Old 03-24-2017   #661
So what was originally wrong with the 2 piece ones? They just have abnormal wear?
Yup. They overheat and warp, even with street driving.
2014-2016 Z51's included these stupid Band-Aids to supposedly help:
https://www.edmunds.com/chevrolet/co...ing-rings.html
I'm chalking this rotor design up as a failed experiment into making a poor man's 2-piece rotor.
Old 03-24-2017   #662
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Interesting. You'd think on a car at that price they would be able to give you legit 2 piece rotors. Isn't that part of the z51 upgrade, better brakes?
Old 03-24-2017   #663
Yes, the Z51 gets better pads & rotors (same Brembo calipers), along with brake cooling ducts & guides. The revised 2017 Z51 rotors are still an upgrade over the base Stingray rotors (larger + slotted). If you want true 2-piece rotors though, step on up to the Grand Sport or Z06.
Old 03-24-2017   #664
dogwhistle
dogwhistle's Avatar
I assume GS/Z06 rotors are different in overall dimensions, thickness/diameter?
-Adam
aneujahr@maperformance.com
Old 03-24-2017   #665
Front yes, rear no.
Old 04-04-2017   #666
Here are a couple pics I took last night after fully detailing the car over the weekend.
I should probably do another round of touch-ups with the Doctor ColorChip kit before it goes bad; I think they claim it has a shelf life of about a year.
Old 04-04-2017   #667
Looking good!
Old 04-04-2017   #668
...Powestop Z26 pads which should be quieter and dust quite a bit less (so far this seem true). Initial bite doesn't seem as good, but I'll let them heat cycle a few times and fully get bedded in before making too much judgment on them.
Now that the pads are broken-in, initial bite has gotten better, but still not quite as aggressive as the factory pads. Overall stopping power is great though. I stood on them doing about 130 down the Tollway last night and they hauled the car down very nicely and sent the leftover pizza in the trunk flying As long a they stay low-dust and silent, I will be very happy with them for street pads.
Old 04-04-2017   #669
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Looking good! I like the carbon badges.
Old 04-04-2017   #670
So fresh and clean!
Old 05-09-2017   #671
I found these interesting, my friend just did them last night. This car is similar to mine, Z51, but does have the automatic transmission and is bone stock. Regardless, I was impressed!
Old 05-09-2017   #672
Those Vettes are supposed to have a really good balance. Get into the driver's seat and see where it goes.
Old 05-09-2017   #673
Impressivly balanced from the factory!
Old 05-09-2017   #674
Mmmmm, Corvette.
Old 05-31-2017   #675
So AFE just released these...
Primary cat-delete pipes aka downpipes (with or without 200-cell high-flow cats). Along with their 3.0" catless X-pipe (I have Borla's 2.75") they're claiming gains of +24/+24 on the Z06. My gains considering I already have the X-pipe, maybe +10whp? Regardless, intriguing product that got my attention. I need to figure out of the high-flow cats they use are enough to prevent a CEL or if it would need to be tuned out like any of the various headers on the market.
http://afepower.com/afe-power-48-341...nnection-pipes
Old 06-01-2017   #676
I heard back from AFE and they say its about a 50/50 chance of getting a CEL with these. With the catless X-pipe, they saw +18whp on the LT1 is the +10 mentioned above is likely accurate considering I already have the X-pipe.
Old 06-01-2017   #677
Those look quality. Wonder if you can work with them to get a set, and if they throw a CEL get a refund since it's 50/50.
Old 06-01-2017   #678
I tried to angle for a discounted pair to be a test subject on the forum but no luck. I could always do the spark plug non-fouler trick if needed I suppose.
Old 06-01-2017   #679
Can't you just eliminate that CEL with a custom tune?
Old 06-01-2017   #680
Murlo26
Murlo26's Avatar
Just get a tunez dude
