Old 08-02-2009   #1
cman3000
Colin
cman3000's Avatar
100m Running Champion!
Drives: 90 Talon TSi AWD, 73 Datsun 240z w/Built L28
Full Built 1ga Part Out!
Alright, il try this one more time. The way it will have to work is you let me know what you want, paypal me the cash and i will pick it up when i go home home and bring it to the cities. For the bigger stuff or things i will need help taking out (transmission, engine, etc.) we can meet in Brainerd over a weekend that works for both parties and pull the part(s). Pm me for more info.
Front axles - 50
Three Speed Shatter Shield 100
Rebuilt Driveshaft 50
New Carriage Bearings
New Front Hub Bearings & Seals
BRAKES:
Front Baer Brakes with Slotted Rotors - $550
New rear calipers with Slotted Rotors 75
Front Stainless Steel Braided Brake Lines 30
FUEL SYSTEM:
Supra TT Fuel Pump 80
Re-wire fuel pump relay
3" GM MAF
Braided fuel lines(3) - 65
INTAKE SYSTEM:
Bullseye T04B 50 Trim turbo (oil & water cooled, -10an oil drain) - $500
COOLING SYSTEM:
Alumium Mishimoto Radiator W/Slim Fans (One Puller & One Pusher) - $250
6an turbo coolant feed and return line - 70
SUSPENSION:
Suspension Techniques rear sway bar with Urethane Bushings - 40
New Front & Rear Stabilizer Bar endlinks - 35
RO_JA 18" Formula 5 lightweight wheels with 225/40/18 tires. - $700
AUDIO:
Pioneer head unit with detachable face and CD player with remote control,Polk Audio front and side speakers - 220 for it all
GAUGES:
Autometer Phantom:
30psi Boost/Vacuum Gauge 25
Oil Pressure Gauge 25
Volt Gauge 25
Water Temp Gauge 25
EGT Gauge w/sensor 50
125 for all of them
ELECTRONICS:
New small Battery 25
New Alternator 50
New Coil Packs 25
New Ignition Module 25
New Spark Plug Wires and Plugs(BPR7ES) 25
EPROM ECU with Keydiver Chip reprogrammed for the following; 8000 Rev Limiter NO Airflow CAP No Fuelcut Octane Reset Shift CE Light @ 7000 RPM Enhanced closed loop MAPS Knocksum Gauge 1200cc injectors/264us deadtime 3” GM MAFT 850 RPM Idle 45 PSI AFPR 11.0:1 WOT A/F FED/AWD Locked Baro & Airtem 180
INTERIOR:
Corbeau TRS Seats w/1g brackets - $500
cman3000 is offline   Reply With Quote
