View Poll Results: How much WHP will I make on Cobb's AWD Mustang dyno?
<450 2 11.11%
450-475 3 16.67%
475-500 6 33.33%
500-525 3 16.67%
525-550 3 16.67%
>550 1 5.56%
Voters: 18. You may not vote on this poll
Old 03-23-2011   #61
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Hughes, this is the same dyno your old IX did 360/369 on right? So add a 2.3 and E85 to the mix?
Yes 2.3L+10.5:1 CR+no BS+ E85+stage 3 head
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 03-23-2011   #62
Re: SE take two!
Originally Posted by PlanoEvo View Post
+larger IC(ETS 4inch)
I believe the Perrin intercooler actually has a larger volume than the ETS 4" widetank.
Old 03-23-2011   #63
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Agreed they are both big ic's so a push
Old 03-24-2011   #64
mike55112
mike55112's Avatar
Drives: 04 evo
Re: SE take two!
I had a fp white (flows 10% over stock IX) on my 2.3 and made 450awhp and 470awtq on maps dyno at 25psi.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 04-09-2011   #65
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Parts coming in just got my new clutch thanks Adam! CM FX400!!
Old 04-12-2011   #66
Re: SE take two!
What do you think?
...I say lets do it!
Old 04-12-2011   #67
Re: SE take two!
If you do, take plenty of pictures plz.
Old 04-12-2011   #68
Re: SE take two!
I figure I already took apart his transfer case, this really can't be a whole lot different.
Old 04-14-2011   #69
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
The spider gears have me worried
Old 05-04-2011   #70
Re: SE take two!
for why?
Old 05-14-2011   #71
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
The engine is all done at MAP and awaiting shipping info. Hopefully here in a week the it goes back together and hopefully making the NTEC dyno day!!!!
Old 05-19-2011   #72
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Hell yes engine and head at my house pics to follow soon
Old 05-27-2011   #73
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Got the transmission back last night new HKS 4.11 final drive installed. Getting started putting it all back together this weekend with Kracka wooohoooo!
Old 05-30-2011   #74
Re: SE take two!
Head on & timing components swapped over from the old block! Now he just needs to get the tensioner tools so we can get the belt set.
Old 05-30-2011   #75
93gtpeater
Drives: cbr 1000rr repsol
Re: SE take two!
I want to see some pics please
Old 05-30-2011   #76
Re: SE take two!
He took a bunch today, hopefully he posts them!
Old 05-30-2011   #77
Re: SE take two!
Coated parts by SPC in Arlington, TX (MAP ported exhaust manifold, Mil.Spec R2 ported intake manifold, & Megan o2 housing):
Installing the timing belt tensioner on the new block:
MAP Stage 2 shortblock (2.3L, 10.5:1 pistons, MAP rods, & MAP headstuds):
MAP Stage 3 ported head (stock Evo IX valves):
MAP Stage 3 ported head (MAP beehive valve springs):
Old 05-30-2011   #78
93gtpeater
Re: SE take two!
Looking really nice. Cant wait to see what that thing makes on the dyno. Should be a fun car to drive when its all done.
Old 05-30-2011   #79
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Intake port
Exhaust port
5spd old 4.529 gears out with installed 4.11 gears
4.529 gears not needed anymore!
4.11 gears
4.11 gears
Old balance shaft sprocket
New 1.6 spacer 9oz savings!
Works Flywheel+new friction surface
Head on!!
Old 05-30-2011   #80
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
decided to go with new *** **** turbo which makes the 4.11's even more needed imo..with the 4.11 at 8K 5th tops at 190mph
Tags
post liked by shane
