Old 02-22-2013   #141
tmosser
Drives: 06 Evo IX
Re: Rebuilding motor, need suggestions
Well since wesico makes 2.3l pistons in std size which is what I wanted. But itll prob need a bore to get everything straight
14 PB GSR
tmosser is offline   Reply With Quote
Old 02-22-2013   #142
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Aint nothing wrong with a 2.3. I'll be joining you someday if you do
2006 WW IX RS 396/404 - SOLD
Old 02-23-2013   #143
tmosser
Drives: 06 Evo IX
Since talking with a couple friends, coming to conclusion no one knows or will know how long the motor has had thrse low numbers (ive seen posts from 09 than 2010 on this motor showing weird numbers from chucke) im going to install new plugs and a diy cop set up I bought from troy, new air filter and a gs 3port ebc and take it to shane within the next two weeks and get it tuned. If it makes power im just going to leave it alone if its a dog ill rebuild it. So the dyno will be my truth moment.
14 PB GSR
Old 02-23-2013   #144
After having a 2.4 I would never go back to a 2.0 on a street car. My 2 pence.
Old 02-23-2013   #145
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
2.4 is beast on streets. Just cruising out of boost was awesome.
Old 02-25-2013   #146
If your motor has some decent miles on it or it needs to be bored, then you can't use std size pistons.
Old 02-25-2013   #147
tmosser
Drives: 06 Evo IX
Shane, after talking with a couple people I have another option of just getting it tuned seeing if it makes power than go from there. Even though it has low compression if it made descent power what do you think? Id like to make the car last till next winter so I can save up money for a rebuild but I dunno if itll make it all summer.
14 PB GSR
Old 02-25-2013   #148
Don't beat the hell out of it and it'll probably be fine; or do beat the hell out of it and add oil if/as needed.
Old 02-25-2013   #149
tmosser
Drives: 06 Evo IX
It doesnt use any oil in between oil changes
14 PB GSR
Old 02-25-2013   #150
Then you're worrying about compression numbers that a beater-DSMer would die for
Old 02-25-2013   #151
tmosser
Drives: 06 Evo IX
You sure make me feel better about this. Lol
14 PB GSR
Old 02-25-2013   #152
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Took a look today, results are kinda screwy:
Compression: 130 110 86 121
Leakdown: 18% 23% 33% 20%
This is using my cheap harbor freight leak down tester, I usually remove about 10% from the leak down results.
Edit forgot to add: leak down on #3 was *really* hard to tell where it was going. Maybe rings but sound in the valve cover was ever-so-slight.
I hope a beater dsmer doesn't hope for those #. 1 of those #'s are within the serviceable limit.
But not burning oil between oil changes that's a different story
Old 02-25-2013   #153
It was a joke, but we all know of at least a few beater DSM's running around with all holes <100!
Old 02-25-2013   #154
tmosser
Drives: 06 Evo IX
So your saying itd good? It really dont I daily the car and change oil at 3/4k and i dont have to add any in between. I use 10w-30 ams oil synthetic.
14 PB GSR
Old 02-25-2013   #155
I wish I would of ran my old motor that tested out similar to that, but the low cyl. was a bent rod.
Old 02-26-2013   #156
Not at all, not even close, but if it's running OK and you're fine with it as-is then just keep driving it until you can afford to rebuild the engine.
Old 03-03-2013   #157
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
http://minneapolis.craigslist.org/hn...654032654.html
Old 03-03-2013   #158
tmosser
Drives: 06 Evo IX
I just said screw it and bought a motor from topspeed performance. And a twin disc rebuild from map. So everythings good. Now just need to figure out what im doing with my old motor.
14 PB GSR
Old 03-03-2013   #159
4seasons69
4seasons69's Avatar
A stock motor or built motor?
Old 03-03-2013   #160
Who is Top Speed and what made you decide on them?
