Go Back   MitsuStyle > Hosted Support Forums > Elite Autosport
Old 04-13-2005   #41
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: Dynoed my car before I broke it.
Originally Posted by Raptor
Expecially that fast a change in RPM, not many setups would ever handle that. Did the cam follwers come apart or just come off? Maybe it's time for the switch to Russ Cox mode instead of switching drivers, least then you still get the fun of all your labor.
Russ Cox? Swanny has been talking up the auto around you too?
Old 04-13-2005   #42
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
What type of fuel management / measurement strategy are you using? N Alpha, Speed Density, Mass Air Flow? and if you are using a MAF whitch one? Oh and that Q45 TB kicks ass.
Take her to the limit!
Old 04-13-2005   #43
Raptor
ConArtist
Raptor's Avatar
Ask Russ how many parts he still replaces even with an auto.
Steve
I wasn't saying it so he would save tranny parts.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 04-13-2005   #44
Raptor
ConArtist
Raptor's Avatar
I knew of Russ Cox long before I knew of Swanny. But either way, of course he does.
651-488-7774
Old 04-13-2005   #45
LightningGSX
Hellbound
N Alpha/Alpha N would be worthless on a boosted vehicle.
-Nulli Secundus-
Old 04-13-2005   #46
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
That was a joke.
How about a Granatelli’s Bullet Converter?
Old 04-13-2005   #47
Speed density, no MAF, 5 bar map sensor.
Old 04-14-2005   #48
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
damn! those are insane numbers man! Insane! Love it dude. When's it going to be ready? Wanna see that DSM run at Rock Falls sometimes. Sweet.
ლ(ಠ益ಠლ)
Old 04-14-2005   #49
Bow down to the Master Blaster.
Great to see the numbers, sorry to hear about the damage.
Old 04-15-2005   #50
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
You know that other people are use to getting beat by DSMs, but the sweet smack down, that you can do with that car just brings a tear to my eye, and to the person you beat. One more thing,Do you have an “RS” sticker?
Old 04-15-2005   #51
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
No but he has a powered by honda license plate frame.
Old 04-15-2005   #52
JiggahMan
Does that just bolt up to DSMs?
JiggahMan is offline   Reply With Quote
Old 04-15-2005   #53
JiggahMan
The Q45 throttle body, I mean.
Old 04-15-2005   #54
Most likely you dont need it.
Old 04-15-2005   #55
No, you wouldn't want to use it, unless your running 3" or bigger intercooler piping also. The butterfly is about 80mm, the inlet OD for a couple is around 85mm. The MKIV Supra guys have started to figure out that they can use them also, so they might start getting more expensive, but I paid $50 for mine. I am hoping it is a bit stronger than the BBKs and Accufabs that tend to break a lot on high boost cars.
Old 04-18-2005   #56
520Talon
Shane, sequential shifter. No more missed shifts and you get to them quicker. The basic ones are way simpler than I would have thought. They use a drum and ratchet to click the gears and have groves cut on a plate or drum to work the factory cables to where they would have been on a h- pattern.
P.S. Wow on the numbers and to bad on the run.
520Talon is offline   Reply With Quote
Old 04-24-2005   #57
Worked on the car some this weekend. Pulled a lot of parts out of the head, but the valves don't look too bad. When I pulled the transfer case off, the output shaft pulled out of the tranny a bit and started pouring our fluid, so my little aluminum TRE VC eliminator either broke or fell off. There were some more rocker parts in the oil pan as expected. I didn't feel any signs of spun rod bearing from wiggling the rod caps. I pulled one of them off and the bearing looked ok, some of the white coating had worn off, but that is something I would expect.
Old 04-24-2005   #58
Well, hopefully the lower end is ok. I take it the head isn't off yet? Hopefully those valves turn out ok too! I want to see that thing back at the track sometime this summer.
Old 04-24-2005   #59
Shane what were you running for springs and retainers? Was anything ARP besides your head studs?
Old 04-24-2005   #60
I have Crower springs/retainers, I only rev to 8500, except when I shift into the wrong gear, so I haven't need anything crazy for springs.. The rods came with ARP rod bolts.
