1 pistons so stock basically.
Old 06-23-2011   #42
Old 06-23-2011   #43
shitty
Old 06-23-2011   #44
TalonFiero
moonshine power
TalonFiero's Avatar
shitty
Lol, that was 7K miles ago when I performed a compression test, motor runs pretty good. I wonder if they improved. hmm
Old 06-23-2011   #45
Well aren't IX numbers all goofy and low because of the MIVEC anyways? What is the factory spec?
Old 06-23-2011   #46
145 with stock cams and 8.8:1 pistons.
Old 06-23-2011   #47
TalonFiero
moonshine power
TalonFiero's Avatar
My comp tester would read 140 stock.
Old 06-23-2011   #48
cmspaz
Walls need hugs too
cmspaz's Avatar
I like my reassuring 180+ across the board.
Originally Posted by Trogdor
Old 06-23-2011   #49
Tachyon
Tachyon's Avatar
Drives: Icarus
It it makes you feel any better about the compression numbers, the last engine I build has 110 135 90 125 compression numbers on 9:1 Wiseco's (.24 ring end gap) yet it runs what it should in the quarter 'feels' 100%... I'm pulling my hair out as to why the numbers are so weird... all cylinders are equal with a leakdown test, and there is no smoke ever...
-Sebastian Vettel
Old 06-23-2011   #50
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
shitty
There's worse on this board. LOL
