Build the X 17 56.67%
Old 03-24-2011   #1
In for long runner info.
Old 03-24-2011   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Here is a little info....it's an overlay of boost logs from my car. One is from last October on the stock ported mani, one is from last night with the long runner. Both are my "track tune". The numbers should be pretty close as the baselines were spot on for my regular tune with the stock mani this week vs last october (within 1hp).
Numbers for stock ported were - 564whp/464wtq.
Numbers for long runner were - 562whp/465wtq.
So basically the same damn numbers at way way less boost...next step...bring the boost back up
Old 03-24-2011   #3
LOL
So how did the MAP long-runner compare vs. the FiD and MAP short-runner?
Old 03-24-2011   #4
Murlo26
Murlo26's Avatar
I could post boost plots of all of them if you want. I don't have all the dyno graphs yet though so it will be tough to say numbers wise.
The FID did provide the least amount of gain over any of the manifolds on the normal tune. But boost was a tad lower. still not near as low as the long runner though.
Old 03-24-2011   #5
FWIW when we were tuning my car on the first pull made almost the exact same power as it did last summer, ~340whp, but at only 20psi vs the 28psi it ran last summer. When we turned the boost back up the car hit 400, but with more taper i.e. more to go.
High hopes for this retune are certainly worth having!
Old 03-24-2011   #6
Murlo26
Murlo26's Avatar
So basically exactly what I am seeing
I might be trying your MBC/3 port setup to reduce wastegate duty cycle up top to see if we can get more outta it. I asked Shane what he thought was the best option, MBC, Forge wga (which i know he hates, but has a 25psi spring) or cranking down my blouch one more on the preload as it has lots of thread for preloading.
Old 03-24-2011   #7
Murlo26
Murlo26's Avatar
well here are general spool numbers. I don't have the numbers to go with each of these runs so its hard to say anything conclusively, but here are the rough spool numbers. (I kinda chose them at random from the groups of runs).
Old 03-24-2011   #8
Any pics of this MAP prototype? When you refer to long-runner, that is Scheides' old one, right?
Old 03-24-2011   #9
Murlo26
Murlo26's Avatar
Correct.
No pics, I suppose I should've taken a few, but the prototype one might be a one off so I didn't want to take any pictures. I am sure Chris could get you a few pics though.
Those are .5 psi tick marks too on the graph, not 1psi...so you can see that both MAP longer runner type designs were quite a bit lower on spool up.
Old 03-24-2011   #10
v8klla
v8klla's Avatar
By lower are you referring to the initial boost spike? It appears that boost on both MAP long runner manifolds was lower throughout. Numbers coming soon!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 03-24-2011   #11
These manifold comparisons are getting old. You tune for the setup, not for the part. You could have two identically built cars and the tunes between them will be anything but identical. It might be apples to apples, but comparing Red Delicious to Granny Smith is silly. One is good for eating, the other makes great deserts. It all comes down to the application and ingredients.
Old 03-24-2011   #12
Murlo26
Murlo26's Avatar
Yes the boost spike, which tends to carry power through the rpm range better. But overall boost was typically lower on the long runner designs on all the runs.
I could go for some apple pie, sounds yummy.
Old 03-24-2011   #13
v8klla
v8klla's Avatar
You're certainly entitled to your opinion (which I agree with to an extent, every car is different), but if you recall I was all but forced into this round of testing
P: 763-545-3800
Old 03-24-2011   #14
And imagine that, your product performed the best at your facility. Shocking.
Old 03-24-2011   #15
v8klla
v8klla's Avatar
And we (MAP) didn't touch a laptop throughout the entire process, can you imagine that? We did turn up the heat in the shop to approximately 150 degrees during the FID testing though
P: 763-545-3800
Old 03-24-2011   #16
mlomker
*Resting In Peace*
mlomker's Avatar
Old 03-24-2011   #17
Murlo26
Murlo26's Avatar
If you want to get technical...the short runner that they don't make performed by far the best overall on the actual testing. Best spool/most power.
Old 03-24-2011   #18
If that is the one listed as "MAP Short Runner" above, then it was also making the most boost.
Old 03-24-2011   #19
Murlo26
Murlo26's Avatar
Indeed, which is why this test can never be perfect no matter what you do.
You either change the tune to get the boost and everything as close as possible or you do what we did. I think both have advantages and both have shortcomings.
I don't think either is better than the other.
But the short runner is still running comparable boost to the baseline which is what matters.
Old 03-24-2011   #20
311evo
311evo's Avatar
Close no doubt, but 2psi can make 20hp difference at your power level.
Tags
