Old 03-03-2013   #141
Re: 1g 6 bolt 4g63 tsi build
Do it!! The only regret you'll have is wishing you'd have done it sooner
Old 03-03-2013   #142
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Originally Posted by dsmghost View Post
I'm not, I'm unsure if I'm going to. The car is ready to run e85 though.
Theres no reason not to.
2006 WW IX RS 396/404 - SOLD
Old 03-04-2013   #143
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
I just feel like I would have to go way out of my way to fill up. I don't pass any e85 stations on my way to or from work. Definitely would like to but seems like a hassle.
Old 03-04-2013   #144
Dude, we have more e85 than any other state! To drive an extra mile or two to fill up is definitely worth the extra 100hp!
Old 03-04-2013   #145
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
I have to agree with Goodhart, theres a buttload of E85 here
Old 03-11-2013   #146
dsmghost
dsmghost's Avatar
Well, today I pulled the fuel pump to do a complete rewire. I found a Walbro 190 not a 255 like I thought I had in the tank. So I put the rewire on hold until I pick up a new pump.
Old 03-11-2013   #147
dsmghost
dsmghost's Avatar
Ok I ordered a 255hp fuel pump, went ahead and did the rewire at the connector. When I get the new pump, I'm going to rewire it down to the pump and run a new fresh ground from the pump.
Old 03-14-2013   #148
dsmghost
dsmghost's Avatar
Got the new walbro installed after work today.
Old 03-14-2013   #149
Hah wow, wonder if that's the one I installed way back when. I didn't go with a full 255 because it wasn't a race car (LOL) and I wanted to keep it simple on the street.
Old 03-14-2013   #150
dsmghost
dsmghost's Avatar
Yeah not sure, oh well. Glad I handle this before going in for a tune. It was pretty loud and since I was told it was a 255 I never questioned it. But I can't believe I didn't do this earlier, especially the rewire.
Old 03-16-2013   #151
dsmghost
dsmghost's Avatar
Installed braided stainless fuel line from the tank to the rail with -6an fittings and a fuelab filter today. Ill get more pics up later.
Old 03-16-2013   #152
Fran05
Drives: DSM
Nice! Waiting on dyno #'s!
Old 03-16-2013   #153
Why the line from tank to rail?
Old 03-16-2013   #154
dsmghost
dsmghost's Avatar
Since I've started driving the car there has always been a fuel smell but no major fuel leaks. I finally got around to fixing it, it turned out I had a few issues. The sending unit had no gasket and half the studs on top are broken off. Also, the hose section was seeping at the crimps. I decided to just replace it all and make it look better too.
Old 03-17-2013   #155
Ah, good call. Yea when the car got parted I didn't recall what pump went back in. I thought I had a 255 before I went to the double pumped setup? When parting a car, fixing bad gaskets and such aren't really top priorities, I just wanted to get rid of everything.
Anyways, glad you got it all sorted out and are doing things the right way! This thing is def headed in the right direction.
Old 03-25-2013   #156
dsmghost
dsmghost's Avatar
Pic of the new fuel line/ filter, today ill be installing a prosport fuel pressure gauge, and a prosport egt gauge. Ill post pics after install.
I don't get why these pics keep loading sideways.
Old 03-27-2013   #157
dsmghost
dsmghost's Avatar
Install of the EGT gauge and sensor was a breeze thanks to a previously tapped manifold I bought from Carltalon a few months back. The fuel pressure gauge install went well too, except it reads 10psi high. I contacted prosport and ill be measuring the resistance of the sensor tomorrow to test it. I like the how the gauges are either white (daytime), or blue (nighttime). I wired them so they come on white, I hit the fog light switch to change to blue.
ID:	13448   Click image for larger version
ID:	13449   Click image for larger version
Old 03-29-2013   #158
dsmghost
dsmghost's Avatar
Just put in this vent pod, holds my boost and wideband gauges.
Damn phone uploading pics upside down
Old 03-29-2013   #159
dsmghost
dsmghost's Avatar
Also, my brand new Prosport fuel pressure gauge reads 10psi high, I tested the resistance of the sending unit and was out of spec. Prosport shipped a new sending unit today.
