Old 04-13-2012   #141
URV8SUX
URV8SUX's Avatar
Re: Mark's 1G Winter Projects
Originally Posted by munchgsx View Post
Blue is the EVO
Red is the 1G
Green is LaCroix's Galant
Holy shit I wonder what the red graph would do at 10psi cause it make 800 with .65psi!!!!!!!
Old 04-13-2012   #142
Mark Leasure
Mark Leasure's Avatar
Originally Posted by Revobasher View Post
So you are on stock transfer case and non built trans still on Evo?
Built ultimate ration trans from Jacks with a 4.11 final drive. MAP spec beast mode Xfercase with a wavetec front diff.
Old 06-06-2012   #143
Mark Leasure
I’m not going to count on an upgraded T-case anymore. The 1G should make it to the MAP proving grounds with a stock transfer case! I just ordered my yoke conversion to adapt a factory case to a HD DSS 3.5” drive shaft. The off the shelf format from DSS is meant to only work with an upgraded T-case.
Now I need to:
· Tear into the motor to take out the BC280 and install the GSC S3’s
· Replace the timing gear and the keyway on the crank since last time the keyway groove was worn.
· Remove the upgraded TX-case that grenaded.
· Install the new fabricated yoke and factory Tcase.
· Street tune WOT (hopefully the cams will help hold power out further in the band)
The car should be running in a week or two, as normal in the nick of time for the event!
I’m sure it will be hot off the street onto the trailer and heading out to BIR.
Happy days again! Just shooting to get one clean pass in, haha.
Old 06-06-2012   #144
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice! glad to see you're still planning on rocking the 1G at the PG!
-Sebastian Vettel
Old 06-06-2012   #145
Awesome. Good luck those GSC S3s are sick, you should be happy with those.
I hope you get more than one clean pass.
Old 06-06-2012   #146
Damn that sucks your t-case puked on you. Good luck at BIR.
Old 06-06-2012   #147
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Good luck!!!
I also picked up those cams so it will be good to hear what you think. Obviously my setup isnt the exact same but still cool to see what I can expect.
Old 06-06-2012   #148
mondale
Drives: 1g dsm
Good luck!!!
Copious amounts of airflow lol.
8.59 @ 158
mondale is offline   Reply With Quote
Old 06-07-2012   #149
santa
Boost Spike
santa's Avatar
If you need a lap top holder for those wot pulls, im your guy!! Good luck Mark!! Hopefully we can line up against each other and confuse everyone which car is which!!
Old 06-08-2012   #150
Mark Leasure
Sounds good to me! How's your car coming along?
Old 06-08-2012   #151
santa
Boost Spike
santa's Avatar
Driving it up to map in a few minutes to have the nhra chassis inspector check it out. Hopefully it should pass with flying colors. Let me know if you need a hand with your car!
Old 06-09-2012   #152
Mark Leasure
Good thing I decided to do a cam swap, I found 3 of the 5 nuts on my adjustable cam gears were finger tight. The shield plate that attaches to the head had one of the small fasteners ready to fall out. Who knows another couple of miles and the whole motor could have been F’d. Now the cam gears have Locktite Red applied.
The idle is a little rougher, not too bad though. You can physically see the difference in the cams when you set them side by side with the S3’s. The S3’s are monsters. I wish I could have done them when I built the motor, since I’m a little concerned about valve to piston clearance. I’m just going to let her buck and see what happens. I took the car around the block in front wheel drive mode and the tires break free at about 15 psi making the care useless. Now I know why transfer cases take so much abuse, it’s like the front have no aid in the traction department. These 1G’s are closer to rear wheel drives.
Now I just need to get the transfer case in it and tune it up, should be exciting!
Old 06-09-2012   #153
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Woo! Good to see a few cars getting ready for proving grounds! I'm excited to see you and Kevin both make some passes in this year. We have to have some fast cars around here, seems there's quite a few really quick 1g's nationwide this year.
Old 06-11-2012   #154
Most after market pistons have enough room with a 1mm over valve.
Old 06-11-2012   #155
Mark Leasure
Good to know John, I took a compression check after I smoked the front tires to almost 8k. All is good!
Old 06-14-2012   #156
Mark Leasure
I took out the broken transfer case and replaced it with a factory one. Now it's just a matter of some tuning and an oil change to get the new cams dialed in.
Pic of the broken case:
Old 06-14-2012   #157
Because Racecar.
Old 06-14-2012   #158
HOLY
Glad you are getting it all taken care of though
Old 06-15-2012   #159
I think you need one of these haha
Old 06-15-2012   #160
He needs the race version fool!
That thing is $350!
