Old 10-05-2011   #1001
Re: beaterX project thread
I bet if you used nitrous and had a backfire that piece they cut open would put a nice dent in your wirewall.
Looks cool and hopefully you pick up some gains with it!
Nitrous expansion plate ftw!
I'd actually put a nice hole in my radiator, it's in the front
Old 10-05-2011   #1002
Very awesome! The Rev3 did good things on my IX, and I know my basic ported IM/TB combo showed great gains on my X!
Old 10-05-2011   #1003
People have said the IM and TB aren't really bottle necks on the X's
The stock X TB is smaller than the stock IX TB, it is the smallest diameter opening of the entire intake track between the turbo outlet and intake manifold inlet.
You saw the results my friend gained by just adding the ported TB to his MR-T w/Green I think.
Old 10-05-2011   #1004
Most of the time a nitrous backfire will blow up an intake manifold anyway....
Chris,
Are you using a software like Virtual Dyno? You should look into something like that as you seem to make parts changes a lot and it can get expensive running to the dyno all the time (plus I know you street tune).
Old 10-05-2011   #1005
He uses the fuck out of VD.
hmm nitrous.
Old 10-05-2011   #1006
v8klla
v8klla's Avatar
Where the heck did you get that manifold from? lol Used I assume?
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 10-05-2011   #1007
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Oh I am not saying there aren't gains, its just a lot of people with bigger turbos haven't posted a ton of info on them yet.
AMS has said before they think the intake mani is very good factory and isn't worth upgrading. However, I doubt there is no room for improvement.
Post up a before/after in Virtual Dyno Scheides, when you get AFR's in line!
Old 10-05-2011   #1008
Added about .8AFR to my fuel maps this morning and the car no longer knocks at all. Runs solid like it should and the car feels great all over, but no amazing change from my butt dyno.
However....and this is FAR FROM PERFECT but if the numbers indicate gains across the board:
Also I now have a set of FIC 2150cc injectors...trying on if I want to install them and sell my 1680's or just sell them. Either way the money will go towards the new walbro DW400 fuel pump setup and a mil.spec 64mm TB....maybe by xmas? :P
Old 10-05-2011   #1009
Murlo26
Murlo26's Avatar
Hmmm, I might want one of the sets of injectors that you don't end up using.
Preferably the 2150's but who knows. PM me down the road when you decide and we can talk.
Gains look solid, fatter midrange ftw!Tough to tell on virtual dyno sometimes though.
that mil-spec 64mm is the hotness too btw, I like that you are maxing the setup out!
EDIT:
Also you should be able to grab my AMS intake shield sometime soon, next few weeks so you can test it out and copy it if need be.
Old 10-05-2011   #1010
mmmm gains!
Old 10-05-2011   #1011
Nice! I'm in no rush. Car runs great with my silly exhaust manifold heat shield I def want to give it a try though!
mmmm gains!
ino right! Driving the car around a little more & not concentrating on fueling it definitely feels better everywhere. It's not nearly as dramatic as when I swapped in MAP's long-runner tubular manifold, but I can feel it down low and there is a little bit more yanking of the neck up top. The powerband on these 4b11's is so smooth it's hard to really say it feels faster.
Old 10-05-2011   #1012
very nice. need to drive it with the new parts
Old 10-09-2011   #1013
Car rolled over 38000 miles as I pulled into the garage last night--this marks 10,000 miles on the motor since I got it running last fall. What an epic year it has been! The car is making fantastic power and I couldn't be happier with the drivability and day-to-day civility. The car runs perfect and last weekend Andrew complimented me on how clean the car runs under boost--no puffs of smoke, no drops of oil flying out, etc.
Today I decided to give it a health check. Engine was up to full temp but oil temps were probably not too hot as I only drove over to the dog park and back.
Compression test:
145 147 138 127
147 149 139 130 (retest)
This spring I had tested it out at 145-151-146-145 so I'm not sure what to think.
Next I yanked the valve cover off and check the clearances on all of the cam buckets. All are within spec except intake cam lobe #3 (cyl 2, intake valve #1) which is .012/.013, this hasn't changed since I checked it at 1000 miles.
Checked timing chain stretch, it's well within spec.
Spark plugs look ok, probably will replace them next spring.
Boost leak test and oil change are on my todo list, maybe next weekend. About time to order snow tires to I guess :P
Old 10-10-2011   #1014
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
God damn man. I am definitely envious of this car. I'll catch up eventually.
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 10-24-2011   #1015
I couldn't bring myself to spend $1200 on another set of Dunlop WinterSport 3D's...even though on the X the car surpassed any other AWD car I've driven in the snow. Lots of local guys have had great luck with the Hankook W300's and these are the next-generation: I'm going to try my hand at a new tire that I haven't heard much about: Hankook W310 i-cept evo.
I weighed them against the Dunlop Wintersport M3's and the w300's and had to play around with sizing to find different tires that would fit and not kill my wallet. In the end I got 235/40-18. Stock is 245/40-18.
$796 shipped from discounttiredirect.com, best deal I could find on 18" snow tires that fit on the stock X rims.
Old 10-24-2011   #1016
Skinnier tires are better in the snow anyway. That's cool.
Old 10-25-2011   #1017
The tires are called evo they belong on your car!
Old 10-25-2011   #1018
Murlo26
Murlo26's Avatar
Nice pick up! The Dunlops easily made my X the most enjoyable best snow handling vehicle I ever drove but yes they are stupid expensive.
I am sure these will work well too. Let us know how they compare!
Old 11-10-2011   #1019
Ok snow tires are still sitting at the ready...in the meantime I ordered the aluminum undertray from SSP in South Dakota...man this thing fits REALLY nice. My front bumper was flimsy and kickable, it is missing chunks out of it (see thread title!) and I just realized that I might be missing the lower wheel liner on the driver's side. In fact I'm sure of it, just never thought about it!
Install took about an hour, including jacking and lowering the car and *sniff* firing up the torpedo heater for the first time this season.
Every hole lined up perfectly. You can see the access panels for the oil drain and filter.
Lots of unused mounting points along the sides, probably hs something to do with the missing wheel liner piece I guess :P Still fits awesome. My bumper cover is much more sturdy, this will be VERY helpful once the snow flies
Old 11-10-2011   #1020
b00sted_spyder
How much did that nice piece cost you?
