Old 10-16-2013   #61
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: head fused to the block ?
nice man^
Old 10-16-2013   #62
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
When I just took mine off it wouldn't budge without removing the washers on the ARP's
BW8776, e-85
Old 10-17-2013   #63
M1L3S
M1L3S's Avatar
Drives: 99Gst
All washers move freely except 4 one. I honestly believe the on stubborn stud and washer is the issues.
I wish I knew how to post picks. Cause id post the pick of the bar my freind and I bent trying to lift the head.
That thing is on there. Lbvs
M1L3S is offline   Reply With Quote
Old 10-20-2013   #64
M1L3S
M1L3S's Avatar
Drives: 99Gst
We got it off !
Head dosent look too bad. Alot of corrosion. Head has to be warped
Old 10-20-2013   #65
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Well damage report? and how did you get her off?!
Old 10-20-2013   #66
Got as many studs out as we could then pried like hell with a 3' pry bar, used the power steering bracket for leverage.
He's going to have to pull the motor now and hone the cylinders and re-ring it though, there was some surface rust on the cylinder walls from coolant getting in and sitting.
Old 10-20-2013   #67
M1L3S
M1L3S's Avatar
Drives: 99Gst
Ended up removing all the head studs except 3 (stripped ones)
Then used a 3 1/2 ft pry bar.
Hammer and elbow grease.
She finally lifted up. I have pics. But I dont know how to post them :/
Alot of corrosion!
Definitely going to need to hone the block. Guessing the head is trash ?
But didnt see anything melted. And the weird part is all the fire rings on the head gasket were intact ???
Old 10-20-2013   #69
I have a 1G head for sale in good condition. came off a good running motor. $140/obo.
Old 10-20-2013   #70
dsmreck
dsmreck's Avatar
Drives: 98 gsx
is that head a virgin and strait^
Old 10-20-2013   #71
twack
It was a auto get over it
twack's Avatar
any chance that the block is now warped to?
Old 10-20-2013   #72
Well, the 3 remaining head studs that did not want to come out were VERY tough to turn with a vicegrips on them. I don't know if that means that the block could be warped and making the holes oval shaped or what?
