Old 07-08-2004   #1
john
Business as usual
john's Avatar
Is it a bad idea for a car driven in the winter? I read somewhere that you may have to use the gas petal to warm your car up.
Would sheet metal do to block it off (~18 gauge) or should I go with something thinker?
97 Viper GTS
Old 07-08-2004   #2
http://www.vallotton.com/fiavblockoff.asp
Old 07-08-2004   #3
LightningGSX
Hellbound
Why would you want to remove it?
-Nulli Secundus-
Old 07-08-2004   #4
It's the hot shit these days. All the kids are doing it.
Old 07-08-2004   #5
Emcee gsxtc
Emcee gsxtc's Avatar
if you only strip out your interior behind the front seats your a ricer, but if you strip out every possible little thing you are a racer.
Besides, Having my car idle up and down and everything else is annoying. A slightly cooler intake temp, and my personal favorite: LESS LINES ALL OVER THE PLACE.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 07-08-2004   #6
Enes
Enes's Avatar
so its all a big difference between an i and an a
-E
Old 07-08-2004   #7
If you suspect that your FIAV is junk and your car bounces through the rpms back and forth in startup and at idle your FIAV might be bad and if you block it off your idle will be fine...
The only reason to block it is idle problems after youve eliminated the ISC, EGR and other suspects of Idle surge. I would try and find another TB or FIAV to swap out if you ahve idle problems.
Old 07-08-2004   #8
illz
you can test if it's the fiav by simply bypassing the tb with the coolant lines without blocking off the fiav. if it's functioning, just keep it, and track down the bad isc/egr/dirty tb or intake manifold air leak
Old 07-08-2004   #9
Raptor
ConArtist
Raptor's Avatar
Of course he may just want to keep from having coolant circulate through the TB. I have had mine bypassed for 2 years and never had a problem in the winter. It also is a good way to eliminate more potential coolant leaks depending on what you do with the old connections. Ask JET about how much those coolant leaks can suck. Sometimes you might even replace a head gasket when you don't have to. :stick:
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 07-08-2004   #10
LightningGSX
Hellbound
Originally posted by Emcee gsxtc+Jul 8 2004, 12:48 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Emcee gsxtc @ Jul 8 2004, 12:48 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-LightningGSX@Jul 8 2004, 05:04 AM
Besides, Having my car idle up and down and everything else is annoying. A slightly cooler intake temp, and my personal favorite: LESS LINES ALL OVER THE PLACE. [/b][/quote]
how does removing the fiav lower your intake temp? The coolant circulates around the wax pellet of the fiav only, not the TB.
-Nulli Secundus-
Old 07-08-2004   #11
john
Business as usual
john's Avatar
Mike is right, I would just rather re-route the coolant lines and not have them near the TB. Would there be a problem with re-routing the lines and not blocking off the FIAV or are they related?
97 Viper GTS
Old 07-08-2004   #12
Jana
Mazda Bitch
Stupid question, what is FIAV?
Old 07-08-2004   #13
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Fast Idle Air Valve.
Old 07-08-2004   #14
Raptor
ConArtist
Raptor's Avatar
Not a problem just to loop the lines and leave the FIAV open. It will work fine.
651-488-7774
Old 07-08-2004   #15
john
Business as usual
john's Avatar
Thanks, I will do that in a few minutes .
97 Viper GTS
Old 07-08-2004   #16
i block that off and the ISC, to be more specific, the entire lower TB assy.
Jet made me a nice plate out of stainless, holes drilled, that fit perfect for $15. he made cher one too actually
