Old 01-04-2012   #61
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Evo IX MR Winter Projects
The turbo kit has been wrapped up! All of the fabrication is complete: manifold, wastegate dump, down pipe, and lower IC piping. There are no modifications to the car, for the exception that I needed to run a Evo 5-7 radiator.
Old 01-04-2012   #62
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Wow, this turned out phenomenal! Create me one!
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 01-11-2012   #63
Mark Leasure
A little update:
I completed the oil lines for turbo. I primed the oiling system while the timing belt was off the motor, installed a new timing belt and completed the front of the engine. Filled the trans with fluid. I installed Avid racings poly motor and trans mounts offering, they look great but the passenger side mount raises the engine up about ¼” of an inch. So I fabricated a 1/4” spacer to account for the design flaw. I cannot believe how much garbage companies produce without and verification & validation testing. Just a tiny bit of due diligence would make customers 100% happier. I installed the Magnus V5 and Boomba TB too.
Next steps are to fabricate a slim line fan mount on the radiator, upper intercooler pipe, intake pipe.
Old 01-11-2012   #64
Hmm Magnus V5
Old 01-11-2012   #65
Which trans mount, the front/rear or side?
Ugh magnus IM and that huge TB...this thing is gonna freaking RIP!
Old 01-11-2012   #66
Mark Leasure
Motor mount on passenger side was off by a 1/4". The manifold works very good on my 1G so I was inclined to use it on the evo too. Yep this thing is going to be nasty!!
Old 01-11-2012   #67
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
You do some nice work man!
Amsoil Dealer
Old 01-11-2012   #68
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
God that looks clean! Keep it up man, I wanna see this beast this spring
Old 01-14-2012   #69
santa
Boost Spike
santa's Avatar
Looking good Mark! Im jealous of your exhaust housing!!!
Old 01-19-2012   #70
Mark Leasure
Thanks for the comments! I will be showing more progress very soon! I need to get the camera out to the garage! Next steps will be to fabricate the upper intercooler pipe and the 3.5" aluminum exhaust with 2 mufflers to keep it quiet.
Old 01-19-2012   #71
I'll be interested to see how quiet you can make it. As that is one of my goals for this season.. make the 1g 3.5" exhaust as quiet as humanly possible(willing to sacrifice a little hp for less sound).
Old 01-19-2012   #72
I was pretty happy with my old 3.5" system with the two mufflers, although it was still kind of loud. I need to quiet my current 3" system way down, I just don't like that fart can crap anymore.
Old 01-21-2012   #73
Mark Leasure
Quick update, it’s getting closer! Servicing the turbo kit is going to be a pain in the ass due to the downpipe. I cannot snake it through with all of the turbo/manifold/WG/radiator components in place. I need to remove the WG then snake it up through the bottom to connect it to the turbo. There was not enough room to fit a V-band close enough down before it makes the bend to the back of the car.
Old 01-21-2012   #74
That looks crazy.
Old 01-21-2012   #75
Mark Leasure
Yea I know what you mean. I'm debating installing one of those electronic controlled muffler on my other Evo. I had the chance to listen to one installed on a 3" TBE on an Evo and it sound OEM! The cost is a little high but worth it in my mind. At least it gives you the option to be "normal". My only concern is road salt fucking up the actuation and electronics controlling it.
Old 01-21-2012   #76
Any plan for a heat shield for the coolant return line ?
Old 01-21-2012   #77
Mark Leasure
Yes, I'm using thermo-tec wire jacketing to protect the coolant over flow line and WG line. I'm also wrapping the down pipe up, to protect the WG. I already wrapped up a section of the manifold to protect the starter wiring.
Old 01-21-2012   #78
Mark Leasure
Today I fabricated a new mount for the ethanol content sensor. I also cleaned up wiring and finalized the intake manifold.
Old 01-21-2012   #79
Damn, that E meter looks like a stock piece.
Old 01-21-2012   #80
funky_monkey58
Drives: 95 gsx
How do you intend to utilize the ethanol content sensor with the vs 1 AEM?
funky_monkey58 is offline   Reply With Quote
