Old 09-09-2004   #41
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Pull the tranny and put a thin washer behind the pivot ball.
'04 Honda Ricer: stock
Old 09-09-2004   #42
Enes
Enes's Avatar
or if you have tiny fingers and good tools you should be able to do it thru the inspection shield and the fork hole... might take same time and be more frustrating but beats taking the trany out
-E
Old 09-09-2004   #43
To check the pedal assembly, I believe all you have to do is push the cluch to the floor, take your foot off it and see if you can pull the pedal up higher. If you can pull it up furthur, then I believe the assembly is worn out.
My car hasn't been driven since something broke. Seems as if I almost have to kick the firewall to get it to fully dissengage. Mine is way the hell up there also. I am about out of adjustment. Good luck. Did you just replace the TOB?
Old 09-09-2004   #44
I didnt replace the TOB because I looked throught he inspection hole and it looks intact and doesnt make any more grinding noise. The noise I heard was actually the slave rod scraping against the fork in that little divit.
I tried pulling on the pedal after it is fully let out and it doesnt move so does that factor out a bad pedal assembly? As soon as I move the pedal down even in the play section the master rod does move inwards and then once you reach pressure it is just in further... so its like there isnt enough pressure in the system to have full pressure throughout the pedal travel.
Also I bought a mitsu slave cylinder and the bleeding screw is so small and in the way that I cant fit any size 10 wrench in there. I had to bleed it by just using a long socket over the fitting and just bled it by letting it drip out of the fitting. Can air get sucked back in at all? We push the pedal down open the fitting, let it drip and then close it and release the pedal.
I tried switching slave rods from the 1/4 longer to the stock and that made it worse.
You really think that pivot ball is the problem? And no I dont think you can even get to it through the inspection hole.
TIA
Old 09-09-2004   #45
I could fit a wrench on mine even with my scattershield in the way. I did it from the top of the car. Air cannot be sucked back in unless somone takes their foot off the clutch while the vavle is still open. Try bleeding it from the top and use a hose on it. Then you can see if air bubbles are still coming out.
Old 09-12-2004   #46
Well no luck.... I tried eveything short of taking the tranny off and nothing helps.
SO.. tranny comes out this week if I dont sell it before that. GRRRRRRRRRRRRRRR :headache: :headache: I quit.
Old 09-12-2004   #47
Sticky Rice
Sticky Rice's Avatar
Send a message via AIM to Sticky Rice Send a message via MSN to Sticky Rice Send a message via Yahoo to Sticky Rice
Originally posted by 92tsiawd84@Aug 24 2004, 08:32 PM
OK, I went out to bleed the clutch. Before bleeding it, my friend noticed that you can get it into gear with the car off except 5th gear. While bleeding the clutch, the clutch pedal would get stuck to the floor after I close the valve. There would still be plenty of fluid in the resivior. We repeated the process untill the bubbles went away. After doing it, the trans could get into 5th while the car was off. There still feels like a lot of slop in the pedal though. We started it and it still will not go into gear. Everytime he let off the clutch (after I shut the valve) it remained stuck to the floor. The repair manual says that you should slowely release it but it gets stuck. What am I doing wrong? Could it have something to do with the slave cylinder?
I had that problem on my 97 GST.. Took it in to the shop, turns out that both slave and master cylinder needed to be replace. :goodluck:
2007 Kawasaki Ninja ZX6R
1997 GST Spyder
1993 Civic H/B
1993 Toyota 4Runner
Sticky Rice is offline   Reply With Quote
Old 09-12-2004   #48
520Talon
Just to through it out there... Maybe the rubber hose had a partial failure. All of the heat cycles ext maybe weakend it and it bulges out a little when you start to push it. It happens to brake lines. Time to upgrade to a stainless, maybe.
520Talon is offline   Reply With Quote
Old 09-12-2004   #49
I gots the stainless :cry:
Old 09-12-2004   #50
Originally posted by EclipseTurbo@Sep 12 2004, 11:44 AM
I quit.
Me too
Old 09-12-2004   #51
Kougar
Drives: 06 RSX
Originally posted by 92tsiawd84+Sep 12 2004, 09:53 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (92tsiawd84 @ Sep 12 2004, 09:53 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-EclipseTurbo@Sep 12 2004, 11:44 AM
I quit.
Me too [/b][/quote]
I said the same thing almost 2 months ago :jammin:
Old 09-12-2004   #52
I am talking about DSMs.
Old 09-25-2004   #53
Well I got my transmission out today. To me there doesnt seem to be anything majorly wrong with it at all.
The fork looks ok, some wear where the pivot ball goes but nothing drastic.
The ball is shiny and only has 1 little rougher spot but its still round.
Im stumped, next the pedal assembly comes out.
