Old 10-09-2017   #1061
Re: House Projects
Anybody know a good electrician? Looking to get some can lights installed and need wire run via the attic.
Old 10-09-2017   #1062
Re: House Projects
We have someone we use(electrician), I'll try to remember to.add his info when I get home.
On that note, we are looking for a general contractor/company to do some updates to our house (bathrooms and moving some non structural walls).
Anyone know anyone good with reasonable rates?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 10-10-2017   #1063
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: House Projects
When you looking to have this done? My dad is a GC but he's a bit swamped right now. Depending on timing I am sure he would be happy to discuss this with you.
Old 10-10-2017   #1064
Re: House Projects
Ended up getting a quote from a local electrician in the south metro, its about 150 per can light, and another 100 for the switch if needed. About what I expected, but I may try doing the kitchen myself and see how that goes since wiring and the switch are already there.
Old 10-10-2017   #1065
Re: House Projects
Would like to get a quote and design rolling soon to get the ball rolling. We'll have some work to get rid of stuff and move stuff out of the way. Then would like to begin construction roughly February.
GSX - 571whp/490wtq
Sienna
Old 10-10-2017   #1066
Murlo26
Murlo26's Avatar
Re: House Projects
I will ask him for you. If you want, shoot me a PM with some contact info and I can pass it on. He's building my house currently and has quite a few other jobs rolling right now but starting work in Feb would probably be a good timeline.
Old 10-10-2017   #1067
Re: House Projects
Contact info sent. Thanks
GSX - 571whp/490wtq
Sienna
Old 10-10-2017   #1068
Re: House Projects
So I've gotten sick of the garage layout. Just kinda got shit done and didn't really think it thru very well. So I'm going to try and redo a lot, slowly but surely. We started by adding two windows which I'm in love with. Just lets in tons of natural light and you can open them to help get a breeze going thru the front of the garage. At some point once I clear the wall off in my back shop area, we will be adding a window back there too but not quite yet.
So next up now is the ceiling lighting. The garage came with 3 bulb sockets when it was built. So all I did originally is put in high wattage bulbs in two of them, and the one in my car shop area I put up an old shitty small ceiling fan that I painted black, and has 3 bulbs. The fan is so small and shitty that you don't feel any air movement even if you stand right under it, it's pointless. Then my father in law added some fluorescent lighting on the side walls a couple years back which is kinda nice, but I'd like to do something different I think as I just don't really like how it looks. I haven't completely decided if I'm keeping the fluorescent yet, but for now I am going to just focus on redoing the ceiling lighting.
Buddy with a Supra who lives a couple miles from me, his setup is so nice and sort of motivated me to do something. I did some researching and some shopping and went a lil overboard on the planning/layout lol. I ended up deciding I'm going to install 16 recessed cans in the ceiling. The old 3 bulb sockets will be removed and completely replaced with the can lights. Plus Menards is having a big lighting sale. 8 will go in my shop area as that's what I care most about being well lit. The other 8 will span the 3 stall garage to give it 'adequate' lighting.
So I picked up 4 packs of these:
https://www.menards.com/main/lightin...2225715&ipos=9
The plan is to put them on two switches so basically half of them turn on with one switch, and half with the other, that way if I don't want the lighting completely blasting I can have just half on.
Then, I'm going to add 3 Industrial type ceiling fans (56") to hopefully help keep some air movement going on in the garage. I plan to put all 3 on a single adjustable speed control switch. These are also on sale at Menards:
https://www.menards.com/main/lightin...0210352&ipos=2
I drew up a pretty accurate / to-scale drawing of the garage using SolidWorks. Some things may be an inch or two off here and there, but overall it's quite accurate. It shows the internal sheetrock dimensions, the 6" can placement, their overall beam width assuming 45* beam width and a roughly 11.5' ceiling height. It shows the 3 fan locations as well as stud locations, garage door openers, and garage doors at full up (wanted to make sure the last row of lights wouldn't be covered up even if garage was open).
The interesting thing is I did the math on wattage as I wanted to make sure I'm not overloading my current 15A lighting circuit. Assuming 15A @ 110VAC, I should be OK for roughly 1650W. So to be a little conservative I just said my limit is 1500W. I'll be using LED bulbs which are advertised as 9W (65W equivalent), so again conservative I just figured 10W x 16 bulbs = 160W total. Lol, not even hardly scratching the surface! Then the fans, I'm not completely sure but I believe they'll pull roughly 60W at full speed. Even if they pulled 100W, that puts me at 460W which still is only using barely 33% of the circuits rating. Comparing it to what I'm currently at, I calculate I'm currently somewhere around 700-800W. So overall I think it'll be quite the improvement, and still leaves me with plenty of room to either keep or add some extra fluorescent lighting or something.
So that's the plan, and planning to just do it slowly but surely over the course of winter.
ID:	16781   Click image for larger version
Old 10-10-2017   #1069
Re: House Projects
Very nice project, that'll be cool when its complete. Do you have any attic insulation above there? I'd love to do the same but I have a foot of cellulose type stuff on the ceiling that would make it impossible, or at least really suck. I have the standard three bulbs, and they're CFL so they take several minutes to warm up in the winter. Maybe I should just replace them with 100W equivalent LEDs.
Regarding circuits, they're rated at 80% of the amperage. So you could safely draw 12A on that circuit, or about 1300W.
Old 10-10-2017   #1070
Re: House Projects
Yes it's full of blown in insulation. So I made sure to use IC (insulated ceiling) rated cans. Yes there will be a mess, haha.
Old 10-15-2017   #1071
Re: House Projects
Here's a few before pictures that basically show the garage as it sits today. You can see the two single bulbs up front, and the one bulb socket in the car shop are that I hung a ceiling fan at. Anyway just a record of what it was before. I'll be starting on the new lighting soon.
I ended up buying four 4-packs ($40/ea) and thre 56" fans ($40/ea) and some house wire ($30). So in the end right around $300 worth of material.
ID:	16792   Click image for larger version
ID:	16793   Click image for larger version
Old 10-15-2017   #1072
Re: House Projects
You inspired me to finally fix the dim cfl lighting in my garage, especially with winter coming and those things take a couple minutes to warm up. Nothing major but I bought 1600 lumen led bulbs in daylight color. Garage is twice as bright and I like the cooler color temp for the garage, no need for warm white out there.
Old 10-15-2017   #1073
Re: House Projects
Also Murlo, love the garage layout, looks very familiar
Old 10-16-2017   #1074
Re: House Projects
Friday night's after-dinner fuel for a Saturday of yard work:
Truck-mode (15 of 25 mulch bags):
Doesn't look like an overgrown jungle:
Reward for a job decently done:
Spread out 25 bags of mulch front & back, along with further continued the tree and bush trimming from last weekend.
Old 10-16-2017   #1075
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: House Projects
Cupcake ATM is genius!!
Old 10-16-2017   #1076
Re: House Projects
It's downright dangerous being open 24/7!
Old 10-16-2017   #1077
Re: House Projects
Looking good! TruckSTUFF! Those fries look amazing.
Old 10-16-2017   #1078
Re: House Projects
Some of my favorites! http://jakesburgersandbeer.com/
Old 10-16-2017   #1079
Murlo26
Murlo26's Avatar
Re: House Projects
Thanks! I was looking at your picture and thought that looked familiar haha. I am excited to have enough room in my garage finally (if that is possible).
My house has had a few delays with the permitting process (i hate city workers) but I am getting a walk out basement out of it now so yay.
Old 10-16-2017   #1080
Re: House Projects
You think it's big enough now. But it's just like horsepower, eventually you still wish u had more haha.
