Old 09-21-2011   #41
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Project XXX AWD WHP Or Bust!
Hey dude, are you still running the dual walbro setup? Do you have an aftermarket FPR? What is your fuel pressure at? You might be overrunning the mother loving crap out of your stock regulator, washing your cylinders and diluting your oil. I didn't see an FPR on your mod list.
Bearings don't really like a broken-down oil/gas slurry...
Style's automotive engineer
Old 09-21-2011   #42
blackawdtsi
Drives: 2G DSM
It's kinda hard to figure out what happened without actually seeing it.
From the pictures, it looks like a rod nut wasn't properly tightened. Which caused the nut to loosen then shear off the bolt and as the piston was pushed down, bent the rod and turned the piston. If the piston was suspended for 14 or so degrees at TDC just after the bolt sheared because of the play from having only one rod bolt, that would explain the bent valves.
singletracker, maybe you know something I don't. But wouldn't an overrun FPR just not be able to control FP and dump too little pressure and raise the fuel pressure at idle / low boost. How would it get into the oil?
Old 09-21-2011   #43
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Interesting you mention the dual fuel pumps. . .i was wondering wether i thined the oil out with the car running WAY rich. . .I bought 110 race fuel for a couple reason's A to kind of clean my valves cylinders ect, B to help prevent detonation since ignition timing needed to be taken care of and i knew i might have to drive it a distance to get tuned primarily to prevent any kind of knock. Now i had 15w 40 rottela instead of 5w 40 which dosnt make all the difference in hot wether . . .temperatures were at 70 plus degress at all times.
I must make a correction only 1 of the valves are bend. Once i removed the cam shafts all the valves sealed against the valve seats. Granted i wouldnt know for sure unless i leak down tested which at this point is futile. Judging from the damage on cylinder number 1 the other valves didnt touch the pistons.
I kind of am leaning towards blackawdtsi scenerio because the darn rod stud that pulls the nut on to the cap completly seperated. . .how that even works im clueless. We have MAJOR DESTRUCTION. . .over all i think my first guess of a loose rod must have been correct. . .
Old 09-21-2011   #44
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Singletrack, Yeah i still have dual fuel pumps in tank. . . i will definetly add a fpr to my modlist or before the next engine is assembled and goes back in car.
Old 09-21-2011   #45
93gtpeater
Drives: cbr 1000rr repsol
That motor was beat before you got on it. iam not suprised it blew up. Its a bummer but just keep at it. and tgis is what happens when you buy used parts shit can go break pretty fast sometimes.
Old 09-21-2011   #46
blackawdtsi
Drives: 2G DSM
That motor was beat before you got on it. iam not suprised it blew up. Its a bummer but just keep at it. and tgis is what happens when you buy any parts shit can go break pretty fast sometimes.
It sucks you had to learn the hard way. But unless you trust who it came from and they said it was without a doubt spectacular, clearance and torque everything important. I had to recently relearn that lesson also.
Old 09-21-2011   #47
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Thank you guys, especially for the words of encouragment regarding the trust part yeah it was from a very trusted source. They actually were there with me when it happen'd I hope to recieve some pointers, guidance ect during the next engine build from him. Heck with a little bit more posting and asking you guys, if i dont understand something the next season should be fun. Just gotta come up with a game plan now. I have my old engine sitting on the bench. Stripped down . . .the crank, water pump, oil pump, timing components and main bearings are the only thing left attached.
Old 09-21-2011   #48
s1ngletracker
Drives: A BMW
Yeah, i didn't actually look that closely at his failed motor pictures - it does look like a stud failure or some such thing. I was reading earlier in the thread and was like WHOA! twin pumps... dont' see anything about upgraded fuel regulation.
So when you run too rich, you can actually run so rich that you have just a ton of unburned fuel that slips past your rings and drains down into your oil pan. I've unfortunately experienced such a thing, my oil level rose and it smelled like gas. Needless to say I did like 3 oil changes in quick succession to get that crap outta there.
Old 09-21-2011   #49
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Perfect advice for the next rodeo get a FPR!... I wondered wether i would over run my stock fpr as well, once i started driving the car ect, but figured the pump probably wont crank that much pressure out . . .(Now that i think about it though with two pumps....didnt i technically dumple the pressure?) I Didnt give it to much thought as far as idle goes. I guess that stud might of been on its way out and something pushed it off the edge. Sad well never know what excactly did it. . .
Old 09-21-2011   #50
Whoa you were running dual pumps on the stock FPR? A single 255 is borderline over running the stock FPR at idle. I can't imagine how much you were over running it with a dual pump setup.
Old 09-22-2011   #51
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
It smelled quite rich, no clouds of unburned fuel or anything crazy like that though. Im not sure and wonder if maybe my small 560 cc injectors braced the volume slightly. Since i wanted to keep those in untill everything had been buttoned up then switch over to e85 with link installed Can we honestly say that the fuel could of caused this. . .because just before the last start up i put fresh oil in it again. . .
Another question: I have or had ...a key diver chip that was programmed for 1G piston refering to the stock 1g compression ration, my 560cc injectors ect. . . the engine however has/had 2G pistons. . .could the 7:1 or 7.8:1 1G compression ratio? Compared to the 8.something 2G piston compression ratio been a cause for such destruction? Doing some resarch tonight i came across that the timing maps for the 1G pistons are way more aggressive then the 2G pistons making tuning ect harder with a 2G piston set up and less room for error while tuning? This is a WHOLE NEW BALL GAME TO ME NOW. . .
Seems like all these small things could of added to the results i came up with. . .
Old 09-22-2011   #52
1g pistons = 7.8:1
2g pistons = 8.5:1
Old 09-22-2011   #53
s1ngletracker
Drives: A BMW
precisely. My single 255 overran my stock FPR...
However, unlikely that detonation caused your problem.
Old 09-22-2011   #54
You need a good FPR to run 2 pumps all the time, even some aftermarket ones don't handle 2 pumps at low load perfectly. A lot of people with 2 pump systems have the second one come on at 15 psi or whatever instead of running them all the time.
1G ignition timing with 2G or higher compression is not good. It depends on what was actually in the chip though and what kind of boost the tune was meant for. At 20psi with 8.5:1 compression you might only be able to get away with 11-14 degrees of timing on our normal pump gas, while the stock 1G timing maps would be trying to run 22-24 degrees. It probably would have been lower in a chip that had the timing maps modified though, because the stock 1G ignition timing doesn't work very well even on a stock motor 1G unless you are running low boost or race gas.
Old 09-22-2011   #55
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
1g pistons = 7.8:1
2g pistons = 8.5:1
Thank you goodhart ha i was almost close!
Now talking about the stock FPR im not sure if i excactly understand or if i have the right concept in mind. The purpose of the fpr is to keep a constant pressure of fuel. . . the less fuel you move through a specific diameter of pipe in our case fuel lines the less pressure. . .the more fuel (dual 255) the more pressure. In the case of a dual 255 set up to much fuel for the stock fpr to handle? Now where does the problem come in the excess fuel not being bled back in to the tank. . .How excactly does this result in overfueling?
I thought the injectors are only open for a certain amount of time or duration, now is the over fueling caused by the high amount of pressure squeezing more then the normal amount of fuel into the cylinders each time the inectors fire. . .or do they leak how excactly does this work? Im just curious. . .seems to be a simple concept yet i overlooked it and could, more like did contribute to the problem for all i know.
Moving on to the compression ratio @ shane the timing info would that only apply when putting the engine underload/boost not during idle? & Could one so to say pull on boost given the psi stated cause engine failure? Because if yes then perhaps that could of been the reason as well. What i would like to know is whether this dilema was caused due to a mechanical failure (loose bolt, interference ect) which im really leaning towards or Electronically (timing, fuel pump, the other not so obvious possibilitys)
Old 09-22-2011   #56
s1ngletracker
Drives: A BMW
It's really hard to say what caused the failure. I can't really even see whats going on in your pictures. Get it taken apart and take more pictures.
To answer your fueling question, yes, the increase in rail pressure is due to the orifice in the stock FPR being too small to bleed off the excess fuel flow from the dual pumps and causing pressure to build. This makes your car run too rich. What Shane was talking about regarding low load, at idle or otherwise low engine load is when the most fuel is being bled out the FPR and returned back to the tank as your engine requires little to run. The pumps are operating at full output all the time, regardless of your engine RPM or load.
Old 09-22-2011   #57
blackawdtsi
Drives: 2G DSM
This. There's a possibility that if there was enough fuel, it would get past the rings and get into your oil. However you would've heard spinning bearings followed by a loud deep knocking.
Old 09-22-2011   #58
Fuel rail pressure will go up when you overrun the stock FPR, most noticeable at idle/low load. At a higher fuel pressure, the injector will flow more fuel, hence the richer idle. I'm not saying that caused your problem, I'm just surprised you were running dual pumps on the stock FPR.
Old 09-22-2011   #59
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Well thank you guys for the input. Never hurts to ask for clearification
Old 09-22-2011   #60
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
He probably heard something like that as the engine block exploded. I have to say, holy crap you were running dual pumps on 560cc injectors on E85? I thought you werent supposed to go below 720's and even thats pushing it, and no fpr? You need the AFPR because your telling dsmlink that you have a base fuel pressure of 37psi so if it's not 37 then your going to have problems. Once again, holy shit you were running a stock fuel pressure regulator.
