Old 05-05-2019   #761
Well, I guess this officially makes me a South Dakotan... The Corvette license plate was the final bit of Texas I was clinging to
Old 05-07-2019   #762
Old 06-06-2019   #763
^The funny part is, that license plate picture was taken at the nearby Indian casino
Old 06-06-2019   #764
Finally got the AFE pipes back from the coater (https://www.facebook.com/SSPowderCoating/) and had them installed by the local Corvette specialty shop (https://www.facebook.com/CustomImageCorvettes/)...who would have known Watertown had one?!
Factory cat pipes w/DEI heatshields:
AFE pipes before coating:
AFE pipes after coating:
Here are some comparison pics of the pipe inlets and cat density showing, in theory, how much more restrictive the factory pipes are:
Vs.
I only have a few miles on then so far to cure the coating, but so far no CEL. I've gotten on the car a bit and it definitely has some additional volume to it; same with start-up and idle. Tour mode while cruising still seems plenty tame for roadtrips though which is exactly what I wanted.
I have a tank of 93 right now so I'll get some logs off to my tuner this weekend, then once that tank is gone we'll get it done again with the local 91 available in-town.
Old 06-06-2019   #765
Do u notice an increase in smell now that the cats are fine?
Old 06-06-2019   #766
Nothing out of the ordinary yet, even when idling in the garage, but I'll probably need more time/miles to accurately make that claim.
Old 06-07-2019   #767
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Looking good, gonna try to swap those blankets on the new pipes?
Old 06-07-2019   #768
I figured I'd at least try since it keeps a good amount of heat away from the oil cooler and dry-sump oil lines! The ceramic coating should help quite a bit as well. I thought about having the shop that did the install wrap at least the pre-cat section of pipe, but I really didn't want to risk having a cracked weld down the road sometime. I'll have to be very careful not to scratch up the coating with the blankets' metal standoffs though since I don't want it flaking off. I'll likely give it a try and see if/how they fit while swapping out the shocks. Speaking of, here's my thread on that: https://www.corvetteforum.com/forums...k-failure.html
Old 06-15-2019   #769
DOH!!!
Looks like I'll be having my tuner disable the code. I could have used non-foulers as I knew it was a 50/50 risk per AFE but I'm fine just having it disabled.
Old 07-02-2019   #770
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
I know that code 😋
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 07-22-2019   #771
Now that I replaced all 4 shocks (3 of 4 were leaking their sweet magnetic juices) for a cool $1300 I still have a faint clunk coming from somewhere in the suspension over bumps. I replaced the rear sway bushings & end-links yesterday hoping that might be it but unfortunately that didn’t change anything. The factory bushings looked fine and so did the end-links other than feeling a little looser than brand new. Up next are the front swaybar bushings & end-links to see if that’s the issue! Unfortunately, the car’s age (5 years/45k miles) is starting to show as its needed quite a few wear-n-tear items replaced this year it feels like. At least I got in a good 200+ mile roofless drive yesterday; still enjoying the car just as much as I did back in 2014, and at least replacing these parts is still cheaper than trading-in for a new one!
Old 07-22-2019   #772
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
I thought 45k on a Corvette was like 120k on a passenger car, you sure you dont want to trade in on that sweet new mid engine??
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 07-22-2019   #773
Zero interest in the C8; Julie and I both despise the interior and the fact it's auto-only. Bigger/heavier car, but with a more cramped interior... Brilliant! The row of buttons along the wall separating the driver and passenger sides is idiotic too. If anything, I'd get a 2019 C7, but realistically I may as well just keep this one for another 5+ years.
Old 07-23-2019   #774
I'm dropping it off at the local Corvette shop today to have the front swaybar bushings/end-links done along with the Big Daddy angled o2 sensor spacers to eliminate the CEL so AFM can be reenabled.
Old 07-23-2019   #775
Looks good! Can't believe you've had that for 5 years already.
Old 07-23-2019   #776
Time flies! Not sure how 5 years has gone by so quickly. Even crazier to realize I've owned 3 different houses in that time too.
Old 07-23-2019   #777
I bet the front sway links are contributing to that clunk that sounds like its from the rear. Hopefully an easy fix! They dont seem to last more than 50k miles.
Old 07-23-2019   #778
Thank you, sounds like you've had similar experiences! We'll find out soon enough... Hopefully this will be the end of it for the year, as far as maintenance/repairs go.
Old 07-23-2019   #779
If the clunking is in the front, have you tried moving some of the weight to the rear, like say the engine?
Old 07-23-2019   #780
I'll swap the 'Vette & Volt powertrains and report back.
