Old 09-03-2010   #1
Fran05
Drives: DSM
Smile My talon 1/4 mile pass @ BIR
Quest for 11's hasn't ended just yet. One more track day, September 8th. I have couple things I want to change, including a trip to DB to rent some dyno time.
Old 09-03-2010   #2
Re: My talon 1/4 mile pass @ BIR
haha, Looks like some new tires are in order too
I have seen this thing at wed night drags quite a bit the last two years.
What's the mod list?
Old 09-03-2010   #3
Fran05
Drives: DSM
Just like it says in the video, pretty much a 16g with some supporting mods. Stock motor, a very mild set of cams... FMIC and such. All boost.
I do need some stickier tires, but I'd rather spin than go through transmissions
Old 09-03-2010   #4
santa
Boost Spike
santa's Avatar
The trans usually hold up just fine. Its the rear axle's you got to worry about.
Old 09-03-2010   #5
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
isn't spinning through awd more harsh for the trans?? but i like, i like get some rx7 rims, sticker tires and 11s are there! Love the launch!
ლ(ಠ益ಠლ)
Old 09-03-2010   #6
Can we get more info on your setup?
i just posted on link. People need to put cities in their location. If you are running some higher boost 27+ you should be moving a bit quicker I'd think.
Old 09-03-2010   #7
Almost! I'd focus on shifting faster, the 1-2 shift was pretty slow, 2-3 not much better, probably shave off 4 tenths right there.
Old 09-03-2010   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice, your 1g bounces as much as mine on the launch
-Sebastian Vettel
Old 09-04-2010   #9
Fran05
Drives: DSM
Stock, shot suspension will do that. I get those "compliments" quite often, too. One time, I actually lifted front tire on the launch, according to bystanders.
Shifting is somewhat slow due to shot clutch pedal assembly. If I slam the pedal down during quick shifts, it doesn't disengage the clutch right away, so I have to wait. Hence slower shifts.
Launch def. needs to be improved, I think I am gonna try from lower rpms (5k in that video)
I am not sure if I want to go and beat on the car some more to get into 11s, we will see. I still need something to drive this winter
Tags
16g, bir, e85, talon
