Build the X 17 56.67%
Old 07-15-2010   #721
mlomker
*Resting In Peace*
mlomker's Avatar
AMS Spec JE pistons will be at DB tomorrow, just got word from AMS
I assume these are different than the ones on their website, since you said that these were coated. Were they more than Buschur's version?
http://tinyurl.com/27pg2nn
Old 07-15-2010   #722
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
They were more money yea...but its AMS, to be expected.
AMS said they have tested them up to 800whp on the X and they have used them on 1000whp+ builds on the 8/9. The AMS spec ones simply handle more power.
Not sure the exact differences, but here is some bullet points from the AMS website about the ones i got:
* Specially designed quench area that improves power and reduces the chance of detonation
* Annular pin hole grooves with double forced oil holes to prevent pinhole galling
* Taper lands to prevent scuffing
* Extra thick lands for superior ring groove support under extreme pressure
* 4340 taper bore, hard-chromed extra heavy duty pins for high strength and low weight
Taken from the AMS spec ones from the IX, should be the same features though.
Old 07-15-2010   #723
311evo
311evo's Avatar
Most aftermarket pistons will hold plenty of power, but detonation will kill anything.
Old 07-15-2010   #724
Murlo26
Murlo26's Avatar
True...but the AMS ones were in stock ready to go...I just want a car to drive while there is summer left!
Old 07-15-2010   #725
mlomker
*Resting In Peace*
mlomker's Avatar
Dave is so balla'
Old 07-15-2010   #726
Murlo26
Murlo26's Avatar
Originally Posted by mlomker View Post
Dave is so balla'
Hell ya! Got an oil cap and a pc'ed valve cover and all now...also an SSP coil cover too
Old 07-15-2010   #727
311evo
311evo's Avatar
Haha, anything by AMS though is usually the highest of quality though. I would have done the same thing, I feel your hurt (of missing a fast vehicle).
Should have stayed with the manley's. Then DB could have got mine done while you were waiting. :P LOL jk.
Old 07-15-2010   #728
mlomker
*Resting In Peace*
mlomker's Avatar
Hmm.
Originally Posted by Tephra
Put this into your 5268 (or 5269) xml:
<table name="30psi ASCOFF, SSTOFF Test Fix 0x00E9 -> 0x0100" category="Misc" address="53b0a" type="1D" scaling="Hex16"/>
Make sure it matches 0x00E9, then change it to 0x0100.
Flash/done/test
Old 07-15-2010   #729
I haven't read up on this fix yet. What exactly is it attempting to correct?
Old 07-15-2010   #730
mlomker
*Resting In Peace*
mlomker's Avatar
When you go over 30psi you'll get a whole lot of lights on your dash along with the 'ASC off' indicator. Your fancy drivetrain features will remain disabled until you shut the car off.
On a hot E85 tune this will get disabled on every drive (like for Dave). What's interesting is that this turned out to be the same fix for MR owners as well. The ECU would stop sending data to the tranny secondary ECUs and that'd cause them to go into limp mode.
The assumption is that this is a safety feature but obviously it was based on the power output capability of the stock turbo at that psi, anyway...
Old 07-15-2010   #731
I wonder if Mitsu chose ~30psi since that's near where the stock MAP sensor maxes out at?
Old 07-15-2010   #732
Murlo26
Murlo26's Avatar
Nice, did he post that just now, or PM you that?
Yea it's the stupid ASC light problem all the people running high boost get.
Old 07-15-2010   #733
Hmm.
Worth trying
Old 07-15-2010   #734
Murlo26
Murlo26's Avatar
Worth trying
I'll have Shane load that up on my car when its time for sure. That light was super annoying.
Old 07-15-2010   #735
mlomker
*Resting In Peace*
mlomker's Avatar
Another reasonable guess. Consensus is that it reads to 33. They haven't found the tables for going to a 4bar yet. I've got one of those sitting and waiting, as well.
Found that in SSP's thread on his MR. The fix is the same, apparently.
Old 07-15-2010   #736
Yup, its a 3.3 bar sensor. It's actually the same one that came on the JDM IX's. The "JDM" sensor I ran on my IX was actually just a an Evo X one I got from Brookdale Mitsu.
Old 07-15-2010   #737
You dudes let me know if you want to upgrade, I will happily take your old little sensors.
Old 07-20-2010   #738
Murlo26
Murlo26's Avatar
My new SSP clutch master cylinder finally shipped out today. My relay pack from the Mitsu TSB shipped from them yesterday so i should get that today.
Dropped my AMS front motor mount insert off at DB's carcraft tent on Saturday when I was there just in case by some miracle the motor was going to go in soon, didn't want to create extra work for them.
Man am I getting ancy...can't take it anymore!
Old 07-20-2010   #739
Murlo26
Murlo26's Avatar
EPIC NEWS!!!!
Just got a call from Forced Performance, my FP black is done and being shipped back to me right now, woo woo!
Old 07-20-2010   #740
Wahoo! Any other major parts you're waiting on? Sounds like its go time I'll have to take a peak when I'm up at DB on Friday...
Tags
