Old 06-25-2012   #101
v8klla
v8klla's Avatar
Re: MAPerformance Proving Grounds Weekend @ BIR June 22-24th
Not with an external wastegate under it lol
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-25-2012   #102
MorningWood
Drives: Evo 8, 2014 Silverado
I had a blast, I'm still having shifting issues, but managed to run a 10.41@142.15 and 3rd place in KS/U, Wish I could've gotten some good times during the actual Eliminations though, but my tranny said it just wanted to go home haha
Is it just me or was the racing much better this year than last year?
MorningWood is offline   Reply With Quote
Old 06-25-2012   #103
Tachyon
Tachyon's Avatar
Drives: Icarus
I think it was a lot better / competitive this year. I wish I could have been in normal SA as that looked like a good dogfight!
-Sebastian Vettel
Old 06-25-2012   #104
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I had a blast on the AutoX course, and would like to give CWSCC a shout out for putting together a great AX event! Tons of fun hanging out and partying and watching some drag strip passes as well. I don't plan on missing one of these again!
Old 06-25-2012   #105
congrats on the autox Ryan!
Old 06-25-2012   #106
You got me, I won't have the external gate for stock appearing.
Old 06-25-2012   #107
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Man up, ran SA/U...looked about the same times anyway haha. However Paul did run gimp tune
Sounds like SA/U was under populated.
Old 06-25-2012   #108
Yiddie
Yiddie's Avatar
Drives: 98GSX
http://youtu.be/MvxUqTTkZeQ
Video of the evo crash at the road course.
Old 06-25-2012   #109
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Shitty!
Old 06-25-2012   #110
Murlo26
Murlo26's Avatar
Yea that is crazy...sucks for the owner to lose his evo. Looks like he had new rotors in there...guess his pads/fluid just wasn't up to the task. This is why road racing worries me...not only can i blow shit up, I can crash. Going straight is so much easier haha.
Old 06-25-2012   #111
That was interesting, I was driving the black Evo that turned right after he crashed. I couldn't tell what had happened, I saw the Evo against the wall as I was braking for the turn and then I hit all kinds of water and shit right after the turn that the Mustang had put left when he got back on. The wall the Evo hit is pretty far out there too, farther than it appears to be in that video.
Old 06-26-2012   #112
cmspaz
Walls need hugs too
cmspaz's Avatar
Well, I finally found time to post up...
I was still on my self tune that made 350 at DB on 24psi, so I didn't have a chance at anything super impressive. I made two passes before calling it quits, I hadn't even started dropping my tire pressures from street levels at that point. First pass was a 12.1 @ 117, 1.9 60', had a decent 8th trap at 92mph, then it started braking up in the back half and killed any chance of a good run. I'd expect another couple mph out of it and easily mid 11s on a good launch. Second pass I let the clutch out a bit quick and hopped the crap out of the rear end, and in turn threw away my front half. Ended up running a 12.1 at 116. Coming back down the return lane my first gear was whining super loud under decel and slightly louder than normal while driving, I said fuck it and parked it after that. The hopping must have hammered the coast side pretty good as the tires grabbed and let go repeatedly. Still fine and drivable just loud and annoying. Still on the fence on what I'll do about it.
As for autox, Street Modified (SM) was easily one of the more competitive classes, and I managed 3rd in class, 19th overall, not bad on a fairly passive alignment and continued issues with break-up at WOT.
As it turned out, and I realized this when leaving after checking plugs and everything, that I'd gotten a bad tank of E85 from the Holiday on Xerxes in Brooklyn Center. I know the station has been accepted as iffy at best by a number of people (I myself have noticed extra knock after filling up there), but I just didn't want to go super far out of my way to fill up before leaving. Live and learn though, and I'd recommend avoiding the station at all costs if you can.
It was a super fun and exciting weekend for sure, but I just wish I could have had the car better prepared and had less issues. Hopefully next year I'll have everything squared away, my pile of suspension stuff in the basement rebuilt and in the car, and not break anything for once.
Originally Posted by Trogdor
Old 06-26-2012   #113
Yeah, his angle in to the corner was WAY off. I think he was trying to catch the vette in front of him. I know how it gets when you start seeing red, I laid my bike down doing the same thing on the last turn. Slow in and fast out! Especially with the double apex turns at BIR.
Old 06-26-2012   #114
99gsxjoel
Drives: 1999 GSX
I was still on my self tune that made 350 at DB on 24psi, so I didn't have a chance at anything super impressive. I made two passes before calling it quits, I hadn't even started dropping my tire pressures from street levels at that point. First pass was a 12.1 @ 117, 1.9 60', had a decent 8th trap at 92mph, then it started braking up in the back half and killed any chance of a good run. I'd expect another couple mph out of it and easily mid 11s on a good launch. Second pass I let the clutch out a bit quick and hopped the crap out of the rear end, and in turn threw away my front half. Ended up running a 12.1 at 116. Coming back down the return lane my first gear was whining super loud under decel and slightly louder than normal while driving, I said fuck it and parked it after that. The hopping must have hammered the coast side pretty good as the tires grabbed and let go repeatedly. Still fine and drivable just loud and annoying. Still on the fence on what I'll do about it.e.
Was this in a evo?
99gsxjoel is offline   Reply With Quote
Old 06-26-2012   #115
Dizmm
Dizmm's Avatar
Drives: on ICE
He lost brakes. When that happens you want to early apex and stay on the track as long as possible. He tried to scrub off as much speed as he could which is what you want to do. He probably shaved off 30-40mph by doing what he did.
Glad he is OK.
Having fresh brake fluid (racing fluid) and good pads for big track stuff is very important.
Andy Smedegard
Dizmm is offline   Reply With Quote
Old 06-26-2012   #116
Crazy vid, hope the guy is doing okay. His passenger just walked out like nothing happened, odd lol. Smashing up against that wall did some damage to the driver though Im sure.
Old 06-26-2012   #117
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Holy fak. What turbo setup you running now a days?
5858
Converted to LS
Old 06-26-2012   #118
munchgsx
munchgsx's Avatar
The guy in the evo will be fine. 3 broken ribs and some sort of back injury. He bought that car last Thursday strait off the dyno.
Converted to LS
Old 06-26-2012   #119
cmspaz
Walls need hugs too
cmspaz's Avatar
Originally Posted by 99gsxjoel View Post
Was this in a evo?
Yep.
Old 06-26-2012   #120
cmspaz
Walls need hugs too
cmspaz's Avatar
Also, did some research on the loud whining, it's normal on 8s that get launched and Shep's reported response is that you can replace the gear but it'll just do it again. People have upwards of 50 more passes on these gears with no extra issues or problems, though some report extra notchiness. I'll just rock it until it gets worse like everyone else apparently does.
