Old 05-01-2007   #61
Re: Toms Project...
Ok, so i managed to sum up the whole cars life within the first 24 hours of it driving.
First was being pulled over within the first 2 hours of it driving. Then i took it to work and went on lunch, came back and it was running fine.
Got off of work and the fucker wouldnt start. I checked everything. Was getting spark, had gas, fuel pressure, and the pistons were wet. Then i looked at the timing, WAY THE FUCK OFF. I dont know how this could have happened but it was running fine when i shut it off. But anyways, it was towed home. So today i have to get a timing belt and tensioner.
Fucking dsms.
Old 05-01-2007   #62
Re: Toms Project...
How did you go about setting the TB? Did you use the drill bit method? That works the best for me.
Sorry man, that really sucks.
Old 05-01-2007   #63
Re: Toms Project...
I did it when i had the motor out.
I lined up the crank at 10 BTDC, lined up the cam gears and oil pump gear. I pushed the tensioner in with a vise and dropped an allen wrench in the hole. Then installed that and pulled the pin after i had the belt on. it was dead on 10 btdc when i installed the motor and made sure it was. Im thinking it was either a faulty tensioner that just gave out or it was a bad belt. I am just hoping i didnt bend any valves.
What is the easiest way of checking the valves without pulling off the head?
Old 05-01-2007   #64
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Re: Toms Project...
Compression check is a easy way. Or the only way I can think of. Good luck man I hope you did not bend any valves.
Josh LaCroix
Old 05-01-2007   #65
Re: Toms Project...
How did you adjust the tensioner pulley? Did you adjust the tensioner pulley?
Old 05-01-2007   #66
Re: Toms Project...
Its an auto tensioner, isnt it?
Old 05-01-2007   #67
Re: Toms Project...
Yes, but you need to torque the cammed tensioner wheel at the same time as tightening it, THEN pull the pin on the auto tensioner.
Old 05-01-2007   #68
Re: Toms Project...
You need to torque the tensioner pulley to so many inch lbs also. Good thing you motor isnt toast!
Old 05-01-2007   #69
Re: Toms Project...
I wouldn't go that far, it very well might be. Tom, how far off were the marks? Why didn't you at least read the VFAQ? It is free! I hope you got lucky and it is ok, but if it wouldn't start, then chances are you at least have bent valves.
Old 05-01-2007   #70
Re: Toms Project...
Maybe 30 degrees or so.
I basically made sure the belt was tight but not too tight.
When i was trying to start the car it was not backfireing like it usually does when the timing is off.
Old 05-01-2007   #71
Re: Toms Project...
Rut-roh... That sounds like at least 2 teeth and at 2 teeth the valves are usually goners.
Old 05-01-2007   #72
Re: Toms Project...
well im crossing my fingers on this one. i remember when looking down the spark plug holes i didnt see any damage to the pistons.
In looking at the vfaq i did not use the torque tool, on the tensioner pully. i just figured that there was a auto tensioner for a reason, to AUTO tension the belt.
Old 05-01-2007   #73
Re: Toms Project...
It is a hydraulic tensioner, not an auto tensioner. It will take up slack as the belt wears, but it needs to start in the correct position.
Old 05-09-2007   #74
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Re: Toms Project...
Any updates?
