Build the X 17 56.67%
Old 11-06-2011   #1821
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I have no money or desire to fix it now. It'll get done first thing when snow melts.
Old 12-27-2011   #1822
Murlo26
Murlo26's Avatar
So Sunday I finally got my lazy ass in gear and pulled my battery out for winter like 6 weeks after I put it away lol. It was dead but I bought a new smart charger that has it all charged up now and is in trickle mode now. I hope it didn't nuke the battery like last year (been traveling for work the last 4 out of 5 weeks and just didn't have much time). Last year I never unhooked it and the battery died and could not be brought back and I had to buy a new one. I have the AMS small battery, which is not great for leaving hooked up over winter obviously.
So I also forgot I got these back before I put my car down for winter (stock OEM idler pulley's).
What do you guys think? Reuse? These are my original OEM ones, they are worn and my fingernail hits the grooves but not too terrible. But I am not sure what bad ones look like. Obviously I need to something about my serp belt problems and seeing as how the pulley's were changed and now I am having problems I am considering going back to the OEM ones.
Old 12-27-2011   #1823
Just get new OEM ones, I should probably consider changing mine when I replace my acc belt this spring (it's about due).
Old 12-27-2011   #1824
Murlo26
Murlo26's Avatar
That was one thing I considered. Maybe I should just do that, I know that will work fine. I guess I will see what pricing is like on them.
Old 02-03-2012   #1825
Murlo26
Murlo26's Avatar
Can I get an overlay Scheides or another person who is an overlay wizard? Shane couldn't find my old FPblack dynos in the database when I was at DB last so I never got them. I don't think I ever got one for my two setups and was just curious on how my 2.2L works compared to my 2.0L. Sorry bored at work
Thank you to whoever can help me Just getting ancy for spring and car stuff again.
Old 02-03-2012   #1826
DSM_421
When batteries die and are left out in freezing wheather, they freeze and get destroyed on the inside. Hopefully this mild winter didn't ruin your AMS battery and it will hold a charge.
Next time just disconnect the negative terminal, takes all of 30 seconds...
Old 02-03-2012   #1827
Murlo26
Murlo26's Avatar
^I know, I forgot last year, was as simple as that.
I disconnected it this year and pulled it out. It's been on my new tender in my basement all year.
Old 02-03-2012   #1828
Here is an overlay
U R DUMB, look back sucka!
Old 02-03-2012   #1829
Murlo26
Murlo26's Avatar
That technically wasn't my final tune though, it had breakup up top. But close enough, lol. I thought I did it but fail at looking.
Sorry to disturb
Old 02-14-2012   #1830
Murlo26
Murlo26's Avatar
Honestly my personal favorite update to this thread:
No more car payment on the evo! Thank you tax return. Now I won't feel like a dbag for having a car payment and modding at the same time...feels real good.
As there is no snow i have thought lots about the car lately.
I am in the process of putting an order through MAP right now. As of right now I am ordering a new OEM serp belt and Shawn and myself are going to look into that when it gets warm out. However, Shane commented on my brakes being really weak last time he had the car and I agreed after I drove it, I think its time for at least pads. 30k miles on stock evo pads seems pretty solid.
I REALLY want girodisc 2piece rotors for some rotational weight savings but that will have to wait. My plan is this:
Ferodo DS2500's
ATE Super Blue
AMS SS lines or technafit to save a few bucks
I think Scheides has this setup essentially, any thoughts? Mostly street driven car really.
The only other question is do you guys think my rotors should be alright or is that a maybe? Turn them maybe? Or am I stuck buying new ones?
Thanks for feedback!
Old 02-14-2012   #1831
Ferodo DS2500's are the BOMB but beware they do dust quite a bit!
Definitely get the rotors turned...I am going to be swapping in some MR 2-piece rotors on my car sometime this spring so you could get mine turned as cores if you want.
I say KISS and stick with stock lines, that's all I have on my car and they are fine. I did SS lines on my 8 on my second brake job, after 50k miles and/or some time I think it's about time to swap out the stock lines...up to you though, not a bad mod at all.
Old 02-14-2012   #1832
simulatedwood
Drives: 08 Evolution X
Awesome idea on the brakes, like scheides recommended get the rotors turned and throw on decent pads. I wouldnt do the brake lines unless you are expecting to get a fair amount of heat in the brakes then it makes sense, most street cars will never get that much heat. The biggest difference you are going to feel is getting new fluid, that alone will make the pedal much firmer just from not having old janky watery fluid. On the silver x, bleed the factory stuff out @ 10K and noticed an immediate diffence in the pedal feel.
Old 02-14-2012   #1833
Murlo26
Murlo26's Avatar
No SS lines it is. But going to buy pads and the serp belt then with the super blue. Add that to my list of shit to do this spring.
Thanks for the feedback guys.
Old 02-14-2012   #1834
cmspaz
Walls need hugs too
cmspaz's Avatar
I'm not sure if I can do X rotors due to the size increase, but let me know when you swap stuff, Scheides, I'll give your stockers a shot.
Originally Posted by Trogdor
Old 02-14-2012   #1835
Murlo26
Murlo26's Avatar
I'll be end of march time frame. I will let you know.
Old 02-15-2012   #1836
Such a baller!
Old 02-15-2012   #1837
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Spaz can do the rear but the fronts will have about a half inch or so that the brake lathe wont hit towards the end.
Old 02-15-2012   #1838
Murlo26
Murlo26's Avatar
Hmm, guess I will have to find somewhere else to do them then. Dealer maybe?
Old 02-15-2012   #1839
cmspaz
Walls need hugs too
cmspaz's Avatar
You sure? How much bigger are the X rotors over the VIII/IXs? I'm pretty sure when I did Matt D's that I had at least an inch and a half of bit clearance at the end.
Old 02-15-2012   #1840
Murlo26
Murlo26's Avatar
Evo X is 13.8" front, 13" rear.
I think the 8/9 front is 13".
Tags
