Old 10-26-2012   #161
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: 2012 Fall Dyno Day - October 20th - MAPerformance
Yep, my car was a lot closer to ~31.5 not ~33.5. I believe Jordan told me last time I was at MAP that this was happening too.
Old 10-26-2012   #162
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
I forgot about that too. My dad said my car was right at 40psi when he hit it on the way home. The last time I was at MAP before this the dyno sheet had a couple more psi than what it actually was.
Old 10-26-2012   #163
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Ok good to know that it was not just me.
Very pimp that you drove up, what is your setup?
I'd guess an old 61mm? or new 5858
I don’t have a built thread.
Basic run down of the dsm.
its a precision t4 6262 .58
dnp manifold
44mm tial wg
bc 280/280cams
bc springs and retainers
aem gears
head is ported.
Cometic hg with standard arp studs.
SMIM q45 90mm tb
fic bm 1450cc inj on e85. 81% injector duty cycle @ 36psi.
Twin wally 255's in tank -6an feed. to a fuel lab ss micron filter
omni4bar/gm iat
Tuned on ecmlink v3
shep trans act clutch/flywheel
off the shelf weisco/eagle bottom end 8:5:1 comp .40 over arp hardware
ETS race fmic 3.5'
ksport coils
Should bring it to the shootout this year and get in the Q16! Car was clean man. Makes me want to sell the dsm and put the coin into my evo haha.
dsmolition is offline   Reply With Quote
Old 10-26-2012   #164
That is the turbo I wanted to go with, I'm surprised by spool and power. I thought spool would be a bit quicker and you would of made more power.
Nice setup though.
Old 10-26-2012   #165
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Nice setup though.
yeah, should of gone t3 i know haha.
Old 10-26-2012   #166
Tachyon
Tachyon's Avatar
Drives: Icarus
Now that Aaron mentions it, your TQ numbers do seem a tad low for that PSI level. What fuel and total timing advance are you running?
-Sebastian Vettel
Old 10-26-2012   #167
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
17° up top. Fuel varies from e77-e80 is the highest I tested it this summer I know my #3 cyl is a little lower on compresion then the others.
Old 10-26-2012   #168
The people around Des Moines never ever ever do anything worth the drive.
I know, it sucks. This is why I still drive up for every MitsuStyle cruise and try to make it to dyno days. I really wanted to make this one but had a race last weekend.
Where do you live in Iowa? I live in Des Moines.
Old 10-26-2012   #169
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
I live north a hour and a half (mason city area)
Old 10-26-2012   #170
Nice setup though.
Spoolup and torque don't look that weird to me for a 2.0l. I think most 2.0l DSMs I get in here that have a tubular manifold and decent sized cams and a 61mm or bigger turbo don't hit 30+psi until past 5000RPMs.
Old 10-26-2012   #171
No way, from what I've been told it isn't that at all. That is the exact turbo I wanted until I decided 5858 recently.
I guess the only way to tell would be to switch, but I don't know all the guys saying to go T4 have been around for a long time and the spool should be that bad compared to a T3.
I wonder if its those cams, there are like an on and off switch.
Old 10-28-2012   #172
You are right sir, good point I'm use to seeing everyone with a stroker motor these days.
Old 10-29-2012   #173
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Yea a 2.0 at 8:5:1 compression. I wish I would of degreed in the cams. Know there is more power to be made by doing so so especially on those cams. But owell.
