Old 05-12-2012   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: 91 Galant VR4
good luck man. hopefully you kill the gvr4 record
ლ(ಠ益ಠლ)
Old 05-12-2012   #2
Re: 91 Galant VR4
Awesome update John. Good luck this year!
Old 05-13-2012   #3
Re: 91 Galant VR4
Very very excited to get this on the rollers and the track!
Old 05-13-2012   #4
Re: 91 Galant VR4
Awesome!!
Old 05-13-2012   #5
Re: 91 Galant VR4
Moon taxi indeed! Nice work!!
Old 06-02-2012   #6
Re: 91 Galant VR4
Official 2012 mods list.
MoonTaxi Mod’s list
FIC 2150cc injectors (peak and hold driver)
No resistor pack
MSD box DIS 2
MSD twin post coils
AEM 5 bar map sensor
MAC boost control solenoid
GM AIT
GT4202 1.01 a/r divided housing T4
MAP stage 5 head (max awesome edition)
Crower 288 cams
Beehive GSC valve springs
90mm Q45 throttle body
JDM J Fab Customs intake manifold with epic fucking diamond plate accents, seriously epic
Exhaust manifold for dividing by zero and solving world hunger, at the same time
Block is solid yo, literally ¾ solid
9.0 CP pistons, heavy duty 22mm wrist pins, custom
Carrillo Rods, custom
Custom Quarter master twin disc
Stage infinity/Jack’s transmission that hates itself with welded center diff
Aeromotive Eliminator fuel pump, extra loud edition with 10 gallon fuel cell
E-85/E-98 tunes for facetaking
Bitchen cage ready for 7’s in a white moon taxi, 2 piece chassis conversion
JDM J driver <- seriously a mod
Car still has a/c with the windows down @ 55+mph, has a custom dash with gauges installed, and race seats with harnesses.
...and a few other items we won't mention here.
Old 06-02-2012   #7
Re: 91 Galant VR4
lol, awesome mod list.
Old 06-12-2012   #8
Mark Leasure
Mark Leasure's Avatar
Re: 91 Galant VR4
So do you have a sfi3.2a/15 flame suit? I'm kind of upset that they change the flame suit rule in 2012 for people that run ethanol and faster than 9.99. I used my 3.2/5 setup for 2 years and it's like new, now unusable. The cost of the suit is much greater too, I have a Simpson setup now and to upgrade to SFI-15 its $1600.00. I know there are other cost effective alternatives, like RJS for around 700, but there’s a lack of availability in time for MAP's PG. I'm afraid my fate will be determined in BIR's tech inspection...
Old 06-12-2012   #9
Re: 91 Galant VR4
What a load of crap, thank god for being slow is good for once. I meant me, in case anyone was wondering.
I talked to john a few days ago, and it sounded like he has a lot of work ahead of him to make PG, but well he was determined.
Old 06-14-2012   #10
Re: 91 Galant VR4
Yes running e98 and quicker then 9.99 we need to run the same fire suit as top fuel.
I have a line on a brand new suit and a parachute setup from an old top alcohol team.
I will write up another update this weekend, but a quick snap shot.
I drove the car early last week, we broke in the motor and changed the oil to red line 40wt race oil, and fixed a few minor things.
The tranny would not shift into 3/4 like it should and the wide band broke over the winter.
So off to MAP for a dyno session to see how the new parts are working.
First pull it made more boost then we thought it would, so we upped the boost cut and 2nd run made 613hp at 28psi, we added 1° of timing and made 620hp.
Then we tried upping the boost and ran into major traction issues.
The driver rear tire keeper spinning, registered 750@40psi, but I figure with no tire spin it will be about 850 @ 40-41psi. Which is the goal for PG. The AEM with control boost and have vss input for some traction control for 1st into 2nd gear.
Also with the QTP tires I hope if the tranny shifts right into 3/4 and makes the 850 it can I think this setup will run a high 8.
And a quick thanks to all my sponsors, and there are a few new ones this year: Modern Automotive Performance, Josh with CTS tuning, Ryan, Kyle, CP Pistons, Carrillo rods, Karl Ramm, KRAMM-LOX, Paul, Chuck at HTM, Jacks Trans.
Old 06-14-2012   #11
Re: 91 Galant VR4
Special thanks again for the crew at Modern Automotive Performance for staying late and the excellent use of facilities.
Old 07-29-2012   #12
Re: 91 Galant VR4
Well PG did not go to plan, shifting issues left us with 60' testing, which only making 8 full passes on this new setup over 2 years, was not a bad idea to get this part working right.
So the new tires are the best thing ever, the car makes no low end torque, so having a little spin threw 1st gear is the goal.
The first test pass was a 1.59, great, a lot faster then the 1.75 for the record run last year.
Then some adjustments and ran a 1.52, getting to the magic 1.500 I was looking for.
Then everyone was like dam that thing spins a lot, so we tried lowering boost at the line and tire pressure, we found at 5psi of boost and 13psi tire pressure the car falls on it face, drops to 2,000rpm and runs like a 1.63 60'.
The car is back up and running, I want to get a few more tuning sessions in and get back to the track with full shifting capability, then get the 60' back to the 1.500 it can be, with 12-15psi of boost at the line and 12psi tire pressure.
Old 07-30-2012   #13
Re: 91 Galant VR4
Still plenty of season left my man, let us ease into the awesomeness.
Old 07-30-2012   #14
awd-drifter
'2of9'
Re: 91 Galant VR4
amazing 60 foot man. *thumbs up*
ლ(ಠ益ಠლ)
Old 08-08-2012   #15
Re: 91 Galant VR4
I did drive the car to work and home, I have the tranny out again... I have all the parts needed on the way to make this thing shift at high RPM for another few runs at the track to get my goal. Also i wanted to hit the dyno 1 more time to see what 48psi does, then nitrous if all is good.
Old 08-08-2012   #16
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: 91 Galant VR4
Post up before you hit the dyno, I might stop by to see it in action!
Good luck man, I wanna see this beast flying down the track once more.
Old 08-26-2012   #17
Re: 91 Galant VR4
Time for the small update.
The new 3/4 syncro set showed up and they are installed. The tranny shifts great at 10,000rpm and we are working out the tune with the 26" tall tire and shifting. The RPM drop per gear is a lot more then the last few years, but the traction and MPH per gear is well worth it.
My new math says the top speed in each gear at 9500rpm is this: 1st 54mph 2nd 80mph 3rd 126mph 4th 172mph
I have done a few pulls now and am back in sync with the car getting the 3/4 shifts clean.
We are going to the muscle car shoot out at BIR this coming weekend to see what this car does with a 1.5 60', clean shifts, and 41psi.
Also when we are at the track we will test and setup the NLTS, this will help with the new tires and traction, boost drops between gears, in the car its hard to tell, but the logs do not lie.
We are heading up to the All Mitsubishi Cook Out tomorrow then the track is next weekend.
Old 08-26-2012   #18
Mark Leasure
Re: 91 Galant VR4
That's great, I can't wait to see it in action again up at BIR!
www.maperformance.com
Old 08-26-2012   #19
Re: 91 Galant VR4
Good luck this coming weekend.
Old 08-26-2012   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 91 Galant VR4
"look dad it's as bigs as my head"!
Go break some records!
