Old 12-17-2006   #121
Re: the evo 3 swap parts are coming
that is the plan
I will use the compleat motor and the tranny and sell the rest off
Old 12-17-2006   #122
I will post up all the parts that will be sold as soon as it show up on tue
the only thing that is sold as of now is the fmic and piping to my buddy kevin
Old 12-19-2006   #123
pics of the 5zigen stering wheel that came from japan the guy also sent me a real blitz horn button
Old 12-19-2006   #124
Funny, that is identical to my Momo wheel. Writing is even in the same place.
Old 12-20-2006   #125
the front clip came to day
we were safer taking this one off. we had one of are accounts come up with ther flat bed and take it off the semi and drop in the shop.
Old 12-20-2006   #126
this clip came with a snap-on key
got the hks short shifter in my car
the drive shaft just have to bolt it back together
Old 12-20-2006   #128
they are only sold in japan
Old 12-21-2006   #129
got some more done to the car and the clip
dash is in the electronic heater and a/c controler works
Old 12-21-2006   #130
got parts off the 2nd clip,also stared on the awd swap
Old 12-21-2006   #131
more of the mirage rear, gas tank is out I will be reusing it be hind the rear end,stock rear suspention is out.
Old 12-21-2006   #132
used the plasma cuter on the trunk floor it was all out in under 10mins
Old 12-22-2006   #133
got the rear end in today the back hole was there for the awd subframe. I had to drill the front hole and make a frame to frame brace to the front of the punken.
Old 12-22-2006   #134
cut open the frame rail to put the bolts in and tacked them in so they will be solid and I hate trying to weld rust at least it just to hold them there
Old 12-25-2006   #135
got some more done today. I will post up the pics as soon as I have time
Got the motor and tranny out of the clip got the tranny off and the car had a 3puck clutch and a jun flywheel so I will be putting on my jun fly and act 2100 so the wife can drive it also. Also checked out the tranny and it has a cusco lsd in it and the the rear end has a cusco lsd in it too. so just off those parts I realy got my moneys worth of the 2nd clip.
Old 12-25-2006   #136
pics from yesterday
first 4 got it on the ground and started to make the trunk floor we are working with the metal we have at the shop so I dont have to buy any.
Old 12-25-2006   #137
Sweetness. The orange really sets it off but I recommend continuing that theme over the whole car then painting "01" on the side.
Old 12-25-2006   #138
got the motor on the stand and took a look at it also to make sure. put a new water pump on it and a B.S. kit still have to go to mitsu to get the pump gasket and a multi layer head gasket and in stall the arp head studs. Also a pic of the front cip that will be soon cut up and be sold for a rhd swap for a 4g mirage.
Old 12-25-2006   #139
pic of the jun flywheel and 3 puch clutch that came out of the clip and the jun flywheel I already had and the 2100 that will be going into it.
Old 12-25-2006   #140
the metal is from a old battery rack that we had it is red. I will be painting the trunk with the same black I did the enging bay and make som panels for it to make it look nicer when it is done
