Old 02-20-2014   #101
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: Very Bad Vibration
Not yet. Going to grab marks sometime sooon. But with this snow it might not be tonight so I think I may just pull that end cover off and check for play. When I pull it off will anything fall out?
Here's a pic of that drivers axle. I wasn't sure if it was all the way in or not.
BW8776, e-85
Old 02-20-2014   #102
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Looks fine
Old 02-20-2014   #103
mark4g63t
mark4g63t's Avatar
Two of the u-joints feel notchy and one in the middle is very smooth, maybe too loose?
BW8776, e-85
Old 02-20-2014   #104
dsmghost
dsmghost's Avatar
The u joints should move smoothly not notchy or binding. If there is any play in a u joint or they don't move smoothly they need to be replaced.
Old 02-20-2014   #105
mark4g63t
mark4g63t's Avatar
Well hopefully it is just the u-joints! Grabbing marks driveshaft tomorrow and giving that a try. Really hope it's just u-joints.
BW8776, e-85
Old 02-22-2014   #106
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
you're wasting your time on the driveshaft, IMO.
Unless the U-joints are so bad there's side to side/in and out play in the joint, it probably won't be your issue.
Most DSMs driving on the road now (wait... are there any other than mine? have notchy U-joints.
I've taken apart about 4-5 in the last few months and... all were notchy.
Style's automotive engineer
Old 02-22-2014   #107
mark4g63t
mark4g63t's Avatar
I want to make sure before I check the tranny. Don't want to drain/ drop it for nothing.
It just sounds soooo similar to driveshaft thump. I should know in a couple hours.
BW8776, e-85
Old 02-22-2014   #108
dsmghost
dsmghost's Avatar
I agree
Old 02-22-2014   #109
dsmghost
dsmghost's Avatar
Sounds like a thump now? Or is it a vibration/bearing type noise?
Old 02-22-2014   #110
mark4g63t
mark4g63t's Avatar
Will give you guy's an update once I get a car to go get the driveshaft. Taking wayyyy longer than I expected. But I did mention that it sounds similar to this earlier https://www.youtube.com/watch?v=vDl4TCJpgZ8 (45 sec.)
BW8776, e-85
Old 02-22-2014   #111
dsmghost
dsmghost's Avatar
You need drivetrain load to cause driveshaft thump like that.
With your wheels off the ground and trans in neutral, is the disturbance still present at a specific engine rpm? If so does it go away when you disengage the clutch? (pushed to the floor)
Old 02-22-2014   #112
mark4g63t
mark4g63t's Avatar
Only happens while in gear. So if I have it in neutral and rev it everything is fine. Got Marks driveshaft (propeller shaft) and it still happens but it is way less sever. Also now if I have it in a higher gear going slower it will do it more and seems to get better with higher rpm/ speed.
Going to be checking the t-case next.
BW8776, e-85
Old 02-23-2014   #113
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Did you try swapping c/v shafts? Sounds like a bad front axle to me
Old 02-23-2014   #114
dsmghost
dsmghost's Avatar
Ok maintain a specific speed say 40mph does it change severity with different gears all while the wheel speed is consistent?
Old 02-23-2014   #115
mark4g63t
mark4g63t's Avatar
Wouldn't that cause a click or some kind of noise while turning?
Also managed to get a CEL to flash from it vibrating so bad.
BW8776, e-85
Old 02-23-2014   #116
mark4g63t
mark4g63t's Avatar
Ill give that a try
BW8776, e-85
Old 02-23-2014   #117
mark4g63t
mark4g63t's Avatar
Alright so I just drove around for a good while and did all sorts of tests. What I found out was..
While going 30 it was about the worst
While maintaining 40 it seemed to vibrate more rapidly in 5th
Under normal acceleration it was very mild
under about 30% throttle is when it started to happen
*Going uphill was almost impossible without downshifting
1st didn't seem to do it
https://www.youtube.com/watch?v=XHCy...ature=youtu.be
Checked the t-case and it spun smooth no sounds coming from it.
Also checked the transmission output shaft and it was ok.
Going to get a new out axle for the drivers side, if it still does it I will get the pass side as well. If neither of those fix it I will be looking deeper into the trans.
BW8776, e-85
Old 02-23-2014   #118
dsmghost
dsmghost's Avatar
If I were you at this point I would unbolt the t case and set it on the ground then pull the front axles out of the trans. Start the engine and run it through the gears.
Old 02-23-2014   #119
mark4g63t
mark4g63t's Avatar
t-case is already off. Do I leave car off when going through the gears once the axles are out? What would I be looking for when doing so?
BW8776, e-85
Old 02-23-2014   #120
dsmghost
dsmghost's Avatar
Start the car and do what I said. If the disturbance is still there you know it has nothing to do with anything past the transmission.
