Old 03-05-2009   #101
311evo
311evo's Avatar
Re: Swifty's never-ending project thread!
Lame guy, hopefully you get it all buttoned up soon.
Old 03-05-2009   #102
Got spark and fuel? If you have both and it won't start, the timing is probably off. Mine started without setting the base timing but it was "lined up" pretty well to begin with. More fuel helped though.
Old 03-05-2009   #103
With the adjustment of the cam, pending how far off they were, the base timing could have been thrown off.
Old 03-05-2009   #104
car doesnt fire.......and missed out on some cute as girls....no luck for you lately!
Old 03-05-2009   #105
Check for spark, im assuming fuel is there.. Im sure you will get it figured out!
Old 03-05-2009   #106
it cranks over, but the RPM gauge on the stock tach doesn't work. The RPM's through the AEM is going completely nuts! Something somewhere is messing up, and not telling the correct thing to the AEM which will then tell the MSD and etc what to do.
-A. Swift
Old 03-06-2009   #107
We only advanced the intake cam 4 deg. It is not Stat Syncing so the AEM does not know the engine is cranking over, so we will re load the map and update the firm ware. The wiring for the CAS and all the grounds check out, but I will bring a CAS and my EMS just to be safe.
Old 03-06-2009   #108
When you coming over to hopefully help wrap this bish up!?
Old 03-06-2009   #109
congrats! you got it running!!!!!!
now get a tune
Old 03-06-2009   #110
brando
Drives: gutlass
min cant wait to see this bish out and about
Old 03-06-2009   #111
viridionplague
woot woot
Old 03-06-2009   #112
fucker spoiled it!! I made a short 30 sec video but the sound just SUCKS!! So, if I had a camera i could record a better vid with, i would. I'll just say everything now works after finding some wires shorting out and whatnot. Issue ended up being that the TDC wire on the CAS was grounded out somewhere, and causeing the AEM to go ape shit! So, eliminate that issue, and wow..it runs! idle is now set, and I gotta find the manual for the FJO to hook up 1 more wire for the wideband 02 to monitor on the AEM, and i'll be in business! Wow, it feels good! BIG thanks to John for sticking it out with me, even till 3am, to figure it out!
-A. Swift
Old 03-06-2009   #113
Congrats, can't wait to see some numbers out of it!
Old 03-06-2009   #114
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Woot!!! Way to go swift!
Old 03-07-2009   #115
hippiekiller
hippiekiller's Avatar
Congrats!
Old 03-07-2009   #116
Congrats! Now make more than 509 and spool early! Haha, that would be awesome if you DD this for part of the summer, cant wait to see it!
Old 03-07-2009   #117
well, now that gas won't be 7 bucks a gallon, i think i will DD it more!
-A. Swift
Old 03-07-2009   #118
Good luck, glad you found the problem.
Old 03-07-2009   #119
-A. Swift
Grounding wires and CAS sensor problems? Hmm...
Glad you guys figured it out. That was a late evening for you guys. I was sleeping by 11pm last night.
Old 03-07-2009   #120
Yeah, I was up till 1am last night and I was/am dead tired. I don't know how you dudes can handle that stuff.
