Old 03-29-2011   #121
Re: Finally got my Evo
Tune just got moved up a few days. Was scheduled to go in on the 22nd, I'm now going in on the 18th.
Apparently some über rich dude is flying a tuner in for the day and renting DB's dyno for the whole day to get his BMW tuned. Shane, Danny, and the crew have been awesome to me over the years, so I gladly moved up the appt. for them. This way I can get some E85 action 4 days earlier anyways woot!
Old 03-29-2011   #122
Yea, there was a short while where I wanted to give up, then the $376.70 price of a new front o2 sensor crossed my mind O_o
$50 Bosch universal 4-wire works perfectly. Otherwise OxygenGeeks has a direct-fit for ~$60.
Old 03-29-2011   #123
Another thing I forgot to mention was the Synapse BOV. When I installed it, I was having some pretty bad surge around 4k rpm and up. I followed the directions I found from other people running it and Tee'd in the C port to the Compressor housing/MBC line, and the A&B ports in a Y connector and ran that to the stock BOV vacuum connection that runs along side the valve cover. This morning I decided to experiment a little with different ways to route the A & B ports. Some people were having better results only using either the A or B port with the other open to atmosphere.
First I tried running only port A. it felt good, there seemed to be a little 'leak off' of boost(for lack of a better term I guess) in partial throttle acceleration, but almost no surge.
Second I tried port B. There wasn't as much boost 'leak off', almost none actually, but the surge was back just like when I had A&B hooked together.
I decided to run port A to the stock BOV vacuum location and feels good. MUCH less surge than with the stock BOV in high gear (5th and 6th mainly) while at low speeds. Overall, for $80 spent on the thing I am happy with it so far.
Thanks! I'll keep that in mind if mine goes out
Old 03-31-2011   #124
Deleting rear o2 soon, just putting these links here for my reference:
Patch:
http://forums.evolutionm.net/6691277-post59.html
Entire patch thread:
http://forums.evolutionm.net/ecuflas...m-patch-2.html
LC-1 Wideband logging:
http://forums.evolutionm.net/ecuflas...ial-cable.html
AEM Wideband logging:
http://forums.evolutionm.net/lancer-...o-evoscan.html
Old 03-31-2011   #125
Jungy
Jungy's Avatar
Old 03-31-2011   #126
Awesome thanks!
Old 04-01-2011   #127
Patch:
Ok, when I click on the above link which I have labeled "patch" it brings me to the thread, I click the link, do the download using WinRAR, open the xml file and it gives me like a half of a webpage with an error. The only code I see is:
<table name="Rear O2 Heater Patch ROM Addr" category="Front/Rear_O2" address="2dc50" type="3D" level="1" scaling="H...
Is there more to the code I would assume? It looks like it was cut off with the "..." at the end. Does anyone have the whole code they can just copy and paste for me? Hughes, scheides either of you guys still have any of your old roms? Shane? Anyone? lol
If I can't figure it out, I'll just say screw it and do the 10kohm/.25 amp resistor all old skool like.
Old 04-01-2011   #128
cmspaz
Walls need hugs too
cmspaz's Avatar
Can't you just turn on the rear O2 simulator in Tephra?
Originally Posted by Trogdor
Old 04-01-2011   #129
Yes, but you still have to deal with the O2 heater CEL as well
Old 04-02-2011   #130
Open the XML files with notepad or a basic XML editer, not a webbrowser.
If you have any current version of tephra, it will have the rear o2 sim patch (and be an option under tephra options). Then for an IX the rear o2 heater bypass is just a simple bit change....look for a thread by mrfred titled something like 'looking for an Evo ix owner to test...' and look for some confirmation posts by me for it working on Hughes or rosey's car. Lmk if you can't find it.
Edit, posting from phone sorry, looks like above link is right!
Old 04-02-2011   #131
That seems to have done the trick! I opened it in wordpad and got the text below. Look right?
I have tephra v5.10 right now btw, and this is what the front/rear O2 table look like. Look right also?
(obviously leave out the top like between the asterisks)
<!-- ** Rear O2 Heater CEL Fix ** -->
<table name="Max RPM To Rear O2 Heaer OBD Reset" category="Front/Rear_O2" address="8746" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Rear O2 Heater Patch ROM Addr" category="Front/Rear_O2" address="2dc50" type="3D" level="1" scaling="Hex16">
<table name="Code" type="Static X Axis" elements="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="2">
<data>2DC50</data>
<data>2DC52</data>
</table>
</table>
<table name="Rear O2 Heater Patch" category="Front/Rear_O2" address="47e30" type="3D" level="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="40">
<data>47E30</data>
<data>47E32</data>
<data>47E34</data>
<data>47E36</data>
<data>47E38</data>
<data>47E3A</data>
<data>47E3C</data>
<data>47E3E</data>
<data>47E40</data>
<data>47E42</data>
<data>47E44</data>
<data>47E46</data>
<data>47E48</data>
<data>47E4A</data>
<data>47E4C</data>
<data>47E4E</data>
<data>47E50</data>
<data>47E52</data>
<data>47E54</data>
<data>47E56</data>
<data>47E58</data>
<data>47E5A</data>
<data>47E5C</data>
<data>47E5E</data>
<data>47E60</data>
<data>47E62</data>
<data>47E64</data>
<data>47E66</data>
<data>47E68</data>
<data>47E6A</data>
<data>47E6C</data>
<data>47E6E</data>
<data>47E70</data>
<data>47E72</data>
<data>47E74</data>
<data>47E76</data>
<data>47E78</data>
<data>47E7A</data>
<data>47E7C</data>
<data>47E7E</data>
</table>
</table>
If the above is hard to read, the 2DC52 table under rear o2 heater patch reads : "4C10"
Old 04-11-2011   #132
Got the Map switch mostly installed yesterday, I couldn't seem to get the stupid ECU pin to push in, tried everything. I'll just see if Shane can get it in there.
Everything else is in order, I just have to boost leak test and change the oil some time this week and I'm ready to rock and roll! 7 days til E85
Hopefully my throttle body shaft seals don't leak. I have new ones to put in, but no TB gasket.
Also, while I was doing a few small things, I cleaned the black crud off my valve cover that would never come off, and I decided that the lettering was a little on the bland side. So I took the paint off the letters and polished them
only took about 30 minutes, maybe some day when I have nothing else to do I'll re-do it and get a real high gloss shine to it.
Old 04-17-2011   #133
Changed my oil on Wednesday with some Amsoil 10w40 High Zinc. Thanks again for that Kerry.
Did a boost leak test today. Throttle body seals leaked like a mother, Troy and I swapped those out which took forever and a freakin day thanks to one being stuck in there like crazy. Finally got the high pressure seals put in, tested it again, replaced the two evap lines (I'd like to get rid of them someday, but just keeping it simple for now) zip tied both EGR lines while I was in there also, and tightened some clamps here and there. There wasn't any real major leaks, it kind of holds 15psi which is all I could get with the janky little setup I had to work with. I think it will be fine though.
Bring on teh corn!
Old 04-18-2011   #134
cmspaz
Walls need hugs too
cmspaz's Avatar
See if Shane'll let you do a test with their equipment while the car gets strapped down, we got mine to hold 27psi steady after a bit of zip-tying.
Old 04-18-2011   #135
simulatedwood
Drives: 08 Evolution X
Nice work GoodHart, smart to get all that done, should save you some money in the long run. Good luck today, it is going to be a new level of fun at the end of the day.
Shawn
Old 04-18-2011   #136
LingLing
AznKraut
LingLing's Avatar
Props for taking care of the small shit that many people would put off. I'm sure your hard work will pay off on the dyno! Good luck!
Old 04-18-2011   #137
Didn't have much to work with yesterday, but I made due haha.
destroyed the throttle body shaft seals taking them out:
Old 04-18-2011   #138
Woot for parking lot maintenance and woot for being on top of that maintenance in the first place! Looking forward to what comes next!
Old 04-18-2011   #139
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Graphs! We demand graphs.
Old 04-18-2011   #140
FUCK. I seriously just typed a god damned novel, then my internet failed on me and I lost it all. Fuck it, here are the graphs.
91 octane tune:
E85 tune:
Shootout:
Very happy with the results btw, I just hate my interwebz right now. Maybe later I'll write it all over again.
Relevant mods:
Invidia 3" TBE
Megan o2 housing
OBX FMIC
Injen intake
Injen UICP
Nisei LICP
Walbro 255HP
FIC 1350's
Grimmspeed MBC
Synapse BOV
Exedy HD Twin Disk
Shane tune
