Old 07-17-2010   #841
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Swifty's never-ending project thread!
Originally Posted by awd-drifter View Post
swifty, did you ever think about goin' with a compound setup?
He's having enough trouble with one turbo.
Old 07-17-2010   #842
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Part it out.
Either that or buy a http://cgi.ebay.com/ebaymotors/WOW-O...item41512577b6
Yup.
-Colin
Old 07-17-2010   #843
mlomker
*Resting In Peace*
mlomker's Avatar
Originally Posted by cudvig View Post
Obviously not a drag vehicle but I'd love to have one for road course. Amazing cars for the price.
Old 07-17-2010   #844
311evo
311evo's Avatar
Part it out.
Yup.
-Colin
I want SO bad. I love these cars.
fuck yellow though, there's a dark cherry one in MN I want real bad.
Old 07-17-2010   #845
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Originally Posted by TheBlizzard View Post
Seriously though, how the fuck does a rebuilt turbo have fucking shaft play within a 100 miles? Even if its a piece of shit knock off, it should last awhile longer than that. I could see one doing it, but two in a row, come on.
My guess would be more of an oiling issue. Feeding or draining.. Either way, if you dont part it out I give you a lot of credit for sticking with the car for this long. I almost gave up on my car after only 2 months of BS.
-1990 Mitsubishi Cyborg 4WD-
Old 07-17-2010   #846
blackrosenova400
blackrosenova400's Avatar
No its becuase they kept using a 270 degree thrust bearing system in the turbo instead of the 360 it needs to support the thrust loads.
With the 270 degree system there isnt enough oil in between the thrust bearing to support such a big compressor wheels thrust, and pretty much just pushes out the oil out of the way. Especially when closing the throttle after high boost. If you can hear your blow off valve flutter after you relased the throttle under high boost, it is removing and applying thust load on that thrust bearing mulitple times, and killing it.
http://www.turbomagazine.com/tech/04...t_1/index.html
20g Mafia
Old 07-30-2010   #847
"After overlaying John's graph with mine, the stupid ar housing doesn't help spool at all, and the gt42 t5 turbine wheels are pretty efficient enough. I'm actually aborting the turbo all together..I found a REAL gt4294 for CHEAP..just comes with a t6 internally gated housing I need to remove and swap out."
Old 07-30-2010   #848
why not just have someone build you another new exhaust manifold. hahah, then switch the head.. then go with higher compression piston... then (you get the idea hehe). Just givin ya shit swift, good luck with the new turbo
Old 07-30-2010   #849
I just don't get it.
Old 07-30-2010   #850
I've said it before, quit buying junk turbos. You end up spending more in the end.
Old 07-30-2010   #851
311evo
311evo's Avatar
It's prolly REAL cheap for a reason, unless you found a diamond in the rough.
Old 07-30-2010   #852
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
6765 and be done with it dammit!
Amsoil Dealer
Old 07-31-2010   #853
^This.
Old 08-05-2010   #854
Updating, since scheides twisted my arm over it.
I've sold my guitar setup, since it was a liquid asset that i didn't mind parting with, to fix this fucking car for the end of year.
Found a new gt42 for sale. Guy was asking $200. I went and looked at it, and talked him down to $100 (he's a vw guy). it came off a detroit diesel series 60, and came with a t6 1.28 internally gated exhaust housing. I took that housing off, and am looking for places to list it for sale on, as I will never use this. The rest of the turbo I inspected, looks GREAT. It was dirty as hell from all the diesel oil and such, so I tried some easy off oven cleaner, and got most of it clean. Still wasn't up to my par, so I ran up to Primo, and with their help, soda blasted and cleaned off all the parts, wheels, housings, and such really well. I have the new torque specs for everything, after conversating with Nick over at Diesel Components, and will be reassembling the turbo in no time. the nice thing about it is the parts all look new on the inside. It has a 270 deg. thrust bearing, but most of these turbos from the factory come with it. What I really liked is the fact that it was stainless steel, NOT brass like the last turbo I had. This shows no sign of going out anytime soon.
I found a housing from a supra guy, and after he shipped it to me, it was the wrong one. He said it's for a gt42, but once I got it, looked at the casting, and mic'd it all, it will never fit. I believe it to be a housing for a GTS turbine wheel, like the 74 GTS turbos those supra owners all love. All is good, he's refunding the money, and i'll ship back the housing to him. Still looking for a gt42 vband 1.01 housing, so we shall see what comes of it.
Hot parts are all at Primo getting their treatment/coating, and the valve cover too, since the corner of it got fucked up somehow. New color, after looking over my options will still be black, but with a "fire sparkle" top coat..basically a little red glitter. Not overly excessive though, but just a hint of it. We shall see how it all turns out. Once I find the housing though, and get everything back, car will be together, running, and doing pulls within an hour. So, I'm just playing the waiting game.
/end update.
Old 08-05-2010   #855
I'm waiting on reply from the guy I found.
Old 08-05-2010   #856
Thanks buddy. I have a pic somewhere I sent to mike and them of both turbos sitting next to each other on my toolbox, but I can't find it on my phone..I prolly deleted it already.
Old 08-05-2010   #857
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Sounds good swifty! I hope everything comes together soon!
Old 08-05-2010   #858
Just do two sc61's in parallel. I will sell you the first one today. Good luck on the truck turbo.
Old 08-05-2010   #859
Try posting that 1.28 housing on here, someone might be interested:
http://www.midwestdieselconnection.com/forum/index.php
I had it saved so I could zoom in a little better on the small screen on my phone.
Old 08-05-2010   #860
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Nice to see that you're getting it back on the road soon! When do I get a ride??
