Old 06-15-2012   #1
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
I remember splitting the front of my case in half at the shootout, but mine wasn't nearly that bad. You know you're supposed to get out of it when smoke and parts start flying out, don't you?
It sounded like a shotgun went off in the car, I was scared out of it!
Old 06-25-2012   #2
Mark Leasure
New great passes at MAP PG 2012, maybe I will keep it a 5 speed
I cut high 1.4 60ft on each pass
http://www.youtube.com/watch?v=-Aileo2urTI&hd=1
and
http://www.youtube.com/watch?v=TdCATTzpPEc&hd=1
Old 06-25-2012   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Nice. You gonna keep the stock t-case in there now?
Old 06-27-2012   #4
Mark Leasure
No way! I'm still looking to get an upgraded one made, a couple of companies still do the old school upgrade where they bore out the tail shaft factory gear and e-beam weld a larger tail shaft to it.
Old 06-25-2012   #5
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
nice runs :drool:
2006 WW IX RS 396/404 - SOLD
Old 06-25-2012   #6
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
wow, that thing is moooooooooovin'!
ლ(ಠ益ಠლ)
Old 06-25-2012   #7
God damn, that is awesome. Congrats on getting some solid runs in.
Old 06-27-2012   #8
Get the brace and rock the stocker till it breaks!
Old 06-27-2012   #9
Mark Leasure
The shock load on everything else takes a beating when the T-Case blows up. I would rather take it safe, since the car is shifted. Auto's can get away with stock cases.
Old 06-29-2012   #10
Mark Leasure
I don't know what the guys name is, but he put his go pro in my car.
http://www.youtube.com/watch?v=G8B81d60fos&hd=1
www.maperformance.com
Old 08-07-2012   #11
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
That guys name is AJ. Or capinoy123.
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 06-27-2012   #12
Good job Mark!
Old 06-29-2012   #13
Did your gauges go back in when you hit the brakes? HOly crap.
How fast was that run because the 2g was moving!
ALso I didnt know that you run a 2.3, i need to talk to you when I build a motor.
Nice run.
Old 06-29-2012   #14
Mark Leasure
Nice run.
Yep 2.3L. I was totally asleep at the line, and his car is bat shit crazy fast!
Old 06-29-2012   #15
mondale
Drives: 1g dsm
Nice runs mark! That video shows really how fast Devin's car is, because you were hauling ass in the first place.
8.59 @ 158
mondale is offline   Reply With Quote
Old 06-29-2012   #16
You are such a damn rip! Car just does work nonstop, crazy fast.
Old 07-05-2012   #17
test post.
Old 07-06-2012   #18
Mark Leasure
Time Slip:
Old 07-06-2012   #19
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Time Slip:
You did take a nap on the line!
Old 07-17-2012   #20
Mark Leasure
Yes Jim, sleeping at the line, my 9.40 was a .68 reaction time. In the final my reaction was 1.4 lol. I have a lot to improve on with pro trees! This is an easy thing to fix.
So what's next with my talon? Well I might as well make the car faster, so I'm going to put it on a diet and set a goal to remove about 150-200lbs! This should make it much faster.
1. First off I'm going to install the light weight STM brakes up front. Un-sprung weight is king!
2. My father in law has a CNC in his garage and is going to scallop and drill rear OEM rotors.
3. Next MAP helped me source some Flex a Lite Lexan molded glass in the rear of the car.
4. I will also put a new fuel cell in the car, going with a 5 gallon model instead of the 16. I typically race with about 8-10 gallons to avoid cavitation on the deceleration, since the tank is only like 10 inches tall.
5. Fuel Lab fixed and upgraded my fuel pump from the 1500hp to the 1800hp version.
6. I have the new upgraded transfer case on the way.
7. I'm going to gut the front doors, remove the carpet, door panels and center console.
8. Over the winter I will take more extreme measures on weight reduction, but still keep it a street capable car!
I’ll take some pics as I go. Should be fun, I will be getting out to the track before the end of the season. Stay tuned!
