Old 05-10-2010   #1
93gtpeater
Drives: cbr 1000rr repsol
looking for special tool for timing belt.
I need the special tool to adjust the tension on the timing belt for a 4g63t 6 bolt. Unless some one knows a differnt way. My timing belt was loose and it jumped a tooth.
Old 05-10-2010   #2
Re: looking for special tool for timing belt.
U can use a threaded battery tie down rod.
vfaq.com is your friend.
Old 05-10-2010   #3
enasnitsi
Drives: 1993 Talon Awd
Which tool are you looking for? The long threaded rod or the tool to rotate the tensioner pulley? The tool to rotate the tensioner pulley you can get from lisle tools or any tool supplier. If I were closer I'd let you use one of the ones I have. The threaded rod you can make and you can see that on vfaq like stated already.
enasnitsi is offline   Reply With Quote
Old 05-10-2010   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
He needs the tool to rotate the tensioner pulley.
-1990 Mitsubishi Cyborg 4WD-
Old 05-11-2010   #5
93gtpeater
I need the one that rotates the pulley
Old 05-11-2010   #6
95tsi
95tsi's Avatar
Drives: a pos
use a screwdriver to pry up on it. then just make sure the hydro tensioner is within the spec range.
Old 05-11-2010   #7
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
or a pry bar. It's better than waiting.
'04 Honda Ricer: stock
Old 05-12-2010   #8
Predavore
Predavore's Avatar
http://www.toolsource.com/timing-bel...i-p-92748.html
http://www.ecrater.com/product.php?pid=5408028
http://www.jayracing.com/index.php?m...roducts_id=214
Predavore is offline   Reply With Quote
Old 05-12-2010   #9
twack
It was a auto get over it
twack's Avatar
this is what ive used on the past dozen timing belt jobs. works better then a pry bar
and you can shank people with it on the weekends too!!!
Old 05-12-2010   #10
Twack is the man.
Old 05-12-2010   #11
twack
twack's Avatar
Twack is the man.
he said he wanted a "special tool" for the timing belt. Mine is as special as they come
Old 05-12-2010   #12
blageo23
AWD4G64
blageo23's Avatar
I have all the tools you need. Id be willing to borrow them out. Mike S Has them. You can use them if you bring them back to me.
1998 Spyder AWD
567hp
490tq
Old 05-13-2010   #13
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I use a 90* needle nose pliers when I cant find the tool
Old 05-13-2010   #14
I made my own with the help of NWA's aircraft alum and titanum pins
