Old 06-29-2011   #761
Re: 91 Galant VR4
Yeah, that thing needs tires in the worst way. Nice runs!
Old 06-29-2011   #762
URV8SUX
URV8SUX's Avatar
Re: 91 Galant VR4
Hell yeah john get some better 60s but if it's going to destroy 3 gear like grove creek then just keep doing what your doing!
Are you going to forum wars?
Old 07-05-2011   #763
Re: 91 Galant VR4
Saturday the car did not spin at all, I launched at 6000rpm for the 9.6 run and it did not spin at all. I need to launch higher, so I launched at 7000rpm sunday morning but the it spun hard due to the cold track and my great tires.
So if the track prep is perfect and the weather conditions are perfect I think the car can cut a high 1.5 60'. that puts it at the 9.0/high 8 second range.
But if I want to cut good consistant 60' times I will need the QTP tires. Then I can think of sub 1.5 60', but not with this tranny.
On the street from a 2nd gear roll it does not spin, so for the rest of this year I will be on the tires I have, I think.
Sounds like a great plan, just need to get the perfect track day to drive down that record!
Old 07-12-2011   #764
Re: 91 Galant VR4
Well I am out for the track this weekend. I still have a mountain of safety items to take care of, and the tranny is not happy shifting into 3rd or 4th gear at high rpm at the moment.
The issue is with the solid hub twin disk clutch and shifting at 9800rpm have taken its toll on the tranny.
Lucky for me its an easy fix, but I need to drop and tear down the tranny. Here is a link to the issue, last time I was in the tranny it had broken springs in the 3/4 hub and was showing the mushroom problem a little.
http://www.jackstransmissions.com/pa...hrooming-rings
So I need to tear it down and see if the springs, which were new, are now broken and then tapper the synchro ring around the dogs to prevent the mushroom affecting shifting.
On a plus I drove the car to my parents house tuesday and saturday, I gave my dad and Ryan a ride. And drove my boat on the water for the first time in 10 years.
Old 09-26-2011   #765
Re: 91 Galant VR4
I did make it to the MAP dyno day, but just. I pulled the head off my car to replace some bent exhaust valves and drove it down there to see how the car did on an AWD DynoJet.
I replaced the 2mm oversized exhaust valves with 1mm over valves. I ended up lapping them in, which worked great and they sealed just fine.
We turned the boost down to 36psi and did some street runs on the way down there, everything looked good, if felt good on power for that boost level. We looked at the logs and made some changes, upped the boost to 40psi and the first run it miss fired a little and made just under 800AWHP at 40psi. So we added some timing where it was missing and the 2nd run was clean, 829AWHP and 554ft/lb at 40psi with a little less overall timing then it had when it was on the dyno early this year at DB Performance.
So we cooled the intercooler down and tried to up the boost again, shooting for 44psi, forgot to up the boost cut, fixed that and tried again, it missed a lot, and put down 860something.
At DB early this year at 40psi on the dyno dynamics it made 720 un corrected AWHP, and at the same boost level on the AWD Dyno Jet it made 829ahwp at the same boost, dang.
I figure a clean cooled down pull at 44psi the car would make low to mid 900's, which is right were it should be.
I should have pics and videos later this week, thanks Josh for helping tune and use your camera.
A big thanks to all the people that made this car possible: Ryan, Kyle, Josh, CP Pistons, Carrillo rods, Karl Ramm, KRAMM-LOX, Paul, Chuck at HTM, Shane at DB Performance, Jacks Trans.
Old 09-27-2011   #766
URV8SUX
URV8SUX's Avatar
Re: 91 Galant VR4
Holy cow john......
I thought all dynos read the same you that's what I was told.
You must have changed alot of things..
Looking forward to seeing you at CFR on the 9th.
Old 09-27-2011   #767
blackawdtsi
Drives: 2G DSM
Re: 91 Galant VR4
That's a crazy powerband for a 4202. I would think you'd have no problems digging into the 8s on slicks and the trans holding together.
Old 10-01-2011   #768
Re: 91 Galant VR4
The car was running great. Then on the way home the keepers on the #4 cylinder #2 exhaust valve blew out. The valve dropped and some damage fallowed.
Here are the pics:
I am headed up to work to clean up the back up block and pick up my parts to finish assemble the back up motor. Then I will pull the tranny apart to fix 3rd/4th gear shifting and with any luck I will be at Cedar Falls the 9th.
Old 10-01-2011   #769
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: 91 Galant VR4
Damn that sucks. Get it back together I was really looking forward to seeing it at cedar falls.
11.35 @ 120mph
Old 10-01-2011   #770
GsXkingGsX
GsXkingGsX's Avatar
Drives: 1997 Eclipse GSX
Send a message via Yahoo to GsXkingGsX
Re: 91 Galant VR4
Oh myy.... Secks.. Pure secks.
'97 Eclipse GSX
GsXkingGsX is offline   Reply With Quote
Old 10-01-2011   #771
Re: 91 Galant VR4
Damn. Good luck man.
Old 10-01-2011   #772
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: 91 Galant VR4
At least you got that neat paper weight of a valve! Haha. Sucks to hear about the car though :/
Old 10-01-2011   #773
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: 91 Galant VR4
Dam that sucks!
Amsoil Dealer
Old 10-02-2011   #774
Re: 91 Galant VR4
God that really blows man. Good luck getting it back together.
Old 10-04-2011   #775
Re: 91 Galant VR4
So the back up motor is a short block as of Sunday night. I have the head ready to bolt down, so when I get home tomorrow it will be a few more coats of copper spray on the head gasket, then I will tear the rest of the way into the tranny then bolt the head on before I go to bed.
Old 10-04-2011   #776
Re: 91 Galant VR4
Ugh that sucks but damn you are kicking ass getting it fixed! Keep going!
Old 10-04-2011   #777
badinblack
badinblack's Avatar
Re: 91 Galant VR4
That's gettin it done man. Good work.
Old 10-04-2011   #778
Re: 91 Galant VR4
Awesome, you do good work, and do it fast!
Are those stock 2-piece valves?
Old 10-04-2011   #779
Mark Leasure
Mark Leasure's Avatar
Re: 91 Galant VR4
Hey I was sorry to hear of the failure, crazy unfortunate. I hope to see you at Cedar this weekend. I need a partner in crime to beat up on all the V8’s that will be there!
Old 10-05-2011   #780
Re: 91 Galant VR4
No, that was a Manley 1mm over exhaust valve. The stock keepers gave up the ghost and the valve dropped at 9800rpm.
And as for going to the track this weekend, as long as the weather holds out I should be there.
Right now I am a 1 man show until things start to come together, then I will need the help to bolt it all together and get some street tuning in.
