Old 10-02-2014   #81
Aftermarket oil pan is a decent idea if you plan to track the car, the baffles and larger capacity both help. But you only get an oil temp port, there is no oil pressure in the pan, you'd still have to run that off the oil filter housing or external cooler or something.
Old 10-03-2014   #82
The goal for this car wasn't really for it to be my DD, it was to be a replacement for my bike, and be my Road Race car that I used with my brother when he travels down this way to race (VIR and CMP)
I plan to install an oil cooler for sure and will more then likely go with the Moroso pan.
I just haven't settled on which way I'm going to install the Oil cooler . I've thought about changing up the OFH to the one that has everything I need like mark suggested in my other thread I think it was. I just haven't done enough research yet.
The other option is to use the pan for the Oil temp, drill and tap a hole for the oil pressure (per several write ups)on my FFOFH, and then use a sandwich adapter for the oil cooler.
Old 10-05-2014   #83
Well today was a productive day on the car.
removed the turbo system from the car, and from there i was able to remove 3 of the 4 bolts with out issues (help of PB blaster) the 4th one I had to grind down the top till it was 1/2 gone (disc wouldn't reach any farther) so was hoping a pair of vice grips might be able to brake it off the rest of the way (turns out heat of the grinding must have loosened up the bolt as it unscrewed) at the very end I found the reason why it was so hard to remove, previous owner cross threaded the bolt.
So luckily I have a full die and tap set, and was able to re tap the hole to the correct thread size/pattern.
I also found that the lower middle three studs for the exhaust manifold were missing there nuts/washers. So replaced those as well.
And when trying to remove the airlines from the waste gate I found that both lines going to it had become brittle and had holes in them. One was so bad it had 3 holes in it and the only thing keeping it attached to the WG was the string inside the rubber.
So replaced/checked all the lines that needed replacing.
Did find one thing I'm concerned about. There was small amount of oil on the exhaust manifold to head gasket around most of the ports. I checked the lower I/C pipe for oil but it was clean/dry. So what does that mean? valves? rings?
I have only seen minor smoke when starting a WOT pull from time to time (thought it was just smoke from running rich, but now I'm not sure)
Tomorrow I'm going to do a compression test as well as see if there is oil on the plugs.
Old 10-05-2014   #84
On the bottom middle exhaust stud that comes out of the head is an oil galley. If you dont rtv that stud, it will do this.
Old 11-10-2014   #85
Well still no luck on figuring out why I can non longer boost over spring pressure with out it sputtering. (And even then sometimes its still splitters on occasion)
Over the weekend I pulled the valve cover just to see I could find anything.
Nothing looked out of place, took pictures of the hks cams, spring and retainers, as well as the kiggly piece. I also checked torque on the head studs and to my surprise at 70 they all turned. So torque Them to100.
Drove into work but still same old same old. At a loss om what to do.
Been contemplating getting
-injectors flow tested/cleaned
-new a/f sensor
Other then that id like to check the timing. But what's easier/possible.
To pull the motor or can I take the covers off while its in the car?
Old 11-10-2014   #86
What headstuds? 100 ft/lbs is a lot of torque. You can check the timing marks with the engine in the car (no different than doing a timing belt job).
Old 11-10-2014   #87
Arp's - believe they are just standard though. All searches I read said 85 with lube and then 100 if you are retorquing w/just oil.
My guess is the owner said he just finished having the rings done on the car and only put 1500miles on the motor since or something like that. And from what I was reading you are supposed to check torque again after break in which I dont think was done.
Forgot to add I was thinking about possibly getting a mbc also as I've seen weird readings from that as well on link from my ebc. Logs were posted in my tuning thread where you can see all this stuff happening.
And ive never done a timing job. I used to pay john from lse to come down and do it. So this will be another first when the time comes.
Old 11-10-2014   #88
Taking the covers off to check timing isn't that difficult. Several screws are different lengths, so make sure you mark exactly where each one goes when you take them out.
If you have a 1g style adjustable CAS you should also check base timing with a timing light to make sure it's 5* BTDC. Several threads on how to do this by grounding timing through link. You'll need the lower timing cover on for this part.
Edit: or use this method if you dont want to set timing with the lower cover: http://www.dsmtuners.com/threads/how...-cover.312350/
Old 11-10-2014   #89
This car is using a 1997cas.... (6bolt block / 2ghead combo) but will read up on it and hopefully get this checked this coming weekend.
Old 11-10-2014   #90
talonsway
Drives: 1995 eagle talon TSI
My talon would always break up due to the inverted CAS. Switched over to a 1g cas and set the base timing and never had another issue dont know if this is the problem in your case, but i would think it would be smart to look into like mentioned above. great build so far !!
talonsway is offline   Reply With Quote
Old 11-11-2014   #91
I wish I could is isolate the issue so I could pin point what needs to be fixed.
Like last night car at spring pressure was pulling really strong so I loaded a log from when I had boost set to 25psi. Did a pull and the car boosted so hard (less then 800rpms pull) saw the gauge hit 36psi at initial spool up. Reviewed logs and link showed 40psi.
So manually went in and loaded different settings after two pulls had it at 22psi.
so why would settings that I ran for 5months now all of a sudden cause such high boost?
Old 11-11-2014   #92
Colder ambient air temps.
Old 11-11-2014   #93
Its possible, but when combines with the fluke last week where I captured a log showing that while cruising with out changing throttle position or anything the controller would just kick on as if I was trying to do a pull, its hard to say for sure of the ebc isn't having an issue also.
Ive also noticed my wideband go nuts for no reason also where it will just stick full rich or somtimes randomly go full lean.
Temps here have been back in the 70's lately. Last night during a pull my wipers went up at around 130mph.
as if there wasn't enough power but logs show 13.7v on the battery at the time it happened.
Just wierd how one moment/pull everything was going great, then the very next pull all this random stuff started happening and has kept on ever since.
Is it possible something is going wrong with the ecu? I remember leaky caps or something was an issue going around when I had my last car. Would that cause something like this?
Old 11-11-2014   #94
I just came across a thread on tuners through a search about the ARC-2 with cop setup causing the same issues im having once either the arc goes bad or the cop goes bad.
Which im running arc 2 w/cop. One person experiencing the same issues finally found his harness had gone bad. Still researching ways to v eryify using an ohm meter.
Old 11-11-2014   #95
ARC2's were great at first, but at some point they became hit/miss. I had an ARC2 on my car to go along with the stock ignition. I never really noticed much of a difference with it honestly, so I always wondered if I had a questionable unit.
Old 11-11-2014   #96
Go to stock
Old 11-12-2014   #97
Well last night before leaving work decided to start the car and check all wires going from the cop to the arc2 and when I got to the plugs by the arc2 I wiggled them and when I did the car would drop rpms. I wiggled some more and the car would probably die if I kept wiggling. When id stop the rpms would go back to normal.
Haven't gotten a chance to pull all the plugs and check pins /wires. But hopefully my issue is someplace in the harness, cop, or arc2.
When I did my first two pulls car barely sputtered at 22psi...but rest of the attempted pulls sputtered anythinf over spring pressure again. (15psi)
Old 11-13-2014   #98
Do like brown said and ditch the cop and arc2, go back to stock stuff. You really dont need anything but stock for your power level. More headaches than its worth.
Old 12-05-2014   #99
Sorry for the OT post, but how far away from Carolina Motorsports Park are you? There is a small chance I may be going in spring.
Edit: Just read your first post, haha! If I end up going I'll let you know. The annual Noble/Rossion track day is probably being held there. Not sure on date yet.
Old 12-05-2014   #100
16miles.
I literally turn right out of my neighborhood , drive 16miles, turn right into the race track.
I live off the same road as it.
