Old 11-04-2010   #81
Re: Borg Warner Turbos
Latest word from Raffi at Full-Race is tht pricing may be out at the end of sema, but it could also be after thanksgiving.
If it is truely going to be that long, than I will be just sticking with the 84-75 I have because I need to start making some progress.
Old 11-04-2010   #82
Lame. Don't do it!!
Old 11-04-2010   #83
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
And they have this little guy to.
Old 11-04-2010   #84
If you have to ask about the pricing, then you can't afford it.
Old 11-04-2010   #85
mlomker
*Resting In Peace*
mlomker's Avatar
They have a photo of one on an Evo X stock flange. Now I'm curious.
Old 11-04-2010   #86
Ha, probably true
Old 11-05-2010   #87
http://www.diesel-plus.com/turbo_sea...rgWarner%20EFR
First pricing I've see listed. The one I would have been interested in which is the 8374 w/ divided T4 and internal WG is around $3000 (part number 179357).
So yup, I'll just be sticking with the 84-75 I have now, im not ballin like that haha
Old 11-05-2010   #88
Geebuz. Still cool, hopefully pricing comes down a bit eventually.
Old 11-09-2010   #89
Full Race got their site updated a little bit with more info. Click on the turbo in the bar graph for pricing, comp maps, more info etc.
http://www.full-race.com/articles/bo...fr-turbos.html
Old 11-09-2010   #90
I'm confused by those numbers, a 67mm only rated to 49lb/min?
Old 11-09-2010   #91
that's 67mm exducer. They name their turbos different than PTE. PTE uses comp inducer and turbine exducer (i.e. 6265)
BW uses comp exducer and turbine inducer (i.e. 83-74)
So the 67mm turbo you are looking at, would be more commonly referred to as a 53mm turbo (that's the inducer).
The 83-74 (a 62mm turbo) they rated at 79lb/min!!!
And the real 67mm turbo (91-80) they've rated at 94lb/min.
Old 11-09-2010   #92
^Thanks for clearing that up, I would expect that 53mm turbo then to do 55+lb/min.
Old 11-15-2010   #93
cool vid on the new efr stuff. amazing how much r&d goes into these before ever even being bolted onto a vehicle, and the testing they do also.
http://www.youtube.com/watch?v=wfuE6xiij9g&hd=1
Some info from Geoff @ Full Race that I thought was useful.
If you go bigger on the compressor that is the same thing as going smaller on the turbine. I put up a bunch of posts explaining the U/C ratio of Compressor OD / Turbine Wheel OD in that big road racing turbo thread... basically divide the compressor OD by the turbine OD - an optimal match will be in the neighborhood of 1.09-1.18 whereas a mismatch turbo will be 1.18+... Also keep in mind that a small a/r will have low turbine efficiency at low flow rates, and higher turbine efficiency at higher flow rates. Conversely the large a/r will have high turbine efficiency at low flow rates and lower at high flow rates...
6blade compressor wheel -- ideal match ratio of ~1.14-1.24
7blade compressor wheel -- ideal match ratio of ~1.09-1.18
Old 01-27-2012   #94
Found some results for the S362:
http://forums.evolutionm.net/evo-dyn...o-results.html
Car info (EVO):
Motor-
2.0 LR 9.1.0 CR
Howard Ultimate Duty I-beams 156mm Rods
Wiseco HD 9.1.0 Pistons .20 over
ACL Bearing
Sparktech non-CDI Ignition
GSC S2 Cams
GSC Behive Springs
GSC Ti Retainers
GSC Valve Seats
Supertech Valves black nitrate coated
Supertech Valve Guides
Torque Solutions Motor Mount Kit
APR Front Motor Mount
BEP S362 T3 Turbo .70 A/R w/CompR Billet wheels
Turbo Trix Manifold
Custom DP
Custom Test Pipe
BR SD 3" Catback
Fuel System-
Fuel Lab FPR kit
FIC 1450cc
AEM Meth Injection "Direct Port" w/Failsafe
Cooling Mist CM5 Knozzels x4
BR Double Pumper
Trans-
Bushwacker Trans "Evo IX 5 speed Trans w/Evo VIII 4th"
Exedy Twin HD
MAP Clutch Fork Stop
STM 1 piece clutch Line
B&M Short Shifter
Blox Knob
Redlinegoods Shift Boot "Custom made for MR Console"
Suspension-
Standard Suspension R3 Coilovers
Whiteline Roll center correction kit
Boost was off on the 35.25 run I maxed the 50psi Absolute sensor which maxes at 35 when we did another pull it was 38.X psi and the sensor is off by 1psi reading higher so we got it to 41 psi.
The 608 and 553 are 3rd gear pulls and the 616 is a 4th gear pull.
Old 10-14-2012   #95
Figured I'd share some results I found from someone running my same 61mm turbo (BW S300sx 84-75) on a Supra with a .88AR T4 open exhaust housing and 264/264 cams. Thought they were some pretty good numbers for a 61mm.
560hp\540tq @ 18psi
630hp\590tq @ 23psi
700hp\675tq @ 27psi
Old 10-14-2012   #96
Those seem like great numbers, I wonder how much is due to displacement.
Vassil made 725whp (DD) at 32 psi on a 2.0L
Old 10-14-2012   #97
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
yeah that torque takes off and the hp takes over, very nice
2006 WW IX RS 396/404 - SOLD
Old 10-18-2012   #98
2Point3TSi
2Point3TSi's Avatar
Drives: 1995 Jeep Grand Cherokee Limited
The EFR turbos are fantastic. I got to see some of the first cars at Full-Race that had these turbo's and I was super impressed. Here is a video of a friend from AZ that has one on his fully built RSX. Also not sure if you can see the links to the forum.
http://www.youtube.com/watch?v=9OS0RazIaVs
http://www.kutsujuracing.com/forum/s...=50682&page=27
2002 Chevy Camaro - Wife's Car
1998 Eagle Talon TSi - Stroked and Slow-Gone
2Point3TSi is offline   Reply With Quote
Old 10-25-2013   #99
Any more info on these? Trying to learn about t4 TS stuff.
Old 10-30-2013   #100
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I need to jump into this thread...
My plan for spring is to go back to an internally gated setup, 90% sure I will be rocking the 7670 .92a/r BW EFR. I have spoken to a lot of people and it looks like its what I am looking for in terms of down low power and powerband, should have peak torque around 4k rpms.
Most who have tried this one on Evos say its a stock turbo on steroids feel, can't wait to try it out.
I have been very skeptical of BW turbos for a while, ever since they released the EFR's but almost every turbo in the top 5 for world time attack runs an EFR now. I have tried everything else, mind as well try this right?
Here is an Evo X comparison (2.2L motor) of the 7670 EFR vs the 9180 EFR
