Old 06-07-2011   #921
Re: beaterX project thread
380
Knowing my luck and my cars, you're probably spot on
Old 06-07-2011   #922
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
At least at 380whp you won't break anything
I think 430whp (your goal) should be easy, but I am a nub.
Old 06-07-2011   #923
I was thinking about it some more.
According to DW their pump is good for 600whp on MAP's dyno @ 14v and at 15.75v mine was about at the limit, so 600*(15.75/14) = 675whp @ MAP /1.15 (convert to DB dyno dynamics) = 586whp, I think if I can get about that I will be happy. If not, I will just list the car for sale, it's no fun anyways.
Old 06-07-2011   #924
mlomker
*Resting In Peace*
mlomker's Avatar
Ricer math ftw. I'm doing the same calculations on my Weldon. :\
Old 06-08-2011   #925
Ok, doing boost control testing I'm getting some inconsistencies--I'm trying to get it sorted. So glad I have e85 so a little more boost doesn't hurt a thing, and I obviously have enough fuel now with the BAP turned all the way up, and I even leaned the fuel map out a little This is ~33psi to just shy of 7000rpm tapering to 28 at 8500. Go 'lil BBX GO!
Again, different starting RPMs!
Earlier today I mentioned to Hughes that I should upgrade the fuse for the fuel pump from a 20a to a 25a or 30a...prolly not a bad idea right? On the way home from Wagner's tonight sure as shit, it blew and I coasted into robbinsdale. I swapped in a 30a when I got home
Did I mention I'm having a blast getting the car dialed in? 4th gear the car just fukin rips!
Old 06-08-2011   #926
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
When were you dynoing?
Amsoil Dealer
Old 06-09-2011   #927
Murlo26
Murlo26's Avatar
Wow, looking great Scheides! Can't wait to see it fully tuned up
Old 06-09-2011   #928
Weds.
Old 06-09-2011   #929
Looks great! I forget, is this logging a wideband or narrowband O2?
Old 06-09-2011   #930
Narrowband, LOL yea right!
Wideband fo sho.
To be clear, the boost just happened to go this high, my goal is to keep it right around 30. It was a good test of the fuel system though, so I am happy with it.
Old 06-09-2011   #931
Just happened to go that high... Yeah, right! Are you worried about the stock wiring being the weak point with such a large fuse in there now?
Old 06-09-2011   #932
Murlo26
Murlo26's Avatar
That is the idea of many fuses, to protect wiring, not protect devices. Basically anti fire device
Old 06-09-2011   #933
Yes, but only if they're properly sized for the gauge of wire they're being used on. Going from a 20A to a 30A doesn't sound like that big of an increase, but it's still 50%.
Old 06-09-2011   #934
Murlo26
Murlo26's Avatar
Well what gauge wire is the fuse on? 14 awg maybe? 14 is good for 15 amps, 12 awg for 20 amps...and so on.
I am an electrical engineer, done plenty of fuse sizing in my day.
Old 06-09-2011   #935
So say it is 12 awg since the factory fuse was 20A, wouldn't running a 30A fuse on it become a fire hazard?
Old 06-09-2011   #936
Murlo26
Murlo26's Avatar
Possibly yes, depending on the wire rating. Some are rated for higher temperatures. What I quoted was the 75 degree C wire rating. There is also 60 degree and 90 degree and really high temp stuff that you can get away with a lot more.
75c is the norm typically though at least for industrial use, I am guessing auto is similar.
It honestly all depends on what kind of current he is actually drawing. If I knew that it would be easy to tell you. And it also depends on the type of fuse. There is an entire icky thing called fuseology...basically you have fuse curves that depending on current levels and length of time at those levels the fuse will be fine or blow. It gets messy.
Old 06-09-2011   #937
Yea I would put in a 25A fuse but all I had was 30. I don't expect it to be a fire hazard as it's not going to continually run at the full 30a. The kit itself includes an upgraded 40a fuse so anyone that has installed one has likely run into this same problem.
If it ever is a problem, I make sure to carry a fire extinguisher at all times in the trunk.
Old 06-09-2011   #938
Murlo26
Murlo26's Avatar
^I am going to start carrying one myself. I think it makes sense with the level of modification I have.
Old 06-09-2011   #939
FWIW I had done probably 10+ pulls w/o blowing the stock fuse so I'm guessing it's running right around 20A. The weird thing is that it blew right as I was getting on it, not like at the top of 4th gear or something (after a looooong pull at high amperage).
Old 06-09-2011   #940
Probably due to a quick spike as it turned on I bet. Like turning on a light, the initial surge is always greater than constant draw.
