Old 10-03-2012   #701
Re: GheyrodX - bigger, fatter, gheyer!
RED = MAP ported exhaust manifold (SPC coated)
BLUE = MAP short-runner tubular exhaust manfiold (SPC coated)
Old 10-03-2012   #702
Crazy you make that much power on 93, badass.
You think the short runner might perform better with a bigger turbo or more RPM?
Looks like the ported does perfect for everywhere on a street car.
Old 10-03-2012   #703
Most likely. The only place the short-runner showed an advantage was in the upper RPM band. With these results, I'm going to stick with porting as my recommendation for stock and smaller stockframe turbos.
Old 10-03-2012   #704
Tachyon
Tachyon's Avatar
Drives: Icarus
Looks like an intelligent decision.
-Sebastian Vettel
Old 10-03-2012   #705
I agree, thank you. I should have just done the MAP ported from the beginning...
BLUE = PPI "extreme" ported
RED = MAP short-runner
GREEN = MAP ported
Old 10-03-2012   #706
Damn! That or you should have gone to a long-runner instead of the short-runner mani!
Old 10-03-2012   #707
Ported stocker looks like a win to me. Not only dyno chart wise, but also keeps the setup simple / OEM under the hood which is always a plus in my book.
Old 10-03-2012   #708
I agree completely; plus it's much better for heat management, less risk of cracking, etc.
Old 10-03-2012   #709
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I compared all of these manifolds, the short runner was huge gains over ported stocker at ~550whp, baseline was like 525, and with short runner it was 550ish.
I'd post it here but not the right thread.
I agree though, on a stock turbo car the ported manifold is king.
Old 10-03-2012   #710
I agree, with an EF4 and big power I think the tubular will dominate. We know how they compare on the EF2 and EF4...wonder how they'd stack up with an EF3?
Old 10-03-2012   #711
Murlo26
Murlo26's Avatar
^Well my testing was on the FPblack, but I get what you are saying
I wouldn't ever run the short runner personally though, I like American welded things. But the design is solid.
Old 10-03-2012   #712
My friend down here does has a MAP long-runner just sitting in his garage...
Kidding kidding, I'm done testing out exhaust manifold setups, I've made enough changes to that! Now if MAP were to place a Rev2/3 ported intake manifold in my lap...
Old 10-03-2012   #713
Mike Rizz, said that is one of his reasons from getting away from a tubular manifold, he had 1-2 of them and he said the engine bay heat was terrible and they would fade/ruin his clearcoat on his CF hood.
It's making me want to stay with the FP cast manifold I have.
Old 10-03-2012   #714
Ceramic coat it and call it good...maybe do a little cleanup porting too?
Old 10-03-2012   #715
Murlo26
Murlo26's Avatar
The OEM manifolds ported work very well, they are a bit restrictive for sure, but spool up is always a good 400-500 rpms better with them and heat is managed better and you get to keep stock heatshields on the Evo X anyway.
Still made 570whp+ on the FPblack with one, it held it back for sure but was adequate.
Both have great benefits.
Old 11-15-2012   #716
New Girodisc S/S (orange) brake pads on the way...I don't need them yet, but they offered me an introductory price that's too good to pass up.
http://forums.evolutionm.net/evo-sal...-s-s-pads.html
Old 11-15-2012   #717
Those sound awesome.
Old 11-15-2012   #718
I hope so. I had terrible luck with their Magic pads (twice) so this is my final attempt at running this company's products. My current Stoptech pads are probably still good for at least another 10k miles so I'll probably swap these new ones in sometime next spring.
Old 11-15-2012   #719
^Sweet I have about the same amount of miles left if not more on my car, but it's all good parts store stuff.
Old 12-05-2012   #720
Hmmm...what is this?
A second compressor cover you say?
Both covers have a 3" inlet for maximum airflow so that alone is a nice upgrade vs. the EF2, but we're also going to be testing standard vs. anti-surge to see how they compare. Stay tuned for data this weekend...
